Conditions Coloring
The Feeder Conditions column uses the following color-coding:
• Red: Violations Exist
• Yellow: Warnings Exist
• Green: No Warnings/Violations Exist.
See “Feeder/Device Condition Names and Colors” for a list of feeder/device conditions and their corresponding cell and text coloring.
Feeder Errors and Warnings
The Feeder Errors and Warnings dialog box lists specific device errors and warnings for each feeder that may prevent the system from solving power flow solutions.
1. Select a row in the Feeder Load Summary.
2. Select Show Errors and Statistics... from the Feeder Load Summary Actions menu. The Feeder Errors and Warnings dialog box will open.
The Feeder Errors and Warnings table displays the following information:
• Feeder: the name of the feeder with possible model errors or warnings.
• Device: the name of a device on the feeder with possible model errors or warnings.
• Severity: the error or warning type.
• Message: the error or warning message returned.
3. You may inspect a listed device's attributes and connections by selecting a row and clicking the Viewer focus button () and then launching Device Details (see “Displaying Device Details”).
