Menu Option | Description | Toolbar Icon |
Print... | Displays the Print Preview window, from which you can view and print the summary. | |
Toggle Dockable Window | Changes a standalone window to a pane that may be moved or docked in another window or frame. See “Understanding Docked Panes and Standalone Window Tools” for more information on dockable and standalone windows. | |
Exit | Closes the SCADA Summary window. | -- |
Inhibit | Inhibit sets the inhibit quality code for the selected SCADA measurement. This suppresses any new updates from SCADA. | |
Cancel Inhibit | Cancel Inhibit removes the inhibit quality code from the selected SCADA measurement. This allows any new updates from SCADA to be displayed. | |
Manual Entry... | Manual Entry allows you to enter a new value for the selected SCADA measurement. When a changed SCADA value is received by the system, it replaces the manually entered value. | |
Manual Override... | Manual Override allows you to enter a new value for the selected SCADA measurement. When a new SCADA value is received by the system, the measurement is blocked and the manually entered value remains. | |
Cancel Override | Cancel Override cancels the manual override for the selected measurement and reverts the selected measurement to the last received value from the SCADA system. | |
Disable in Power Flow | Disable in Power Flow disables the selected measurements from being included in the power flow solution. | |
Enable in Power Flow | Enable in Power Flow re-enables the selected disabled measurements in the power flow solution. | |
Reverse Polarity | Reverse Polarity sets the Reversed (r) quality code on the measurement, which then negates the value, to improve power flow calculations. Note that any subsequent manual entries and manual overrides will also be negated, as if they were SCADA readings. | |
Undo Reverse Polarity | Undo Reverse Polarity undoes the Polarity Reversal and reverts to the last received SCADA value. | |
Edit Comment... | Edit Comment allows you to modify an existing comment for the selected measurement. See “Adding and Modifying Comments for SCADA Status Changes” for more information. | |
Control Tool | Brings up the control tool for the selected measurement's device. | |
Trend Graph | Trend Graph for all phases of the attribute. | |
View... | View focuses the Viewer on the device. | |
Navigate to SCADA | If configured, submenu options open windows in the native SCADA application (currently supported by OSI). For more information, see “OSI SCADA Integration”. | |
Load Feeder | Loads additional data for all SCADA measurements on a feeder when the SCADA Summary is displaying device data. Note: This option is only available when the SCADA Summary is launched from the Control Tool. | |
Load Substation | Loads additional data for all substation measurements when the SCADA Summary is displaying device or feeder data. Note: This option is only available when the SCADA Summary is launched from the Control Tool. | |
Load Adjacent Sub | Loads additional data for adjacent substations. Note: This option is only available when the SCADA Summary is launched from the Control Tool. | |
Load All | Repopulates the SCADA Summary with all measurements. This clears any device, feeder, or substation filters; see “Viewing SCADA Data for a Selected Device”. |
SCADA Summary Help | Opens the online help system to the SCADA Summary help content. | -- |
