Creating, Editing, and Deleting Crews
As a Flex Operations user, you can create, edit, and delete crews.
Creating a Crew
1. From the Crew List, select the File menu and then select New.
2. In the Crew Makeup dialog box, enter the crew's information, and then click OK.
The information displayed in the Crew Makeup dialog is the same as in the NMS Crew Makeup dialog; see “Using Crew Makeup” for more information.
Edit Crew Details
1. In the Crew List, slick to select a crew.
2. Click Edit to open the Crew Makeup dialog.
3. Make your changes, then click OK.
Deleting a Crew
1. Select the crew and ensure it is not assigned to any events.
2. Click Delete.
Working with the Map
The Map provides an operational, interactive, real-time view of the distribution network. It provides context, improves situational awareness, and allows you to update the network directly.
As a Flex Operations user, you can interact with the Map to understand the current network state and assist in the outage management process. You can:
• Visualize and manage outages.
• View information about network assets like switches, conductors, and customers.
• Record device operations.
• Annotate the Map with notes and device tags.
• Add Damage Reports.
• Record Patrolling updates.
• Print the map..
