Inbound Web Services
Inbound web services are used to receive inbound communications from external systems. The tables below list the inbound web services provided with each Smart Grid Gateway adapter.
Itron OpenWay Inbound Web Services
The table below lists the inbound web service provided with the Itron OpenWay adapter.
Name |
Description |
D8-RequestStatusChangedService |
Itron RequestStatusChangedService: Use to receive “status changed” messages from the Itron OpenWay head end system. This service creates instances of the “Itron – StatusChanged” (D8-StatusChanged) inbound communication business object for each message. |
D8-DataSubscriberService |
Itron DataSubscriberService: Used to receive usage and device event payloads from the Itron OpenWay head end system. This service invokes the “Itron – DataArrived Request” (D8_DATAARR) service script, which invokes the ItronDataArrivedStreamProcessor business component to process the usage or device event payload based on the configuration of the Itron Master Configuration, the SGG Payload Processing Configuration extendable lookup, and the File Storage extendable lookup. |
D8-EventSubscriberService |
Itron EventSubscriberService: Used to receive device event payloads from the Itron OpenWay head end system. This service invokes the “Itron – EventsArrived Request” (D8_EVNTSARR) service script, which invokes the ItronEventsArrivedStreamProcessor business component to process the device event payload based on the configuration of the Itron Master Configuration, the SGG Payload Processing Configuration extendable lookup, and the File Storage extendable lookup. |
D8-ExceptionSubscriberService |
Itron ExceptionSubscriberService: Used to receive exceptions from the Itron OpenWay head end system. This service invokes the “Itron – ExceptionsArrived Request” (D8_EXCPARR) service script, which invokes the ItronExceptionsArrivedStreamProcessor business component to process the exception based on the configuration of the Itron Master Configuration, the SGG Payload Processing Configuration extendable lookup, and the File Storage extendable lookup. |
Landis+Gyr Inbound Web Services
The table below lists the inbound web services provided with the Landis+Gyr adapter.
Name |
Schema Name |
Request / Response XSL |
CD State Changed Notification (Callback) (D3-CB_CD) |
D3-ConnectDisconStateChgNtfDR |
D3-ConDiscnStateChgNtfReq.xsl D3-ConDiscnStateChgNtfResp.xsl |
Reading Changed Notification (Callback) (D3-CB_MR) |
D3-ReadingChgNotificationDR |
D3-ReadingChgNotifRequest.xsl D3-ReadingChgNotifResponse.xsl |
CIM Service Callback (D3-CIMCallback) |
D3-CIMAsyncReplyMeterReadingDR |
D3-CIMMeterReadingRequest.xsl D3-CIMMeterReadingResponse.xsl |
Schedule Demand Response (Multispeak) (D3-ScheduleDemandResetResponse) |
Sensus Inbound Web Services
The table below lists the inbound web services provided with the Sensus adapter.
Name |
Schema Name |
Reading Changed Notification (Callback) (D6-CB_MR) |
D6-ReadingChgNotificationDR |
D6-ReadingChgNotifRequest.xsl D6-ReadingChgNotifResponse.xsl |
Sensus MultiSpeak CB_Server Interface (D6-CB_Server) |
D6-ConnectDisconStateChgNtfDR |
D6-ConDiscnStateChgNtfReq.xsl D6-ConDiscnStateChgNtfResp.xsl |
Sensus MultiSpeak OA_Server Interface (D6-OA_Server) |
D6-ODEventNotificationDR |
D6-ODEventNotifRequest.xsl D6-ODEventNotifResponse.xsl |
Unsolicited Event Response D6-UnsolicitedEventNotification |
D6-UnsolicitedEvtNotification |
