Configuring Time of Use Map Templates
This portal is used to display and maintain a TOU Map Templates.
You can access the portal by selecting Admin, then Usage, then TOU Map Template.
  • TOU Map Template List: This zone lists all TOU Map Template records. Broadcast a record to display the details of the selected record.
  • TOU Map Template: This zone provides information about the selected TOU Map Template.
