Emergency Switching
Emergency Switching includes any unplanned switching operations that occur due to events during storms, equipment failures, or even planned switching actions that fail or are incorrect. Unlike planned switching where the switching sheet is created and studied before it is issued, in emergency switching the switching sheet is created as the operations take place in real-time. Essentially, a switching sheet is created and implemented simultaneously. Steps are recorded on the Steps tab as the Control Tool actions are being performed, and each step is considered complete as it is being recorded.
Emergency switching operates just like planned switching, except that the Web Switching Management window and Viewer must both be in real-time mode. Whenever switching steps are recorded in a switching sheet using the real-time Control Tool, the operation is considered emergency switching. The switching sheet provides a record of the switching operation.
Any edits to the Request tab's fields or switching step fields will be logged after the switching sheet has been created (see Viewing the Edit Log for more information).
This section includes the following topics:
Creating an Emergency Switching Sheet
Emergency switching sheets are typically created from the Work Agenda, Create Event, or Event Details window. When you create an emergency sheet from either of these applications, the sheet is automatically associated to the event and saved to the database. The associated actions pertaining to the event, including the Open and Close step operations, will be included in the new sheet. The sheet cannot be deleted and will always remain associated to the originating event.
When an Emergency switching sheet is created that results in the sheet being associated to a device, then all device related attribute fields on the Request tab will be populated.
To create an emergency switching sheet, do one of the following:
• With an event selected in the Work Agenda, select Switching... from the Tools menu.
• From the Event Details Window, select Switching... from the Actions menu.
• From the Create Event window, select the Restored Real Outage event type and complete the required fields. Select the Create Switching Sheet checkbox and then click OK.
