Using Crew Info
Crew Info displays detailed crew information not shown in Crew Actions window. It allows you to unassign a crew or place a crew en route to any of its assigned events.
Crew Info topics include:
Opening Crew Info
Understanding Crew Info Window Components
Working with Crew Assignments
Opening Crew Info
To open the Crew Info window, do the following:
1.
Select the crew:
From the Crew Actions List view, select the row of the crew you want to view.
From the Crew Actions Icons view, select the icon of the crew you want to view.
2.
Click the
Crew Info…
button (
) or select
Crew Info...
from the
Actions
menu.
This site works best with JavaScript enabled
