Deleting a Crew
To delete a crew, complete these steps:
Note: You can only delete a crew if it is inactive. You cannot delete a mobile crew, even if the mobile flag has been overridden.
1. If the crew is active, you must first deactivate it (see Making a Crew Inactive). If a crew is on shift, you must first set the crew to off shift (see Setting a Crew's Status to Off Shift) and then deactivate it before you can delete it.
2. Select the crew in the Crew Actions window.
3. Select Delete from the Actions menu. (In List view, you can also right-click the crew and then select Delete from the context menu.) A dialog box prompts you to confirm the deletion.
4. Click OK. The crew is deleted from the system.
Adding a Note to the Event
You can add a note to any event that crew is assigned to.
Updating the Estimated Restore Time
You can update the Estimated Restore Time for any event that crew is assigned to using a simple display, and optionally add a note to the event at the same time.
