Changing the Coloring Mode
When the Viewer is launched, the network model is displayed in Feeder view where all conductors fed by a feeder are displayed with the same color.
Note: The view indicator is displayed in the Viewer's status bar next to the Real-Time/Study Mode indicator.
To change to a different view, select the view from the Viewer's
Options menu (see
“Options Menu” for details on the different view options). For example, to change to the Phase coloring mode, select
View Phases from the Viewer
Options menu.
