Understanding the Attachments Tab Table Columns
• Name: attachment name (unique within a single damage assessment).
• File Size: attachment size in bytes (0 for links).
• Modified Date: last modification date for file attachments.
• Link: URL of the externally stored attachment.
• Description: description of the attachment
Using the Update Events Window
You can use the
Update Events dialog box to update multiple events with the same completion actions. The dialog box will display all events related to a single Work Agenda row, if any exist, or multiple events selected in the Work Agenda. See the Work Agenda
“Actions Menu” for details on the options available for selected rows.
The Update Events window includes the following panes and buttons:
• Panes
• Events to Update: Provides a table with information about the selected events. The table contains the following information:
• The Event # column displays the system assigned event number.
• The
Status column displays the event's status. See
“Event Status Codes” for a complete list of status codes and descriptions.
• The
Event Type column contains a description of the type of event. See
“Event Type Codes” for a complete list of event type codes and their descriptions.
• Operations Event Note: Text field allowing you to add a note that will apply to all of the selected events.
• Details: Provides a subset of fields from the Event Details Completion Actions tab.
• Buttons
• Select All: Selects all of the check boxes in the Details pane.
• Unselect All: Causes any selected check boxes in the Details pane to become deselected.
• Complete: Completes all of the events.
Note: You may only complete events when the required details have been added.
• Update: Updates the events with the selected details or a new operations event note.
• Help...: Launches online help for the Update Events dialog box.
• Cancel: Closes the Update Events dialog box without making any changes to the events.
