Saving Exported User Configuration
To generate and save SQL statements for the current state of the configuration associated with the User Administration tab, complete the following steps:
1. Click Export Configuration... beneath the Current Users table. A dialog box appears indicating that the configuration is being generated.
2. Once the generation is finished, the Generated Configuration dialog box appears.
• To save the generated SQL statements to a file, click Save. The Save Configuration File dialog box appears. Type a name for the file into the File name field. The Save Configuration File dialog box disappears.
• To print the generated SQL statements, click Print. The Print Preview dialog box appears.
• Click Cancel to close the Generated Configuration dialog box.
Understanding the User Type Memberships Pane
The User Type Memberships pane allows you to assign a selected user to Oracle Utilities Network Management System applications and set their permissions by user type (see also “Understanding User Types”) for each.
The User Type Membership pane displays the following fields and buttons:
• The Products column lists the Oracle Utilities Network Management System modules.
• The Remaining User Types column lists the user types available to be assigned to the selected product.
• The Current User Types column lists the user types assigned to the selected product.
