To Log Out
On the Workspace Banner, click your User ID and then select Logout.
Note: Closing the browser is the same as logging yourself out.
Using the Authority Dialog Box
When you are using the Flex Operations client, you only see events and crews for the areas (or zones) of authority that you are subscribed to. When you log in, you are prompted to subscribe to authority areas, but you can also change your areas of authority at any time (see “Adding and Removing Areas of Authority” for more information).
