Supported Head End Systems
Oracle Utilities Meter Solution products support integration with a number of vendor-specific head end systems via Oracle Smart Grid Gateway Adapters. The table below lists the supported versions of head end system for each Adapter available with Oracle Utilities Meter Solution products.
Adapter
Head End System Version
Adapter for Itron OpenWay
7.0
Itron OpenWay Operations Center SR 5.3, 5.4
Adapter for Landis+Gyr
Gridstream Command Center 7.5, 8.1, 8.4
Adapter for Sensus RNI
Sensus RNI 4.10, 4.12
Adapter for Silver Spring Networks (Itron AMM)
UtilityIQ Version 4.10, 4.12, 4.14, 5.0, 5.1
MV-90 Adapter for Itron
N/A
SGG supports the .mv9 binary, mainframe data format.
