Parameter | Description |
config.enabled | Enable/disable Switching Interface Default: true |
config.credentials | Absolute path to the file containing user credentials the adapter will use to communicate with Oracle Utilities Network Management System. Either this parameter or both config.username and config.password parameters should be provided. If all are present, then the config.username/ config.password pair is used. |
config.username | Valid NMS username, which has the 'NmsService' role in WebLogic Server. |
config.password | NMS user password. Value of this parameter should be encrypted. |
config.nms_url | URL for accessing Oracle Utilities Network Management System. If this parameter is not provided then it is assumed that Switching Adapter is deployed on the same Managed Server as cesejb.ear. |
pollingInterval | How often the adapter should poll the database for updates. Values are in seconds. Default: 15 |
sheet_type | The type of sheet to create when a request comes in to create a sheet from an external system. |
