Configuring Service Order Activity Types
You use the SOM Activity Type portal is to view and maintain service order activity types.
Refer to Understanding Activity Types for more information.
You can access the portal by selecting Admin, Communication, SOM Activity Type.
Note: If the Restrict Division setting in the Control by Division section in the MDM Master Configuration
is set to "Yes", this zone displays only unsecured service order activity
types as well as service order activity types with a Division (or
Divisions) associated with the user on the User Miscellaneous
Information zone on the Miscellaneous tab of the User portal.
- Activity Type List: This zone works differently than the typical zone that list types in that it displays both those activity types that have been configured as well as those activity types that have yet to be configured. Broadcast a record to display the details of the selected record.
- Activity Type: This zone provides information about the selected Activity Type
Field Task By Device Condition: This zone is used to configure field tasks such as Turn
On Device or Turn Off Device, based on the device condition. The configurations defined in this
zone are used by the SP State and Activity BO to Create parameter for algorithms based on
the Update Device (D1-UPDDVC) algorithm type. This allows the
SP State and Activity BO to Create parameter to be defined more than the 20 times
allowed on the algorithm. Note that configurations defined in this zone can also include
Service Point Type.Note: If the Restrict Division setting in the Control by Division section in the MDM Master Configuration is set to "Yes" , only service point types available to the user (based on division), and only field task types considered valid for the service point type can be defined in this zone.
Field Task By Service Point Condition: This zone is used to configure field tasks such as
“Install Device” or “Connect SP”, based the service point condition. The configurations defined
in this zone are used by the SP State and Activity BO to Create parameter for algorithms
based on the “Create Specific Activity (D1-CRSPACT) algorithm type. This
allows the SP State and Activity BO to Create parameter to be defined more than the 20
times allowed on the algorithm. Note that configurations defined in this zone can also include
Service Point Type.Note: If the Restrict Division setting in the Control by Division section in the MDM Master Configuration is set to "Yes", only service point types available to the user (based on division), and only field task types considered valid for the service point type can be defined in this zone.
Service Order Management Configuration
The following table outlines the activity types that must be configured for the service order activity types supported by Service Order Management:
Service Order Activity | Activity Type (Business Object) |
Enable Service | Enable Service (D1–EnableServiceType) |
Disable Service | Disable Service (D1–DisableServiceType) |
Cut Service for Non-Payment | Cut Service for Non-Payment (D1-CutServiceForNonPaymentType) |
Reconnect Service for Payment | Reconnect for Payment (D1–ReconnectForPaymentType) |
Meter Exchange | Exchange Meter (D1–ExchangeMeterType) |
Back-to-Back Service | Back-to-Back Service (D1–BackToBackServiceType) |
Cancel Orchestration | Cancel Orchestration (D1–CancelOrchestrationType) |
Update Orchestration | Update Orchestration (D1–UpdateOrchestrationType) |
The demonstration database contains examples of each of these service order activity types.
