Maintaining Dynamic Option Events
This portal is used to display and maintain a Dynamic Option Event.
Refer to About Dynamic Option Events for additional functional information.
You can access the portal from Menu > Usage > Dynamic Option Event. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
The following zone may appear as part of the portal's Main tab page:
- Dynamic Option Event: defines the basic information about a Dynamic Option Event.
