Aggregation Master Configuration
The Aggregation Master Configuration defines common parameters used with aggregation processing, including:
- Batch Controls used by the dimension scan and aggregation process, for both scheduled and adhoc execution.
- Details for how the system compares interval and billing data for the same set of customers in order to use only one source or other.
