Using the Distance Measurement Tool
You can measure distances on the Map:
1. In the Map toolbar, click the tool selector drop‑down () then select the measurement tool () from the available options.
2. Click in the map to add a start position.
3. Move to a different position and click again to create a turning point.
4. Double-click or click on the last point to complete the measurement. The distance is displayed in the top-right corner of the Map.
5. Click anywhere in the Map to remove the measurement.
Using the Geographic Location Tool
Feeder Highlights
You can highlight an entire feeder by hiding/subduing the other feeders.
For a selected device or conductor, click
Feeder Highlights (
) then click
Highlight Feeder or press
F. Other feeders will be displayed less prominently, but still be selectable (so you can highlight additional feeders).
To remove or clear feeder highlighting, click to select the feeder then choose
Unhighlight or press
F to toggle highlighting of the selected conductor. You can also clear highlighting from the Highlighting indicator displayed in the top-right of the Map or from the
Clear Highlighting option of Feeder Highlights. See
Feeder Focus in CNV Mode for more information on CNV's common feeder focus functionality available in the top right panel.
Viewing Downstream/Connected Customers
Click the
Customer List... button to view a list of customers downstream of the selected device.
Customer List Options
The Customer List provides two options to view additional information about a selected customer.
