Marking Conductors as Assessed
To mark conductors as assessed, perform the following steps:
1. In the Viewer, select the conductors that you want to mark as assessed. The selected conductors will be added to the To Assess pane.
Note: You can select multiple conductors.
2. Select one or more conductors in the To Assess list and click the Assessed button () in the toolbar. The conductors are moved to the Assessed list and they receive the assessed highlight color in the Viewer.
Removing the Assessed Status from Conductors
To undo the assessment status, select one or more conductors in the Assessed list and click the Undo button (). The conductors are moved to the To Assess list and their highlight color is removed.
Removing Conductors from the Lists
To remove one or more conductors from either the To Assess or the Assessed lists, select the conductors in the list and click the Remove button ().
Using the Save Case Management Tool
A study session ‘Save Case' is the collection of changes made during a study session. The Save Case Management tool displays a table with rows for any existing save cases. The tool allows you to create a new save case containing the changes made during a current study session or, like resetting your study session to Real-Time or Nominal mode, you may set your study session based on an existing save cases.
Note: Only topology changes are included in a save case.
Opening the Save Case Management Tool
If you are creating a new save case, you would perform device operations prior to opening the Save Case Management tool. Conversely, if you want to start a study session based on an existing save case, you would not want to perform any device operations because the model will be reset to the topology as it existed when the save case was created.
To open the Save Case Management tool, do the following:
1. Start a Study Session. See Real-Time and Study Mode for more information.
2. From the Viewer's Options menu, select Study Mode, and then select Save Case Management....
Note: This option is also available from the Web Switching Steps tab's Reset context menu.
Save Case Management Tool Menus and Toolbar Options
File Menu
Option
Description
Toolbar Button
Print
Displays the Print Preview dialog box, which allows you print the Save Cases table.
Exit
Closes the Save Case Management tool.
Actions Menu
Option
Description
Toolbar Button
Save Case Details...
Displays the Save Case Details dialog box with the save case details for the selected row.
Reset
Real-Time: resets the current study session to the real-time model.
Nominal: resets the current study session to the nominal model.
Selected Save Case: resets the current study session to the save case for the selected row.
Save...
Opens the Save Case Details dialog box with the steps from the current study session.
Delete...
Displays a confirmation dialog box before deleting the selected save case.
Help Menu
Option
Description
Toolbar Button
Save Case Help
Opens the Oracle Utilities Network Management System's online help content for the Save Case Management tool.
Save Case Management Tool Data Fields
The Save Case Management tool's table contains the following information:
The Save Case Name field displays the name of the save case.
• The Description field displays a description added to the save case.
• The User field displays the name of the user who created the save case.
• The Created Date field displays the date when the save case was saved.
• The Base field displays the model that the save case was created against.
Creating a New Save Case
To create a new save case, you will first perform operations in study mode and then open the Save Case Management tool.
1. In the Save Case Management tool, click the Save... button () to open the Save Case Details dialog box.
2. Enter a name for the save case in the Save Case field.
3. Enter a description for the save case.
4. Click the Save button to save the save case.
Note: If a row was selected in the Save Case Management tool's Save Cases table, the Save Case and the Description fields will be populated with the name and description of the selected save case. If you click Save, an Overwrite Save Case? dialog box will ask you if you want to overwrite the save case with the operations in your study session.
• Click Yes to overwrite the save case.
• Click No to go back to the Save Case Details dialog box and enter a new name and description.
If you select a row in the Save Case Management tool, but want to create a new save case, click outside of a table row to deselect the row.
Understanding the Save Case Details Dialog Box
The Save Case Details dialog box contains fields, buttons, and a data table listing the operations performed in a study session.
Save Case Details Fields
The Save Case Details dialog box contains the following fields and buttons:
• The Save Case field allows you to enter a name for the save case.
• The Description field allows you to enter a description for the save case.
Save Case Details Buttons
• The Save button saves the save case with the name entered in the Save Case field. The button is only sensitized when a name has been entered.
• The Help... button launches online help for the Save Case Management tool.
• The Cancel button closes the dialog box without saving any changes.
Save Case Changes Table Fields
The current study session's operations are listed in the Save Case Changes table. The Save Case Changes table contains the following information:
• The Operation field displays the type of operation performed.
• The Device field displays the operated device's ID.
• The Phases field displays the phases affected by the operation.
Viewing an Existing Save Case
When you click the Save Case Details... button () or double-click in a row in the Save Case Management tool table, the Save Case Details dialog box is displayed in viewing mode.
The save case details are displayed, along with a Reset to Save Case and a Delete button. The Reset to Save Case button resets the current study session to the displayed save case. The Delete... button deletes the displayed save case.
Viewing Device Event History
Event History offers a table summary of events for the currently selected device and optionally, all downstream devices. The events are chronologically ordered by start date with the most recent event being first, but can be sorted by any of the other columns by clicking on the column header. You can access Device Event History by selecting Device Event History... from the Viewer's right click context menu.
Note: Your system administrator sets up the columns available in the event history table by configuring the event_history database view.
Understanding the Select Scope Pane
This pane allows you to define both how many and what kinds of events are displayed, either by filtering the events to be fetched and/or by limiting the number of events fetched.
• Device Scope: Defines whether to fetch events for just the current device (default) or for all devices downstream of this device found by a trace.
Note: If the device is de-energized, a Nominal trace is used to find the downstream devices.
• Event Status Scope: Defines whether to fetch all events (default) or only either Completed or Incomplete events
• Event Type Scope: Defines whether to fetch all events or only either Outage or Non-Outage events.
• Max Events To Fetch: Defines the maximum number of events that match the above scope to fetch. Default is 50.
• Oldest Event To Fetch: Defines a time and date limit of how far back to fetch events. Events will be fetched from the current time back to the time/date defined here. Default is Not Set.
Understanding the Event History Pane
• The Event # column contains the unique number assigned to the event. The event number is also displayed in other Oracle Utilities Network Management System applications in order to track the status of the event.
• The Event Type column indicates whether the event is predicted or an actual outage - see Evt Type column in the Work Agenda.
• The Status column indicates whether the event is predicted or an actual outage. See Event Status Codes for a complete list of status codes and descriptions.
• The Start Time column contains the date and time when the event was reported to have begun.
• The Est Restore Date column contains the date and time when the event is expected to be resolved.
• The Restored Date column contains the date and time when the event was resolved. If this field is empty, then the event has not been completed.
• The Completed Date column contains the date and time when the event was completed. If this field is empty, the event has not been completed.
• The Cause column indicates the Primary Cause option selected when the event is completed; this columns will only be filled in for completed events.
• The Remedy column indicates the Remedy option selected when the event is completed; this columns will only be filled in for completed events.
If you select a row in the table, the context menu allows you to focus the Viewer on the event location or open Event Details.
Note: For some older completed events, the Event Details may not display as the event information may no longer be in the cache.
Understanding Operations Event Note Pane
The Operations Event Note field displays notes entered regarding the selected event. These notes may include crew remarks and resolution issues.
