View an Outage Event on the Map
To view the location of an outage event on the Map, select an event then click the
Focus button (
). The Map displays as a new tab in your browser, but, if desired, you can detach it and display side-by-side with your
Events and Crews tool.
When enabled, the Map’s Selection panel provides the actions available on a selected device.
