Menu Option | Description | View | Toolbar Icon |
Callers | Changes the Trouble Info tab to the Using the Trouble Info Callers View. | All | |
Customers | Changes the Trouble Info tab to the Using the Trouble Info Customers View. | All | |
Export Table... | Opens a dialog box to allow you to save the current table view data to a comma separated value (csv) file. | All | |
Print | Opens the Print Preview dialog box, allowing you to print the current contents of the current view. | All |
Sort Dialog... | Opens the Sort Dialog, which allows you to choose the sort columns and type (that is, ascending or descending). | All |
Default | Sorts the table according to the default settings for the view. | All |
Menu Option | Description | Views | Icon |
Refresh | Refreshes the data in the current view. | All, except AMI Customers | ![]() |
Call Info... | Opens the Call Info window for the selected call. See “Viewing Call Info”. | Callers | |
Ungroup | Opens the Ungroup dialog box, allowing you to ungroup the selected calls from the event. | Callers | |
Unassociate | Opens the Unassociate dialog box, allowing you to unassociate the selected calls from this asset and (optionally) associate them with a new asset. See Unassociating a Call from an Asset for more information. | Callers | |
Transfer Call | Opens the Transfer Call dialog box, allowing you to transfer the selected call(s) to a different event. See “Transferring a Call to a Different Event” for more information. | Callers | |
Move Customers... | Opens the Move Customers dialog box, allowing you to move selected customers to a new asset. See “Moving Customers to a Different Asset” for more information. | Callers, Customers | |
Edit Clues... | Opens the Edit Clues dialog box for the selected call. See Editing Call Clues for details. | Callers |
