Connect / Disconnect
The ConnectDisconnect composite is responsible for starting and stopping the recording of usage data for a meter.
Composite Properties
Property Name |
Default Value |
Description |
CB_CDCallbackEndpoint |
http://[SERVER_NAME]/soa-infra/services/DG/ConnectDisconnect/CB_ServerService |
The default endpoint to which MultiSpeak should send the asynchronous CB_Server callback. |
isExecutingCDReceivedCallout |
true |
Controls whether the Request Received callout executes. |
isExecutingCDCompletedCallout |
true |
Controls whether the Request Received Completed callout executes. |
isExecutingCDStatesChangedArrivedCallout |
true |
Controls whether the CD States Changed Notification arrival callout executes. |
CallbackTimeoutYears |
0 |
The number of years to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
CallbackTimeoutMonths |
0 |
The number of months to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
CallbackTimeoutDays |
0 |
The number of days to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
CallbackTimeoutHours |
0 |
The number of hours to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
CallbackTimeoutMinutes |
0 |
The number of minutes to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
CallbackTimeoutSeconds |
45 |
The number of seconds to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
Composite WSDLs
Composite |
Description |
ConnectDisconnectService |
Entry point for the ConnectDisconnect operation. After a synchronous reply, further updates will be sent to the specified location asynchronously using DG-ConnectDisconnectStateChgNotification. |
CB_ServerService |
MultiSpeak WSDL hosted to receive asynchronous CDStatesChangedNotification callbacks from the head end system. |
CB_ServerCallout |
Reference describing the process callout used when the asynchronous callback from the head end system arrives. |
CD_ServerCallout |
Reference describing the process callout. |
CD_ServerProxy |
Reference describing the proxy used to invoke the head end system. |
AuxiliaryRoutines |
Reference to common helper routines in the Common composite. |
DG-ConnectDisconnectStateChgNotification |
A reference to an inbound web service capable of processing asynchronous results from a Connect/Disconnect request. |
Process Flow
SGG/OUAF invokes InitiateConnectDisconnect operation using ConnectDisconnectService.
Composite properties are loaded and local variables are initialized.
Test whether the input includes a expiration time
If Yes: Use AuxilaryRoutines to compute timeout.
If No: Use composite properties and AuxiliaryRoutines to compute expiration time.
Both the Header and Body inputs are transformed to MultiSpeak format.
If required, execute a process callout in CD_ServerCallout. Assign updated data to head end request.
Add a callback URL to the head end request. This is the endpoint the head end will use to send the results.
Invoke InitiateConnectDisconnect via the CD_ServerProxy to the head end system.
If required, execute a process callout in CD_ServerCallout. Assign updated data to head end response.
Transform Header and Body head end responses to SGG/OUAF format.
Reply to SGG/OUAF with synchronous results.
Check for ErrorObject in the head end response.
If error object not found:
Await asynchronous response from head-end system for the period of expiration time calculated during start of this flow:
Receive CDStatesChangeNotification from CB_ServiceService.
Generate reply with no errors for CDStatesChangeNotification
Synchronously reply to the head end.
If required, execute a process callout in CB_ServerCallout. Assign updated data to the incoming request.
Transform Header and Body of incoming request to OUAF inbound web service format described in DG-ConnectDisconnectStateChgNotification.
If request contains responseURL
Invoke the inbound web service on given responseURL with the transformed incoming request.
Else
Invoke the inbound web service on definedURL with the transformed incoming request.
