Understanding Table Components
The following image shows an illustrated screen capture of a table showing call outs for the components.
2. Filter and Selection History (
) shows a list of recent filters, which may include
Column Quick Filter additions, and selected rows. See
Understanding Quick Filters for more information on column filters.
3. Disable Filtering button (
) temporarily disables (removes) currently applied filters; clicking the button again restores the filters.
4. The applied filter name (for example, To Do & In Progress).
5. Column Filter results shows the column being filtered and the number of rows that meet the column filter criteria; see
Understanding Quick Filters.
7. Save the
Current Filters button (
) allows you to save the combination of the filter and column quick filter criteria.
10. The header row check‑box allows you to select all of the table rows.
11. The column sort arrow icon shows the current sort direction for that column; clicking it will sort the table by that column. See
Understanding Table Sorting for details.
12. The column filter button (
) appears on any column being used in a quick filtering. When you click the button, the values available to filter on are listed allowing you to modify the quick filter; see
