Maintaining Inbound Web Service Operations
This portal is used to maintain a REST inbound web service operation. You can access the portal from the Operations zone on the Inbound Web Service portal for a REST service.
Refer to Inbound REST Web Services for specific information about Operations for REST records.
The following zones may appear as part of the portal's Main tab page
  • IWS Operation. This zone provides information about the selected operation.
  • Schema. This zone describes the request and response schema as defined by the operation’s web service schema. The zone is only visible when an operation schema is explicitly defined.
  • Schema Extensions. This zone manages web service schema extensions that correspond to extensions made to the operation’s internal schema. This zone is only visible if the underlying schema was extended using dynamic data area extension functionality. Each owner that extended the internal schema may provide web service schema information for their extension elements.
  • Options. This zone lists various options for the operation such as request and response samples. The zone is visible when such options exist for the operation. Note that options are maintained as part of operation record.
The following zones may appear as part of the portal's References tab page
  • IWS Operation References. This zone lists references to the current web service operation. The list includes other inbound web service operation records that reference the current operation via their web service schema. For a GET operation, the list also includes the maintenance object or business object that explicitly references the operation using a GET Operation option.
