Removing a Contact
To remove a contact, complete these steps:
1. Click the Contact Manager tab on the Service Alert Administration Tool.
2. Click on a row in the Contacts table. This row represents the contact to be removed.
3. Click the Remove button. The Remove Contact dialog box opens.
4. Click Yes to remove the contact from the system, or No to avoid removing the contact from the system.
Group Manager
The Group Manager tab on the Service Alert Administration Tool window is used to add, edit or remove contact groups, as well as specify the notification format for a group based on each notification type. A group is used in defining notification parameters. A notification parameter is the definition of a rule used to trigger a notification. Every parameter requires a group of contacts to be specified. This group specifies the intended recipients of a notification.
From the Group Manager tab, you can perform the following tasks:
For a description of the fields and buttons on this tab, see the following topic.
