Menu Option | Description | Toolbar Icon |
New... | Opens the New Switching Sheet tool that allows you to create a new switching sheet based on the switching type (for example, planned or emergency). | |
Open... | Opens the selected switching sheets. If the window is not pinned or docked, the window will be closed once the sheets are loaded. Note: If the sheet is locked by another user, the Failed to Establish User Lock dialog box will be displayed; see “Opening Locked Documents” for information. | |
Copy Steps | Copies the selected switching sheet's steps without opening it. The copied steps may then be pasted into another switching sheet. | |
Export Table... | Opens a dialog box to allow you to save the current table view data to a comma separated value (csv) file. | |
Export Sheets... | Export the selected switching sheet as JavaScript Object Notation (JSON) text files to your local file system. These files can then be imported into NMS. This option is restricted to Administration and Trainer user types.See “Exporting/Importing Switching Sheets” for details. | -- |
Import Sheets... | Import switching sheets into NMS via JavaScript Object Notation (JSON) text files from your local file system. These JSON files were created from the Export Sheets... option or from the switching sheet's Export option. Imports are restricted to switching sheet types Planned, Emergency, Template and Training Scenario.See “Exporting/Importing Switching Sheets” for details. | -- |
Print List... | Displays the Print Preview dialog box so you can view or print the list. | |
Print Preview Selected Sheets... | Displays the Content Selection dialog box so that you can choose which sections of each highlighted sheet to include in the generated documents. By default, PDF documents will be created for each of the highlighted switching sheets. | |
Print Selected Sheets... | Displays the Content Selection dialog box so that you can choose which sections of each highlighted sheet to include in the generated documents. By default, PDF generated documents will be printed for each of the highlighted switching sheets. The Content Selection dialog box also includes the target print service. Your default printer will be the default option selected in the combo box list. | |
Email Selected Sheets... | Displays the Content Selection dialog box so that you can choose which sections of each highlighted sheet to include in the generated documents. By default, PDF documents will be created for each of the highlighted switching sheets. | |
Toggle Dockable Window | Changes a standalone window to a pane that may be moved or docked in another window or frame. See “Understanding Docked Panes and Standalone Window Tools” for more information on dockable and standalone windows. | |
Exit | Closes the Switching List window. | -- |
