Knowledge Base Articles
Once you have access to Oracle Support, finding Knowledge Base articles is an easy process.
  1. Log in to https://support.oracle.com.
  2. Select the Knowledge tab at the top of the Oracle Support portal.
  3. Under the Knowledge Base section, type "Oracle Utilities Meter Data Management" as the product.
  4. Enter key search topics into the Enter search terms box.
  5. Click Search.
The search results will display all knowledge articles stored on Oracle Support related to Oracle Utilities Meter Data Management for your key topics.
