Field | Data Type | Comments |
ID | Number | The unique ID for the record. |
INSERT_USER | Varchar2(100) | The user/system that inserted or caused the record to be inserted. |
INSERT_TIME | Date | The time the record was inserted or when the change occurred. |
UPDATE_USER | Varchar2(100) | The user/system that updated the record to be inserted. |
UPDATE_TIME | Date | The time the record was updated. |
SEQ_SHEET_ID | Number | The unique ID of the sheet this entry pertains to. This is used to identify the sheet when an entry is sent to an external system when we do not yet have an external_id. |
EXTERNAL_ID | Varchar2(4000) | The unique external ID associated with a single switching sheet in NMS. We use this to look up the sheet when a request comes in from an external system. |
INTERFACE_UPDATE_STATUS | Varchar2(1024) | This is the status of this record. It is not the status of the sheet. This is used to define when the entry is new, in error, or complete. It is not limited to those specific status values. These status values are only used by the interface to determine how to process the record. |
ERROR_MESSAGE | Varchar2(4000) | The error that occurred processing the last request. This may be populeted by the NMS interface or the interface that processed the update from NMS. The distinction will be identified by the interface_update_status value. |
STATUS | Varchar2(1024) | The status of the sheet. This may be the status of the NMS sheet or the external sheet. It depends on the value specified in the interface_update_status field. |
STATUS_DETAILS | Varchar2(4000) | Some details about the status. For instance, if it was rejected, then a rejection reason would be found in this field. |
START_TIME | Date | The Start Time of the sheet this request pertains to. This is normally only specified when creating a new sheet. |
FINISH_TIME | Date | The Finish Time of the sheet this request pertains to. This is normally only specified when creating a new sheet. |
DEVICE_ALIAS | Varchar2(4000) | The Device of the sheet this request pertains to. This is normally only specified when creating a new sheet. |
DESCRIPTION | Varchar2(4000) | The Description of the sheet this request pertains to. This is normally only specified when creating a new sheet. |
LOCATION | Varchar2(4000) | The Location of the sheet this request pertains to. This is normally only specified when creating a new sheet. |
SAFETY_DOC_ID | Varchar2(4000) | The Safety Document ID of a specific safety document that is linked to the sheet. This is only a textual reference to the safety document and does not include any details about the safety document. |
DOCUMENT_ID | Number | The unique ID for the record. |
FILE_NAME | Varchar2(256) | The name of the file. |
DESCRIPTION | Varchar2(4000) | A description for the file. |
LENGTH | Number | When populated, the size of the file in bytes. |
DATA | BLOB | The raw file data. Before the file is stored in this field, the file needs to be compressed using gzip. |
FILE_MODIFIED_DATE | Timestamp | The date the file was last modified. |
UPDATE_ID | Number | The unique ID number of the SWMAN_INTERFACE_UPDATES record this entry pertains to. |
