Activating a Crew
Crews are activated by changing their status from Inactive to Active, which indicates that they are available for work.
To activate a crew, complete these steps:
1. In the Crew Actions window, select the inactive crew you want to activate.
2. Select Activate from the Actions menu. (In List view, you can also right-click the crew and then select Activate from the context menu.) The status changes to Off Shift.
Note: You cannot activate a crew if its Mobile is Yes. You must choose the Toggle Mobile Off option on the Actions menu to change the mobile status before activating. The Mobile Flag columns displays No (Override), indicating that the crew's mobile status has been manually overridden.
3. You can now set the crew's status to On Shift. See Setting a Crew's Status to On Shift.
