Configuring External Applications
This portal is used to display and maintain External Applications.
You can access the portal from the Admin, then Integration, then External Application.
  • External Applications List: This zone lists all External Application records. Broadcast a record to display the details of the selected record.
  • External Application: This zone provides information about the selected External Application.
  • Processing Method List: This zone provides the list of processing methods defined for the External Application.
  • Translation Method List: This zone provides the list of translation methods defined for the External Application.
  • Inbound BOs Send By Service Provider: This zone lists inbound Business Objects that are sent by this External Application. The identification is driven by the Business Object having a Business Object Option of type "Sent By Service Provider" that references the current External Application.
