Menu Option | Description | Icon |
Open... | Opens the selected safety documents and their associated switching sheets. If the window is not pinned or docked, the window will be closed once the safety documents are loaded. Note: If the safety is locked by another user, the Failed to Establish User Lock dialog box will be displayed; see “Opening Locked Documents” for information. | |
Export Table... | Opens a dialog box to allow you to save the current table view data to a comma separated value (csv) file. | |
Print | Displays the Print Preview dialog box so you can view or print the list. | |
Toggle Dockable Window | Changes a standalone window to a pane that may be moved or docked in another window or frame. See “Understanding Docked Panes and Standalone Window Tools” for more information on dockable and standalone windows. | |
Exit | Closes the Safety Document List window. | -- |
