To find out more about an asset or symbol, select it and then click the Attributes button from the Selection Panel.
Using the Trace Feature
The Trace tab enables you to perform traces:
1. Click to select a network asset like a device or conductor.
2. In the Trace To box, select the trace stop class.
3. Choose the Direction to trace.
4. Choose the Phase(s) to trace.
5. Click to perform the trace.
After a trace has been performed you can perform the following actions:
• Clear () the trace as displayed on the Map
• Refresh () the trace
• Target () the trace, to the Extent of the trace, or on the Start Point
• View ()the Trace Results. Trace results are displayed in a panel, and for each result you can right-click to position on the object, or fetch calculated values.
A list of recent traces is displayed, and actions can be performed on each trace in the list. See Executing Traces for more information on trace options.
Selecting and Interacting with Multiple Map Objects
There are three tools available for selecting multiple objects on the map, which can be accessed from the tool selector drop down on the Map toolbar ():
1. Box Selection: When in this mode, you can define a rectangle which will select all objects that overlap with that rectangle. You can define the rectangle by clicking and holding the left mouse button then dragging the mouse, or by clicking or tapping once to define one corner, then clicking or tapping again to define the other, which can be easier to accomplish on a touch device.
Note: This mode can also be accessed by holding shift and then clicking and dragging with the left mouse button. This will suppress the standard panning behavior and perform a box select instead.
2. Circle Selection: When in this mode, you can define a circle which will select all objects that overlap with that circle, by clicking and holding the left mouse button in th center of the circle, then dragging out to increase the radius of the circle.
3. Polygon Selection: When in this mode you can define a polygon which will select all objects that overlap with that polygon. To define the polygon click once to define the start point, then add more points by repeated clicks of the mouse. To complete the definition of the polygon either double click to place a final point and close the polygon, or click the starting point of the polygon again. The start point has an empty circle around it which will show filled when hovered with the mouse, to indicate it will be activated when clicked and close the polygon.
Note that in all of the above multi select modes the resulting selection is updated in real‑time as the selection area is being defined.
In addition to the above tools individual items can be toggled in/out of the selection by holding the Ctrl key while clicking with the left mouse button.
