Menu Option | Description | Toolbar Icon |
Print... | Displays the Print Preview window, from which you can view and print the summary. | |
Toggle Dockable Window | Changes a standalone window to a pane that may be moved or docked in another window or frame. See “Understanding Docked Panes and Standalone Window Tools” for more information on dockable and standalone windows. | |
Exit | Closes the SCADA Summary window. | -- |
Inhibit | Inhibit sets the inhibit quality code for the selected SCADA measurement. This suppresses any new updates from SCADA. | |
Cancel Inhibit | Cancel Inhibit removes the inhibit quality code from the selected SCADA measurement. This allows any new updates from SCADA to be displayed. | |
Manual Entry... | Manual Entry allows you to enter a new value for the selected SCADA measurement. When a changed SCADA value is received by the system, it replaces the manually entered value. | |
Manual Override... | Manual Override allows you to enter a new value for the selected SCADA measurement. When a new SCADA value is received by the system, the measurement is blocked and the manually entered value remains. | |
Cancel Override | Cancel Override cancels the manual override for the selected measurement and reverts the selected measurement to the last received value from the SCADA system. | |
Control Tool | Brings up the control tool for the selected measurement's asset. | |
View... | View focuses the Viewer on the asset. | |
Load Pressure Zone | Loads additional data for all SCADA measurements on a pressure zone when the SCADA Summary is displaying asset data. Note: This option is only available when the SCADA Summary is launched from the Control Tool. | |
Load Lift Station | Loads additional data for all lift station measurements when the SCADA Summary is displaying asset or pressure zone data. Note: This option is only available when the SCADA Summary is launched from the Control Tool. | |
Load Adjacent Lift | Loads additional data for adjacent lift stations. Note: This option is only available when the SCADA Summary is launched from the Control Tool. | |
Load All | Repopulates the SCADA Summary with all measurements. This clears any asset, pressure zone, or lift station filters; see “Viewing SCADA Data for a Selected Asset”. |
SCADA Summary Help | Opens the online help system to the SCADA Summary help content. | -- |
