Configuring Field Task Types
Field task types are configured using the extendable lookup portal.
You can access the extendable lookup portal from the Admin > General > Extendable Lookup.
Use the Extendable Lookup Search zone to search for and select the Field Task Type (D1-FieldTaskTypeLookup) extendable lookup.
  • Extendable Lookup List: This zone displays a list of values for the Field Task Type extendable lookup.
  • Extendable Lookup List: This zone provides information about the selected value.
Service Order Management Configuration
The following table outlines the field task types that must be configured to support each of the service order activity types supported by Service Order Management:
Service Order Activity Field Task Types
Enable Service — Meters
Connect SP at Source: D1-ConnectSPAtSource
Connect SP at Meter: D1-ConnectSPAtMeter
Connect SP at Source and Turn On: D1-ConnectSPAtSourceAndTurnOn
Connect SP at Meter and Turn On: D1-ConnectSPAtMeterAndTurnOn
Connect SP at Source and Install Meter: D1-ConnSPAtSrceAndInstMtr
Connect SP at Meter and Install Meter: D1-ConnSPAtMtrAndInstMtr
Install Meter: D1-InstallMeter
Turn On Meter: D1-TurnOnMeter
Enable Service — Items
Item - Connect SP at Device: D1-ConnectSPAtDevice
Item - Connect SP at Source and Turn On: D1-ConnSPAtSrceAndTurnOnDvc
Item - Connect SP at Device and Turn On: D1-ConnectSPAtDvcAndTurnOn
Connect SP at Source and Install Device: D1-ConnSPAtSrceAndInstDvc
Connect SP at Device and Install Device: D1-ConnSPAtDvcAndInstDvc
Item - Install Device: D1-InstallDevice
Turn On Item: D1-TurnOnItem
Disable Service — Meters Turn Off Meter: D1-TurnOffMeter
Disable Service — Items Turn Off Item: D1-TurnOffItem
Cut Service for Non-Payment — Meters Cut for Non-Payment: D1-CutForNonPayment
Cut Service for Non-Payment — Items Item - Cut for Non-Payment: D1-CutItemForNonPayment
Reconnect Service for Payment — Meters Reconnect for Payment: D1-ReconnectForPayment
Reconnect Service for Payment — Items Item - Reconnect for Payment: D1-ReconnectItemForPayment
Meter Exchange Exchange Meter: D1-ExchangeMeter
Item Exchange Exchange Device: D1-ExchangeDevice
Back-to-Back — Meters Read Meter: D1-ReadMeter
