Administration Menus
The Storm Administration environment provides the following menus:
Administration System Menu
The options in the System menu are available at all times. The following table describes the System Menu options.
Administration Help Menu
The Help menu provides links to online help content for Storm Management and information about the application, including release version and the Web Gateway that the application is using.
Administration Logout Menu
Provides the User Logout option. If you try to exit the window while there are unsaved changes in the table, a dialog box prompts you to save changes. Click Yes to save the changes in the table and exits the window. Click No to discard the changes in the table and exits the window. The Cancel button closes the dialog box without altering the changes in the table or exiting the window.
