Editing Damage Assessments
The Damage Assessment page allows you to create, edit, and view damage assessments.
The page header contains damage assessment identifier and buttons to save () and reload () damage assessments from the Network Management System server.
Screen capture of Damage Assessments header showing save and reload options.
The Damage Assessment page provides five tabs which allow you to access different damage assessment details.
Screen capture of Damage Assessments tab bar showing Info, Crews, Assets, Attachments, and Map tabs.
Using the Damage Assessment Info Tab
The Info tab contains general damage assessment information.
Screen capture of the Damage Assessments Info tab.
The Damage Assessment Info tab provides the following information:
• State: Allows you to select the state of the Damage Assessment (Assessed, Standing By, Obsolete, and Fixed).
• Reporting Crew: The name of the crew that reported the damage.
• Assigned Crew: The name of the crew that is assigned to perform the damage assessment.
• Main Event: The event associated with the main damaged asset. The button associated with this field () opens page with details for the event (if it is assigned to you).
• Patrol Event: The patrol event associated with this damage assessment. The button associated with this field () opens page with details for the patrol event (if it is assigned to you).
• Main Device: The main damaged device.
• Address: Allows you to enter the address where the damage is.
• Feeder: The feeder where damage is located.
• Affected Section: Allows you to select the affected section of the electrical network.
• Hazard: Allows you to select whether damage is hazardous.
• Street Light Damage: Allows you to select whether street light damage has occurred.
• Comment: Allows you to enter comments.
Using the Crews Tab
The Damage Assessment Crews tab allows you to identify the type and number of crews needed to repair the damage.
Screen capture of the Damage Assessments Crews tab.
Using the Assets Tab
The Damage Assessment Assets tab allows you to view, modify, add, and delete assets that are part of the damage assessment. Each damage assessment contains one main damaged asset. It can be identified by underscored text (typically it is the first listed asset).
Screen capture of the Damage Assessments Assets tab.
Each damaged asset is displayed as a cards that contains the following information:
• Event #: The event associated with the asset.
• Asset Type: The damaged asset type.
• Device: The damaged device (only for modeled asset).
• Affected Phases: The affected phases.
• Status: The asset status (Open, Closed, N/A).
• Condition: The asset condition.
• Size: The asset size (for example, pole length or fuse rating).
• Quantity: The number of damaged assets (always 1 for modeled assets).
• Repair Time: The repair time in hours and minutes.
• Truck Accessible: Whether the asset location is truck accessible.
Each card can contain several buttons for the available actions (some buttons can be hidden is action in not applicable):
• Map () switches to Map tab and focuses map on the damaged asset location.
• Navigate () opens damaged asset location in external mapping application (for example, Google Maps)
• Edit () opens Damaged Asset dialog
• Delete () marks asset for deletion. Assets marked for deletion are crossed out
• Make Main Asset () makes asset the main damaged asset for the damage assessment
• The Add non-modeled asset button () opens Damaged Asset dialog box, which allows you to enter information about non-modeled damaged asset.
• Asset Type: Allows you to select the damaged asset’s type, such as Transformer.
• Status: Allows you to select whether the device is Open or Closed, if applicable.
• Condition: Allows you to select from a list of possible conditions applicable to the device (for example, Damaged, Down, and so on).
• Phases Affected: Allows you to select the phases affected by the damage, if applicable.
• Size: Allows you to enter the asset size. The meaning of size differs depending on the asset type. For example, for a pole, size can be length of the pole in feet, for a fuse, it can be rated current in amps, and so forth.
• Quantity: Allows you to enter the number of instances of the damaged asset.
• Truck Accessible: Toggle button allows you to indicate whether the damage location is truck-accessible.
• Create Separate Event: Toggle button allows you to create a separate event for this damaged asset.
• Repair Time: Allows you to enter the time needed to repair the damaged asset.
• Latitude/Longitude: Allows you to set the damaged asset location from your current location or the last selected location.
• Comments: Allows you to enter a comment with other information about the damaged asset.
The Add assets selected on the map button () allows you to add objects selected on the map as damaged assets. To do this, navigate to the Map tab, select one or more objects on the map, navigate back to the Assets tab, and then tap the Add assets selected on the map button.
Using the Attachments Tab
The Attachments tab allows you to view, add, and delete attachments to the damage assessment. There are two types of attachments: file attachments and link attachments (contain URL of attachment stored elsewhere).
Screen capture of the Damage Assessments Attachments tab.
Each attachment is displayed as a cards that contains the following information:
• Name: Attachment name.
• URL: Attachment URL (only for link attachments).
• Description: Attachment description.
For image attachments thumbnail is displayed on the right side of the card.
Each card contains the following buttons:
• View () opens the attachment. Link attachments are opened in web browser and file attachments are opened in the application associated with the file type
• Delete () marks attachment for deletion. Attachments marked for deletion are crossed out
• The Take Picture button (Camera icon allows you to take a photo and attach it to the switching sheet.) allows you to take a picture using mobile device built-in camera and add it as an attachment.
• The Select File button () allows you to select a file from mobile device picture gallery and add it as an attachment.
• The Add Link () button opens New Link dialog which allows you to add new link attachment.
Screen capture of the New Link dialog.
Using the Map Tab
The Damage Assessments Map tab is a convenient way to navigate to the Map page. Please see “Understanding the Map Tab - Full Operations User Type” for details.
