Configuring Command Sets
This portal is used to display and maintain a Command Set.
You can access the portal by selecting Admin, then Device, then Command Set.
  • Command Set List: This zone lists all Command Set records. Broadcast a record to display the details of the selected record.
  • Command Set: This zone provides information about the selected Command Set.
