Understanding the Database Schema
Overview
The following section defines in detail the schema of each database tables used by the Generic IVR Adapter. This section defines the parameters used by the Generic IVR Adapter's stored procedures.
Database Table Schema
TROUBLE_CALLS Table Schema
The TROUBLE_CALLS table stores the trouble calls that are submitted by the external application. The Generic IVR Adapter polls this table and submits new trouble call records to Oracle Utilities Network Management System, so Oracle Utilities Network Management System could apply the outage analysis algorithm to predict the outage device. The external application indirectly inserts records to the TROUBLE_CALLS table by invoking the pr_trouble_calls stored procedure. See “pr_trouble_calls” for more information.
Each field of the TROUBLE_CALLS table is matched with SRSinput field. The mapping is configurable. A column names are directly tied up to a specific field of the INCIDENTS table or the JOBS table of Oracle Utilities Network Management System.
In effect, each field in the TROUBLE_CALLS table is mapped (and the mapping is configurable) to a particular field of the INCIDENTS table or the JOBS table of Oracle Utilities Network Management System. For more information, see “Trouble Call Mapping Configuration”.
In the 'Description' column, take note that field names prefixed with 'INC.' would come from the INCIDENTS table. Field names prefixed by 'JOBS.' would come from the JOBS table. Field names prefixed by 'CC.' would come from the CES_CUSTOMERS table.
Field Name
Nullable
Data Type
Description (JMS Input String Reference)
ADDR_BUILDING
Y
VARCHAR2(10)
Customer building address. Refer to ADDR_BUILDING for more information.
Map to INC.ADDR_BUILDING
ADDR_CITY
Y
VARCHAR2(45)
Customer City/State. Refer to ADDR_CITY for more information.
Maps to INC.ADDR_CITY
ADDR_CROSS_STREET
Y
VARCHAR2(255)
Intersection cross street name.
Maps to INC.ADDR_CROSS_STREET.
ADDR_STREET
Y
VARCHAR2(255)
Customer address. Refer to ADDR_STREET for more information.
Maps to INC.ADDRESS and JOBS.ADDR_STREET
ALTERNATE_PHONE
Y
VARCHAR2(32)
Alternative contact number. Refer to ALTERNATE_PHONE for more information.
Maps to INC.ALTERNATE_PHONE
APPT_RANGE
Y
NUMBER
Appointment Range. Refer to APPT_RANGE for more information.
Maps to INC.APPT_RANGE.
APPT_TIME
Y
DATE
Time of appointment (in the UTC time zone). Refer to APPT_TIME for more information.
Maps to INC.APPT_TIME.
APPT_TYPE
Y
VARCHAR2(16)
Type of appointment. Refer to APPT_TYPE for more information.
Maps to INC.APPT_TYPE.
CALL_COMMENT
Y
VARCHAR2(255)
Customer Comment. Refer to COMMENT Property Name for more information.
Maps to INC.OP_COMMENT.
CALL_ID
Y
VARCHAR2(16)
Not used.
CALL_STATUS
Y
VARCHAR2(1)
Status of the trouble call in the TROUBLE_CALLS table. The Generic IVR Adapter uses this internally to identify the status of this trouble call.
The possible values are as follows:
'N' - New trouble call
'I' - The Generic IVR Adapter is in the process of submitting this trouble call to Oracle Utilities Network Management System
'C' - Trouble call submission to Oracle Utilities Network Management System is completed.
The Generic IVR Adapter uses this field as one of the criteria in purging the TROUBLE_CALLS table for 'old' records. Records with CALL_STATUS field = 'C' will be purged.
CALL_TIME
N
DATE
Input time of call (in the UTC time zone). Refer to CALL_TIME for more information.
Maps to INC.INPUT_TIME
The Generic IVR Adapter uses this field as one of the criteria in purging the TROUBLE_CALLS table for 'old' records. The TROUBLE_CALL record is 'aged' based on the system date/time and the CALL_TIME field. Any record older than a predefined number of days will be removed. See keepdbinfo for more information.
CALL_TYPE
Y
VARCHAR2(8)
Type of call. Refer to CALL_TYPE for more information.
Maps to INC.TYPE
CALLBACK_LATE
Y
VARCHAR2(1)
Callback late indicator. Refer to CALLBACK_LATE for more information.
'Y' - It is OK to call back even when it is already late.
'N' - It is not OK to call back when it is already late.
If no value was supplied, this field will default to 'N'.
This information is only passed from the external application to Oracle Utilities Network Management System (using the Trouble Calls Data Flow), and back to the external application (using the Callback Requests Data Flow). No other action is taken.
CALLBACK_EMAIL
Y
VARCHAR2(254)
The callback email address.
CALLBACK_METHOD
N
number
The callback method requested (1‑phone, 2‑text, 3‑email).
CALLBACK_TEXT
Y
VARCHAR2(32)
The callback text number.
CALLBACK_REQUEST
Y
NUMBER
Callback request indicator. Refer to CALLBACK_REQUEST for more information.
'0' - callback not requested
'1' - restoration callback requested
'4' - ERT callback requested
'5' - ERT and restoration callbacks requested
Maps to INC.CALLBACK_REQUEST
CALLBACK_TIME
Y
DATE
Callback Before Time (in the UTC time zone). Refer to CALLBACK_TIME for more information.
Maps to INC.CALLBACK_TIME
CHECK_CUTOFF
Y
VARCHAR2(1)
Check cut-off customer indicator. Refer to CHECK_CUTOFF for more information.
'Y' - check if the customer is disconnected
'N' - do not perform checking.
CLUE
Y
NUMBER
Indicates if call is clue if set to Y. Refer to “CLUE” for more information.
Maps to INC.CLUE
COMBINE_PRI
Y
NUMBER
Total priority of call. Refer to COMBINE_PRI for more information.
CUST_CALL_CANCEL
Y
VARCHAR2(1)
Call cancel indicator. Refer to CUST_CALL_CANCEL for more information.
Maps to INC.CALL_CANCEL
CUST_CRITICAL
Y
VARCHAR2(1)
Critical customer indicator. This is added to the critical C count of the outage. Refer to CUST_CRITICAL for more information.
Maps to INC.CRITICAL_CUST
CUST_DEVICE_ALIAS
Y
VARCHAR2(32)
Customer Device Alias. Refer to CUST_DEVICE_ALIAS for more information.
Maps to INC.OBJECT
CUST_DEVICE_CLS
Y
NUMBER
Corresponding CC.H_CLS field for the given CC.SERV_LOC_ID. This field does not have a corresponding input parameter in the pr_trouble_calls stored procedure. The stored procedure itself populates this field. Refer to CUST_DEVICE_CLS for more information.
Maps to INC.H_CLS
CUST_DEVICE_IDX
Y
NUMBER
Corresponding CC.H_IDX field for the given CC.SERV_LOC_ID. This field does not have a corresponding input parameter in the pr_trouble_calls stored procedure. The stored procedure itself populates this field. Refer to CUST_DEVICE_IDX for more information.
Maps to INC.H_IDX
CUST_DEVICE_NCG
Y
NUMBER
NCG of customer device. Refer to CUST_DEVICE_NCG for more information.
Maps to INC.NCG
CUST_DEVICE_PARTITION
Y
NUMBER
Partition of customer device. Refer to CUST_DEVICE_ PARTITION for more information.
Maps to INC.PARTITION
CUST_FIRST_NAME
Y
VARCHAR2(75)
Customer Name. Refer to CUST_FIRST_NAME for more information.
Maps to INC.CUSTOMER_NAME and
JOBS.CUSTOMER_NAME
CUST_ID
Y
VARCHAR2(64)
Unique customer record identifier. Maps to INC.CID.
CUST_INTERSECT_CLS
Y
NUMBER
Intersecting device class. Refer to CUST_INTERSECT_ CLS for more information.
CUST_INTERSECT_IDX
Y
NUMBER
Intersecting device index. Refer to CUST_INTERSECT_ IDX for more information.
CUST_INTERSECT_NCG
Y
NUMBER
Intersecting NCG. Refer to CUST_INTERSECT_ NCG for more information.
CUST_INTR_X
Y
NUMBER
Intersecting X coordinate. X coordinate used for intersection grouping.
CUST_INTR_Y
Y
NUMBER
Intersecting Y coordinate.Y coordinate used for intersection grouping.
CUST_KEY
Y
VARCHAR2(16)
Corresponding CC.ACCOUNT_NUMBER field for the given CC.SERV_LOC_ID. This field does not have a corresponding input parameter in the pr_trouble_calls stored procedure. The stored procedure itself populates this field. Refer to CUST_KEY for more information.
Maps to INC.ACCOUNT_NUM
CUST_LAST_NAME
Y
VARCHAR2(75)
The last name of the customer. Refer to CUST_LAST_NAME for more information.
JOBS.CUSTOMER_NAME
CUST_LIFE_SUPPORT
Y
VARCHAR2(1)
Life support customer. Refer to CUST_LIFE_SUPPORT for more information.
Maps to INC.LIFE_SUPPORT
CUST_ORDER_NUM
Y
VARCHAR2(16)
Customer order number. Refer to CUST_ORDER_NUM for more information.
Maps to INC.ORDER_NUMBER
CUST_PHONE
Y
VARCHAR2(32)
Customer phone number. Refer to CUST_PHONE for more information.
Maps to INC.CUSTOMER_PHONE and JOBS.CUSTOMER_PHONE
CUST_PHONE_AREA
Y
VARCHAR2(8)
Customer phone area code. Refer to CUST_PHONE_AREA for more information.
JOBS.CUSTOMER_PHONE
CUST_PHONE_UPDATE
Y
VARCHAR2(1)
Whether to update customer phone. Refer to CUST_PHONE_ UPDATE for more information.
CUST_PRIORITY
Y
VARCHAR2(4)
Customer Priority. Refer to CUST_PRIORITY for more information.
This is defined by customer and needs to be an integer string.
Maps to INC.CUSTOMER_TYPE
CUST_STATUS
Y
NUMBER
Condition status of call.
CUST_TROUBLE_CODE
N
VARCHAR2(10)
Trouble code or customer complaint. Refer to CUST_TROUBLE_ CODE for more information.
This is the trouble or complaint that the customer reports when making a call. The trouble code determines the priority of the incident.
Trouble code mapping set up in Oracle Utilities Network Management System should be synchronized with the trouble code mapping set up on the external application. This is to ensure that the trouble code sent from the external application is interpreted similarly when the trouble code is received by Oracle Utilities Network Management System.
Maps to INC.COMPLAINT
CUST_TROUBLE_QUEUE
Y
VARCHAR2(10)
Customer trouble queue. Refer to CUST_TROUBLE_ QUEUE for more information.
This field contains the name of the work group queue that the event has been referred to.
Maps to INC.TROUBLE_QUEUE and JOBS.TROUBLE_QUEUE
DRV_INST
Y
VARCHAR2(180)
Driving instructions.
Maps to INC.DRV_INSTR1
EST_REST_TIME
Y
Date
The ERT (in the UTC time zone).
EXTERNAL_ID
N
VARCHAR2(16)
External ID. Refer to EXTERNAL_ID for more information
If it is used, its value should be unique.
Maps to INC.EXTERNAL_ID and
JOBS.EXTERNAL_ID
FUZZY_NCG_CLS
Y
NUMBER
Fuzzy control zone class.
FUZZY_NCG_IDX
Y
NUMBER
Fuzzy control zone index.
GENERAL_AREA
Y
VARCHAR2(32)
General Area. Not Used in the SPL OMS System.
Maps to INC.GENERAL_AREA
GROUP_BY_NAME
Y
VARCHAR2(127)
Fuzzy control zone name.
GROUPABLE
Y
NUMBER
Indicates if call is groupable if set to 1.
Maps to INC.GROUPABLE
MEET_TIME
Y
DATE
Time of customer meet (in the UTC time zone). Refer to MEET_TIME for more information.
Maps to INC.MEET_TIME
MEET_TYPE
Y
NUMBER
Customer meet type. Refer to MEET_TYPE for more information.
Maps to INC.MEET_CODE
METER_ID
Y
VARCHAR2(32)
Customer meter number.
Maps to INC.METER_ID
RELATED_EVT_APP
Y
NUMBER
Related event application.
RELATED_EVT_CLS
Y
NUMBER
Related event class.
Maps to INC. RELATED_CLS
RELATED_EVT_IDX
Y
NUMBER
Related event index.
Maps to INC. RELATED_IDX
REPORTED_ERT
Y
DATE
Estimated restoration time reported to caller (in the UTC time zone).
Maps to INC. REPORTED_EST_REST_TIME
SHORT_DESC
Y
VARCHAR2(128)
Trouble short description.
Maps to INC.SHORT_DESC
TROUBLE_LOC
Y
VARCHAR2(255)
Incident's trouble location.
Maps to INC.TROUBLE_LOC
UPDATE_EXISTING_INC
Y
NUMBER
Whether to update an existing incident. Refer to UPDATE_EXISTING_ INC for more information.
USER_NAME
Y
VARCHAR2(32)
Call-taker user name. Refer to USER_NAME for more information.
Maps to INC.USER_NAME
X_REF
Y
NUMBER
Customer X coordinate. Refer to X_REF for more information.
Maps to INC.X_COORD
Y_REF
Y
NUMBER
Customer Y coordinate. Refer to Y_REF for more information.
Maps to INC.Y_COORD
TROUBLE_CALLBACKS Table Schema
The TROUBLE_CALLBACKS table contains callback request information that has to be reported to the external application. The table also stores the corresponding callback response received from the external application. The Generic IVR Adapter directly inserts new callback requests to the said table. It also directly picks up processed callbacks from the same table. The external application is provided two stored procedures for indirectly reading and updating callback information from the table.
From the table below, on the 'Description' column, take note that field names prefixed with 'INC.' would come from the INCIDENTS table.
Column Name
Nullable
Data Type
Description
ALTERNATE_PHONE
Y
VARCHAR2(38)
Populated by the Callback Requests Data Flow from INC.ALTERNATE_PHONE.
CALL_TAKER_ID
Y
VARCHAR2(32)
Populated by the Callback Requests Data Flow from INC.USER_NAME.
CALLBACK_DONE
Y
VARCHAR2(1)
Initially populated by the Callback Requests Data Flow as 'N', signifying that the callback is not yet done.
As soon as the external application successfully returns the callback response to the Generic IVR Adapter (using pr_trouble_callback_responses stored procedure), the field is updated to 'Y', signifying that the callback has been done.
Below is a list of valid values for this field.
'N' - Callback Has Not Been Done
'Y' - Callback Has Been Done
The Generic IVR Adapter uses this field as one of the criteria in purging the TROUBLE_CALLBACKS table for 'old' records. Records with CALLBACK_DONE field = 'Y' will be purged.
CALLBACK_EMAIL
Y
VARCHAR2(254)
The callback email
CALLBACK_LATE
Y
VARCHAR2(1)
Populated by the Callback Requests Data Flow from INC.CALLBACK_LATE
CALLBACK_LATE_TIME
Y
DATE
Populated by the Callback Requests Data Flow from INC.CALLBACK_TIME (in the UTC time zone).
CALLBACK_METHOD
N
number
CALLBACK_REASON
Y
VARCHAR2(100)
This is used by the Generic IVR Adapter to indicate the source of the callback request. This will default to 'OMS'.
CALLBACK_STATUS
Y
VARCHAR2(10)
Initially populated by the Callback Requests Data Flow as NULL;
The field is repopulated by the external application (using pr_trouble_callback_responses stored procedure). The valid values are as follows:
'F' - Not Restored Callback
'R' - Restored Callback
'N' - Cancel Callback, unable to get a response
The Callback Response Data Flow is responsible for sending the updated value to Oracle Utilities Network Management System. A remapped value is placed in INC.CALLBACK_STATUS.
CALLBACK_TEXT
Y
VARCHAR2(32)
The Callback text number
CALLBACK_TIME
Y
DATE
The field could be repopulated (with time in the UTC time zone) by the external application (using pr_trouble_callback_responses stored procedure). The stored procedure defaults this field to the system date if no information was supplied by the external application.
The Callback Response Data Flow is responsible for sending the updated value to Oracle Utilities Network Management System. The value is placed in INC.CB_CALL_TIME.
CAUSE_CODE
Y
VARCHAR2(32)
This is used to relay back to customers the cause of an outage when a callback is performed.
Populated by the Callback Requests Data Flow from JOBS.CAUSE when the useExternalCause rule is set to 'yes' in the SRS_RULES.
CB_DETAIL_1
Y
VARCHAR2(80)
Populated by the Callback Requests Data Flow from a column in the PICKLIST_INFO_UPD_TR database table. Column name is configured in the IVR_ADAPTER_CONFIG database table.
CB_DETAIL_2
Y
VARCHAR2(80)
CB_DETAIL_3
Y
VARCHAR2(80)
CB_DETAIL_4
Y
VARCHAR2(80)
CUSTOMER_ADDRESS
Y
VARCHAR2(255)
Populated by the Callback Requests Data Flow by concatenating INC.ADDR_BUILDING, INC.ADDRESS and INC.ADDR_CITY
CUSTOMER_COMMENT
Y
VARCHAR2(255)
Populated by the Callback Requests Data Flow from INC.OP_COMMENT.
CUSTOMER_COUNT
Y
NUMBER
CUSTOMER_NAME
Y
VARCHAR2(75)
Populated by the Callback Requests Data Flow from INC.CUSTOMER_NAME.
CUSTOMER_PHONE
Y
VARCHAR2(38)
Populated by the Callback Requests Data Flow from INC.CUSTOMER_PHONE.
EST_REST_TIME
Y
Date
EVENT_CLS
Y
NUMBER(38)
Populated by the Callback Requests Data Flow from INC.EVENT_CLS.
EVENT_IDX
Y
NUMBER(38)
Populated by the Callback Requests Data Flow from INC.EVENT_IDX.
EXTERNAL_ID
Y
VARCHAR2(16)
Populated by the Callback Requests Data Flow from INC.EXTERNAL_ID.
INCIDENT_NUMB
N
NUMBER(38)
Populated by the Callback Requests Data Flow from INC.NUMB.
INCIDENT_TIME
Y
DATE
Populated by the Callback Requests Data Flow from INC.INPUT_TIME (in the UTC time zone).
The Generic IVR Adapter uses this field as one of the criteria in purging the TROUBLE_CALLBACKS table for 'old' records. The TROUBLE_CALLBACKS table record is 'aged' based on the system date/time and the INCIDENT_TIME field. Any record older than a predefined number of days will be removed. See “keepdbinfo” for more information.
OUTAGE_DURATION
Y
NUMBER
Outage duration in seconds.
Populated by the Callback Requests Data with the difference between JOBS.RESTORE_TIME and JOBS.BEGIN_TIME.
PREMISE_ID
N
VARCHAR2(64)
Populated by the Callback Requests Data Flow from INC.CID.
PROCESS_STATUS
Y
VARCHAR2(1)
Initially populated by the Callback Requests Data Flow as 'N', signifying that the record is a new callback
Once the record was fetched by the external application (using pr_trouble_callback_requests stored procedure), the field is automatically updated by the stored procedure to 'I' signifying that the external system is currently processing the callback response.
As soon as the external application successfully returns the callback response to the Generic IVR Adapter (using pr_trouble_callback_responses stored procedure), the field is updated to 'C', signifying that the external application has completed the processing of the callback response.
This field is internally maintained by the Generic IVR Adapter. Below is a list of valid values for this field.
'N' - New Callback
'I' - In Processing Of Callback Response
'C' - Completed The Processing Of Callback Response
The Generic IVR Adapter uses this field as one of the criteria in purging the TROUBLE_CALLBACKS table for 'old' records. Records with PROCESS_STATUS field = 'C' will be purged.
SHORT_DESCRIPTION
Y
VARCHAR2(128)
Populated by the Callback Requests Data Flow from INC.SHORT_DESC
This is the clue (e.g., 'Out') of the incident rather than the trouble code (e.g., '10000000'). 'Out' is short for 'All Power Out'.
TROUBLE_CODE
Y
VARCHAR2(32)
Populated by the Callback Requests Data Flow from INC.COMPLAINT.
This is the trouble code (e.g., '10000000') of the incident rather than the clue (e.g., 'Out'). 'Out' is short for 'All Power Out'.
Stored Procedure Parameters
pk_ccb.submit_call
Data structures and parameters of the PK_CCB.SUBMIT_CALL stored procedure:
SUBTYPE udf_field IS VARCHAR2(256);
TYPE input_call_rec IS RECORD (
call_source_id VARCHAR2(3),
service_point_id trouble_calls.cust_id%TYPE,
external_id trouble_calls.external_id%TYPE,
account_number trouble_calls.cust_key%TYPE,
trouble_code trouble_calls.cust_trouble_code%TYPE,
first_name trouble_calls.cust_first_name%TYPE,
last_name trouble_calls.cust_last_name%TYPE,
phone trouble_calls.cust_phone%TYPE,
phone_area trouble_calls.cust_phone_area%TYPE,
alt_phone trouble_calls.alternate_phone%TYPE,
priority trouble_calls.cust_priority%TYPE,
critical_flag trouble_calls.cust_critical%TYPE,
life_support_flag trouble_calls.cust_life_support%TYPE,
call_id trouble_calls.general_area%TYPE,
call_time TIMESTAMP WITH TIME ZONE,
call_comment trouble_calls.call_comment%TYPE,
call_taker trouble_calls.usename%TYPE,
call_type trouble_calls.call_type%TYPE,
addr_building trouble_calls.addr_building%TYPE,
addr_street trouble_calls.addr_street%TYPE,
addr_cross_street trouble_calls.addr_street%TYPE,
addr_city_state trouble_calls.addr_city%TYPE,
drive_instr trouble_calls.drv_inst%TYPE,
meet_time TIMESTAMP WITH TIME ZONE,
meet_type trouble_calls.meet_type%TYPE,
group_by_name trouble_calls.group_by_name%TYPE,
device_id trouble_calls.cust_device_alias%TYPE,
meter_id trouble_calls.meter_id%TYPE,
trouble_queue trouble_calls.cust_trouble_queue%TYPE,
trouble_location trouble_calls.trouble_loc%TYPE,
x_coord trouble_calls.x_ref%TYPE,
y_coord trouble_calls.y_ref%TYPE,
appt_type trouble_calls.appt_type%TYPE,
appt_time TIMESTAMP WITH TIME ZONE,
appt_range trouble_calls.appt_range%TYPE,
callback_flag trouble_calls.callback_request%TYPE,
callback_before_time TIMESTAMP WITH TIME ZONE,
callback_late_flag trouble_calls.callback_late%TYPE,
intersection_cls trouble_calls.cust_device_cls%TYPE,
intersection_idx trouble_calls.cust_device_idx%TYPE,
cancel_flag trouble_calls.cust_call_cancel%TYPE,
update_flag trouble_calls.update_existing_inc%TYPE,
udf1 udf_field,
udf2 udf_field,
udf3 udf_field,
udf4 udf_field,
udf5 udf_field
-- new/updated trouble call
PROCEDURE submit_call (
p_call IN input_call_rec,
p_err_no OUT NUMBER,
p_err_msg OUT VARCHAR2
Description of the parameters of the PK_CCB.SUBMIT_CALL stored procedure.
Parameter Name
Parameter Type
Description
p_call.call_source_id
VARCHAR2(2)
Id unique to the call capture mechanism (always set to 2 for CCB, 3 for IVR - for example), Value will be prefixed to p_call.external_id field in this stored procedure. Used to allow NMS to maintain unique call ids (incidents.external_id) across multiple call taking systems submitting independent (overlapping) sets of external_ids. Generally an integer (to better support Interactive Voice Response systems) - but can be project specific.
p_call.service_point_id
VARCHAR2(64)
Service point id.
p_call.external_id
VARCHAR2(16)
Call external id unique ID from call capture system (CCB). To ensure uniqueness a given NMS implementation needs to agree on a fixed length field (12 characters for example).
p_call. account_number
VARCHAR2(30)
Customer account number.
p_call.trouble_code
VARCHAR2(32)
Call trouble code. Integer passed as a string - each character (0-9) indicates a specific selection (or 0 for non-selection) from each of 1 to 32 different trouble call categories. Project configurable.
p_call.first_name
VARCHAR2(75)
Customer first name or full name (if customer name is passed in a single field).
p_call.last_name
VARCHAR2(75)
Customer last name.
p_call.phone
VARCHAR2(32)
p_call.phone_area
VARCHAR2(8)
p_call.alt_phone
VARCHAR2(32)
Alternative/callback phone number.
p_call.priority
VARCHAR2(4)
The same value as ces_customers.priority should be passed in. This is used to determine critical customer type.
p_call.critical_flag
VARCHAR2(1)
Critical customer (Y/N)
p_call.life_support_flag
VARCHAR2(1)
Life support flag (Y/N).
p_call.call_id
VARCHAR2(32)
Call identifier (for example, 911 call id) - mapped to general_area.
p_call.call_time
Call capture time from external call capture system
p_call.call_comment
VARCHAR2(255)
Comments
p_call.call_taker
VARCHAR2(32)
Call taker id.
p_call.call_type
VARCHAR2(8)
Call type.
CC&B should leave this field empty.
p_call.addr_building
VARCHAR2(10)
Building/block number.
p_call.addr_street
VARCHAR2(255)
Street address or name of the first intersection street.
p_call.addr_cross_street
VARCHAR2(255)
Name of the second intersection (cross) street.
p_call.addr_city_state
VARCHAR2(45)
City and (optionally) state.
p_call.drive_instr
VARCHAR2(180)
p_call.meet_time
Meet time.
p_call.meet_type
NUMBER
Meet action code.
Possible values:
• 0 - for non-meet calls
• 1 - create new meet
• 2 - reschedule existing meet
• 3- cancel existing meet
p_call.group_by_name
VARCHAR2(127)
Optional control zone name for fuzzy calls.
p_call.device_id
VARCHAR2(32)
Device alias.
p_call.meter_id
VARCHAR2(32)
Meter number.
p_call.trouble_queue
VARCHAR2(10)
Trouble queue (Tree Trimming, Underground, etc)
p_call.trouble_location
VARCHAR2(255)
Trouble location.
p_call.x_coord
NUMBER
X coordinate in the NMS electrical network model coordinate system (generally NOT lat/long). If not provided JMService will default to the coordinates for the supply_node from the point_coordinates table.
p_call.y_coord
NUMBER
Y coordinate - match for X coordinate above.
p_call.appt_type
NUMBER
Appointment type.
p_call.appt_time
Appointment time.
p_call.appt_range
NUMBER
Appointment time window in minutes.
p_call.callback_flag
NUMBER
Callback request flag.
• 0 - callback has not been requested
• 1 - restoration callback has been requested.
• 4 - ERT callback has been requested
• 5 - ERT and restoration callbacks have been requested
p_call.callback_before_time
Callback requested before this time.
p_call.callback_late_flag
VARCHAR2(1)
Callback late ok flag (Y/N)
p_call.intersection_cls
NUMBER
If p_call.service_point_id is NOT null this field is ignored. If not null and p_call.service_point_d is null interpreted as att_street_intersection.h_cls. Used to help identify an intersection (when paired with p_call.intersection_idx)
NUMBER
If p_call.service_point_id is NOT null this field is ignored. If not null and p_call.service_point_id is null interpreted as att_street_intersection.h_idx - to help identify an intersection (when paired with p_call.intersection_cls).
p_call.cancel_flag
VARCHAR2(1)
Call cancel flag (Y/N).
p_call.update_flag
NUMBER
If 0 then this is a new call, otherwise this is an update to an existing call.
p_call.udf1
VARCHAR2(255)
User-defined call field 1.
p_call.udf2
VARCHAR2(255)
p_call.udf3
VARCHAR2(255)
p_call.udf4
VARCHAR2(255)
p_call.udf5
VARCHAR2(255)
p_err_no
NUMBER
Error code.
In case of successful execution 0 is returned.
p_err_msg
VARCHAR2(200)
Internal error message.
pk_ccb.job_history
Stored procedure PK_CCB.JOB_HISTORY allows caller to retrieve list of jobs matching passed in search condition.
The following types of search conditions are supported:
• Search for specific customer by service point id, premise id or account number.
• Location-based search. Search for jobs at or nearby specified location. Location can be street intersection or street segment (block).
• Fuzzy outage search. Search for fuzzy jobs by external id, call identifier, caller name or caller phone.
• Custom search. To use custom search the stored procedure has to be modified by the project. Additional search parameters are passed in the 'p_custom' field.
CREATE OR REPLACE TYPE customer_search_obj AS OBJECT (
serv_point_id VARCHAR2(64),
premise_id NUMBER,
account_number VARCHAR2(30)
CREATE OR REPLACE TYPE location_search_obj AS OBJECT (
city VARCHAR2(200),
state VARCHAR2(30),
street1 VARCHAR2(200),
street2 VARCHAR2(200),
block_number NUMBER
CREATE OR REPLACE TYPE fuzzy_search_obj AS OBJECT (
external_id VARCHAR2(200),
call_id VARCHAR2(200),
caller_name VARCHAR2(200),
caller_phone VARCHAR2(200)
CREATE OR REPLACE TYPE custom_search_obj AS OBJECT (
field1 VARCHAR2(200),
field2 VARCHAR2(200),
field3 VARCHAR2(200),
field4 VARCHAR2(200),
field5 VARCHAR2(200)
TYPE nms_cursor IS REF CURSOR;
-- Get job history.
PROCEDURE job_history (
p_cust IN customer_search_obj,
p_loc IN location_search_obj,
p_fuzzy IN fuzzy_search_obj,
p_custom IN custom_search_obj,
p_num_days IN NUMBER,
p_jobs OUT nms_cursor,
Description of the parameters of the PK_CCB.JOB_HISTORY stored procedure.
Parameter Name
Parameter Type
Description
p_cust.serv_point_id
VARCHAR2(64)
Service point id.
p_cust.premise_id
NUMBER
Service location (premise id).
p_cust.account_number
VARCHAR2(30)
p_loc.city
VARCHAR2(200)
City.
p_loc.state
VARCHAR2(30)
State.
p_loc.street1
VARCHAR2(200)
Street name. This field is used in both street intersection search and street segment search.
p_loc.street2
VARCHAR2(200)
Second street name for street intersection search.
p_loc.block_number
NUMBER
Block number for street segment search.
p_fuzzy.external_id
VARCHAR2(200)
Call external id.
p_fuzzy.call_id
VARCHAR2(200)
Call identifier (for example, id for 911 calls).
p_fuzzy.caller_name
VARCHAR2(200)
Caller name.
p_fuzzy.caller_phone
VARCHAR2(200)
Caller phone number.
p_custom.xxx
Implementation-defined search parameters.
p_cmp_days
NUMBER
If greater than 0 then switching plans completed within specified number of days in the past will be returned in addition to current and future switching plans.
p_jobs
nms_cursor
Returned jobs information.
p_err_no
NUMBER
Error code.
p_err_msg
VERCHAR2(200)
For each returned job the following information is included.
TYPE job_rec IS RECORD (
serv_point_id ces_customers.id%TYPE,
serv_point_addr ces_customers.address%TYPE,
event_idx jobs.event_idx%TYPE,
begin_time TIMESTAMP WITH TIME ZONE,
est_rest_time TIMESTAMP WITH TIME ZONE,
est_rest_time_source jobs.est_source%TYPE,
restore_time TIMESTAMP WITH TIME ZONE,
cust_out jobs.num_cust_out%TYPE,
comments jobs.operator_comment%TYPE,
alarm_state jobs.alarm_state%TYPE,
alarm_state_desc te_valid_states.description%TYPE,
trouble_location jobs.display_name%TYPE,
status jobs.status%TYPE,
device_class jobs.devcls_name%TYPE,
trouble_code jobs.trouble_code%TYPE,
feeder_name jobs.feeder_name%TYPE,
cause jobs.cause%TYPE,
description jobs.description%TYPE,
referral_group jobs.referral_group%TYPE,
last_update_time TIMESTAMP WITH TIME ZONE,
udf1 udf_field,
udf2 udf_field,
udf3 udf_field,
udf4 udf_field,
udf5 udf_field
Field Name
Field Type
Description
serv_point_id
VARCHAR2(64)
Service point id.
serv_point_addr
VARCHAR2(200)
Service point address
event_idx
NUMBER
Event index.
begin_time
Outage begin time.
est_rest_time
Estimated restoration time (ERT).
VARCHAR2(1)
ERT source.
Possible values:
• N - no ERT.
• I - Initial ERT.
• C - crew‑entered via mobile interface.
• S - ERT calculated by Storm Management.
• O - ERT calculated by Storm Management (crew on-site).
• P - Non-publisher ERT.
• G - ERT override is in effect.
• D - ERT delay is in effect.
• U - User‑entered via applications or tools (for example, Work Agenda, Event Details, or Crew tools) other than Storm Management.
• m - Minimum ERT is not reached. The ERT is below the set threshold for minimum ERT.
• M - Maximum ERT exceeded. The Storm Management calculated ERT is beyond a set threshold for maximum ERT.
• W - System-wide default ERT.
• A - Auto-extended ERT.
• E - ERT generated by Storm Management while a crew is en route to the event.
restore_time
Outage restoration time.
cust_out
NUMBER
Number of customers affected by the outage.
comments
VARCHAR2(255)
Operator's comment. Note some customers increase this to max allowed (4k).
alarm_state
VARCHAR2(32)
Outage state.
alarm_state_desc
VARCHAR2(80)
Description of the outage state.
trouble_location
VARCHAR2(255)
status
NUMBER
Job type.
Possible values:
• 0 - Fuzzy outage.
• 1 - Probable/predicted service outage.
• 2 - Probable/predicted device outage.
• 3 - Real service outage.
• 4 - Real device outage.
• 7 - Non-outage.
• 8 - Critical meet.
• 9 - Future meet.
• 10 - Confirmed service outage.
• 11 - Confirmed secondary outage.
• 13 - Probable/predicted momentary outage.
• 14 - Real momentary outage.
• 15 - Planned outage.
• 16 - Non-electric event.
• 17 - Master switching job.
• 18 - Fault current event.
• 19 - Optimization event.
• 20 - Active Network Management job.
• 21 - Protection Scheme job.
device_class
VARCHAR2(32)
Outage device class name (e.g., fuse)
trouble_code
VARCHAR2(128)
Trouble code.
feeder_name
VARCHAR2(32)
Feeder name.
cause
VARCHAR2(32)
Outage cause.
description
VARCHAR2(128)
Job description.
referral_group
VARCHAR2(32)
Referral group.
last_update_time
Timestamp of the latest update to the outage record.
udf1
VARCHAR2(255)
Job user-defined field 1.
udf2
VARCHAR2(255)
Job user-defined field 2.
udf3
VARCHAR2(255)
Job user-defined field 3.
udf4
VARCHAR2(255)
Job user-defined field 4.
udf5
VARCHAR2(255)
Job user-defined field 5.
pk_ccb.call_history
Stored procedure PK_CCB.CALL_HISTORY will allow caller to retrieve list of calls matching search condition.
Following types of search conditions will be supported:
• Search for calls for a specific customer by service point id, premise id or account number.
• Location-based search. Search for calls at or nearby specified location. Location can be street intersection or street segment (block).
• Fuzzy outage search. Search for fuzzy calls by external id, call identifier, caller name or caller phone.
PROCEDURE call_history (
p_calls OUT nms_cursor,
For each returned call the following information is included.
-- call history record
TYPE call_rec IS RECORD (
external_id incidents.external_id%TYPE,
call_id incidents.general_area%TYPE,
serv_point_id incidents.cid%TYPE,
address incidents.address%TYPE,
short_desc incidents.short_desc%TYPE,
comments incidents.op_comment%TYPE,
call_taker incidents.user_name%TYPE,
cust_name incidents.customer_name%TYPE,
status incidents.active%TYPE,
udf1 udf_field,
udf2 udf_field,
udf3 udf_field,
udf4 udf_field,
udf5 udf_field
Field Name
Field Type
Description
external_id
VARCHAR2(16)
Call external id.
call_id
VARCHAR2(32)
serv_point_id
VARCHAR2(64)
Service point id.
call_time
Call time.
Address
VARCHAR2(255)
Address for the call.
short_desc
VARCHAR2(256)
Trouble code.
Comments
VARCHAR2(255)
Comments.
call_taker
VARCHAR2(32)
Call taker id.
cust_name
VARCHAR2(75)
Customer/caller name.
Status
VARCHAR2(1)
Call status. Possible values (other values can exist in NMS but they would not be returned by this procedure):"Y - active call "N - inactive/restored call "C - canceled call "E - call belongs to canceled job
udf1
VARCHAR2(255)
Call user-defined field 1.
udf2
VARCHAR2(255)
Call user-defined field 2.
udf3
VARCHAR2(255)
Call user-defined field 3.
udf4
VARCHAR2(255)
Call user-defined field 4.
udf5
VARCHAR2(255)
Call user-defined field 5.
pk_ccb.switching_history
The stored procedure PK_CCB.SWITCHING_HISTORY allows a caller to retrieve a list of current, future, and (optionally) past switching plans affecting a given customer.
PROCEDURE switching_history (
p_sw_plans OUT nms_cursor,
Description of the parameters of the PK_CCB.SWITCHING_HISTORY stored procedure.
Parameter Name
Parameter Type
Description
VARCHAR2(64)
Service point id.
p_cust.premise_id
NUMBER
VARCHAR2(30)
p_custom
p_sw_plans
nms_cursor
Returned switching plan information.
p_err_no
NUMBER
Error code
p_err_msg
VARCHAR2(200)
Error message.
For each returned switching plan following information is included.
-- switching plan record
TYPE switching_plan_rec IS RECORD (
plan_class swman_sheet_cls.switch_sheet_type%TYPE,
plan_number swman_sheet.switch_sheet_idx%TYPE,
start_date TIMESTAMP WITH TIME ZONE,
end_date TIMESTAMP WITH TIME ZONE,
device_alias swman_sheet.device_alias%TYPE,
state te_valid_states.state_name%TYPE,
work_district swman_sheet_extn.string_value%TYPE,
work_location swman_sheet_extn.string_value%TYPE,
work_description swman_sheet_extn.string_value%TYPE,
udf1 udf_field,
udf2 udf_field,
udf3 udf_field,
udf4 udf_field,
udf5 udf_field,
udf6 udf_field,
udf7 udf_field,
udf8 udf_field,
udf9 udf_field,
udf10 udf_field
Field Name
Field Type
Description
plan_class
VARCHAR2(32)
Switching plan type (planned, emergency, ….).
plan_number
NUMBER
Switching plan number.
start_date
Switching plan start date.
end_date
Switching plan end date.
State
VARCHAR2(32)
Switching plan state.
work_district
VARCHAR2(500)
work_location
VARCHAR2(500)
work_description
VARCHAR2(500)
serv_point_id
VARCHAR2(64)
Service point id.
serv_point_addr
VARCHAR2(200)
pk_ccb.trouble_code_config
Stored procedure PK_CCB.TROUBLE_CODE_CONFIG allows caller to retrieve list of trouble codes configured in the Oracle Utilities Network Management System.
PROCEDURE trouble_code_config (
p_trouble_codes OUT nms_cursor,
Field Name
Field Type
Description
p_trouble_codes
nms_cursor
Returned trouble code information.
p_err_no
NUMBER
Error code
p_err_msg
VARCHAR2(200)
Error message
For each returned trouble code following information is included:
-- trouble code configuration record
TYPE trouble_code_rec IS RECORD (
group_name srs_trouble_codes.group_name%TYPE,
group_order srs_trouble_codes.group_order%TYPE,
code_name srs_trouble_codes.code_name%TYPE,
code_num srs_trouble_codes.code_num%TYPE,
short_desc srs_trouble_codes.short_desc%TYPE,
description srs_trouble_codes.description%TYPE
Field Name
Field Type
Description
group_name
VARCHAR2(20)
Trouble code group name
group_order
NUMBER
Trouble code group order
code_name
VARCHAR2(40)
Trouble code name
code_num
NUMBER
Trouble code number within its group
short_desc
VARCHAR2(25)
Short description of the trouble code
description
VARCHAR2(70)
Long description of the trouble code
pr_trouble_calls
The Generic IVR Adapter provides the pr_trouble_calls procedure to be used by the external application to insert trouble calls in the TROUBLE_CALLS table. Refer to “Trouble Calls” for Data Flow details.
Below is a high level description of what is done inside the stored procedure
• Upon invoking the stored procedure, the p_premise_id parameter is used to query the CES_CUSTOMERS table (via the SERV_LOC_ID field) to retrieve the ACCOUNT_NUMBER, H_CLS and H_IDX fields of the said table. The value of these fields is placed in the corresponding columns of the TROUBLE_CALLS table.
• Other parameter values are inserted to corresponding fields on the TROUBLE_CALL table.
• Several TROUBLE_CALLS columns will have default value when no parameter value is supplied.
• Should there be an error in the record insert, an Oracle error is returned.
Note: If the given premise id has multiple accounts associated with it, only one account is used.
Below are details about each parameter of the pr_trouble_calls stored procedure. Note that the field name column indicates the corresponding column that is populated in the TROUBLE_CALLS table.
Parameters
Parameter
Direction
Data Type
Field Name
Comment
p_premise_id
In
VARCHAR2
PREMISE_ID
The value is inserted as is.
p_trouble_code
In
VARCHAR2
TROUBLE_CODE
Defaults to '1' followed by a certain number of '0'. If no value was supplied. The total length of the string is the total number of distinct groups in the SRS_TROUBLE_CODES table.
p_callback_ind
In
VARCHAR2
CALLBACK_INDICATOR
'1' - callback requested
Defaults to '1' if no value is supplied.
'Y' is translated to '1'.
'N' is translated to '0'.
p_call_time
In
DATE
CALL_TIME
Defaults to the database system date if no value is supplied. When supplied, time should be in the UTC time zone.
p_call_taker_id
In
VARCHAR2
CALL_TAKER_ID
p_alternate_phone
In
VARCHAR2
ALTERNATE_PHONE
p_customer_comment
In
VARCHAR2
CUSTOMER_COMMENT
p_customer_phone
In
VARCHAR2
CUSTOMER_PHONE
p_customer_name
In
VARCHAR2
CUSTOMER_NAME
p_customer_address
In
VARCHAR2
CUSTOMER_ADDRESS
p_customer_city_state
In
VARCHAR2
CUSTOMER_CITY_STATE
p_customer_priority
In
VARCHAR2
CUSTOMER_PRIORITY
p_external_id
In
VARCHAR2
EXTERNAL_ID
p_device_alias
In
VARCHAR2
DEVICE_ALIAS
p_check_cutoff_ind
In
VARCHAR2
CHECK_CUTOFF_IND
Defaults to 'N' if no value is supplied
p_callback_late_ind
In
VARCHAR2
CALLBACK_LATE_IND
p_callback_before_time
In
DATE
CALLBACK_BEFORE_TIME
The value is inserted as is. When supplied, time should be in the UTC time zone.
p_trouble_queue
In
VARCHAR2
TROUBLE_QUEUE
p_meter_id
In
VARCHAR2
METER_ID
p_supply_id
In
NUMBER
SUPPLY_ID
p_cust_phone_area
In
VARCHAR2
CUST_PHONE_AREA
p_cust_last_name
In
VARCHAR2
CUST_LAST_NAME
p_general_area
In
VARCHAR2
GENERAL_AREA
p_cust_order_num
In
VARCHAR2
CUST_ORDER_NUM
p_drv_inst
In
VARCHAR2
DRV_INST
p_cust_life_support
In
VARCHAR2
CUST_LIFE_SUPPORT
p_cust_call_cancel
In
VARCHAR2
CUST_CALL_CANCEL
p_short_desc
In
VARCHAR2
SHORT_DESC
p_addr_building
In
VARCHAR2
ADDR_BUILDING
p_meet_time
In
DATE
MEET_TIME
p_meet_type
In
NUMBER
MEET_TYPE
p_groupable
In
NUMBER
GROUPABLE
p_clue
In
NUMBER
CLUE
p_combine_pri
In
NUMBER
COMBINE_PRI
p_cust_status
In
NUMBER
CUST_STATUS
p_cust_intr_x
In
NUMBER
CUST_INTR_X
p_cust_intr_y
In
NUMBER
CUST_INTR_Y
p_cust_intersect_cls
In
NUMBER
CUST_INTERSECT_CLS
p_cust_intersect_idx
In
NUMBER
CUST_INTERSECT_IDX
p_cust_intersect_ncg
In
NUMBER
CUST_INTERSECT_NCG
p_update_existing_inc
In
NUMBER
UPDATE_EXISTING_INC
p_fuzzy_ncg_cls
In
NUMBER
FUZZY_NCG_CLS
p_fuzzy_ncg_idx
In
NUMBER
FUZZY_NCG_IDX
p_group_by_name
In
VARCHAR2
GROUP_BY_NAME
p_cust_critical
In
VARCHAR2
CUST_CRITICAL
p_related_evt_cls
In
NUMBER
RELATED_EVT_CLS
p_related_evt_idx
In
NUMBER
RELATED_EVT_IDX
p_related_evt_app
In
NUMBER
RELATED_EVT_APP
p_x_ref
In
NUMBER
X_REF
p_y_ref
In
NUMBER
Y_REF
p_call_type
In
VARCHAR2
CALL_TYPE
p_cust_phone_update
In
VARCHAR2
CUST_PHONE_UPDATE
p_trouble_loc
In
VARCHAR2
TROUBLE_LOC
p_appt_type
In
VARCHAR2
APPT_TYPE
p_appt_time
In
DATE
APPT_TIME
p_appt_range
In
NUMBER
APPT_RANGE
p_cust_device_ncg
In
NUMBER
CUST_DEVICE_NCG
p_cust_device_partition
In
NUMBER
p_err_premise_id
Out
VARCHAR2
VARCHAR2(80)
The erroneous premise ID input parameter
p_err_oracle_error
Out
VARCHAR2
VARCHAR2(80)
Oracle's error message.
Note: The pr_trouble_calls stored procedure does not require a call status parameter from the user to insert in the TROUBLE_CALLS stored procedure. Each time the stored procedure inserts trouble calls in the TROUBLE_CALLS table, the CALL_STATUS field is always 'N', signifying that it is a new trouble call.
• From the TROUBLE_CALLBACKS table, a list of new callback requests is created. These are the TROUBLE_CALLBACKS records whose PROCESS_STATUS field is 'N' (New) and CALLBACK_DONE field is 'N' (No).
• The list is captured within the stored procedure as a database cursor and returned to the calling application.
• The PROCESS_STATUS field of the records in the list is updated from 'N' (New) to 'I' (In Progress).
Note: Refer to the Data Flow Steps of the Callback Requests Data Flow on how the TROUBLE_CALLBACKS table is populated.
Parameter
Parameter
Direction
Cursor
p_callback_requests
In/Out
CALLBACK_CURSOR
Cursor Definition
Below are the fields of the CALLBACK_CURSOR. Take note that the CALLBACK_CURSOR is defined as a weakly typed cursor.
Field Name from the Cursor
Data Type
Field Name from TROUBLE_CALLBACKS
Comments
EVENT_CLS
NUMBER(38)
TCB.EVENT_CLS
Event class
EVENT_IDX
NUMBER(38)
TCB.EVENT_IDX
Event index
INCIDENT_NUMB
NUMBER(38)
TCB.INCIDENT_NUMB
Incident number
PREMISE_ID
VARCHAR2(50)
TCB.PREMISE_ID
Premise id
CUSTOMER_NAME
VARCHAR2(75)
TCB.CUSTOMER_NAME
Customer name
CUSTOMER_PHONE
VARCHAR2(38)
TCB.CUSTOMER_PHONE
Customer phone
CUSTOMER_ADDRESS
VARCHAR2(255)
TCB.CUSTOMER_ADDRESS
Customer address
ALTERNATE_PHONE
VARCHAR2(38)
TCB.ALTERNATE_PHONE
Customer alternate phone number
TROUBLE_CODE
VARCHAR2(32)
TCB.TROUBLE_CODE
SHORT_DESCRIPTION
VARCHAR2(128)
TCB.SHORT_DESCRIPTION
CUSTOMER_COMMENT
VARCHAR2(255)
TCB.CUSTOMER_COMMENT
Call-taker Comments. Comments provided by the customer or call-taker about the incident.
INCIDENT_TIME
DATE
TCB.INCIDENT_TIME
Input time of call (in the UTC time zone). The input time of the incident.
EXTERNAL_ID
VARCHAR2(16)
TCB.EXTERNAL_ID
Unique call identifier. The unique identifier for the incident.
CALL_TAKER_ID
VARCHAR2(32)
TCB.CALL_TAKER_ID
Call-taker user name. The name of the call-taker or interface that created the call.
CALLBACK_LATE
VARCHAR2(1)
TCB.CALLBACK_LATE
CALLBACK_LATE_TIME
DATE
TCB.CALLBACK_LATE_TIME
CALLBACK_REASON
VARCHAR2(100)
TCB.CALLBACK_REASON
CAUSE_CODE
VARCHAR2(32)
TCB.CAUSE_CODE
Cause code of the event related to the callback.
• Upon receiving the input parameter values, the stored procedure verifies if either the p_incident_numb input parameter or the p_external_id input parameter was supplied. If both were supplied, the p_incident_numb parameter takes precedence.
• The stored procedure validates if the p_callback_status input parameter has a valid value. The valid values are 'F' (not restored), 'R' (restored) and 'N' (cancel callback).
• The stored procedure verifies that there is a unique combination of p_incident_numb and p_premise_id OR a unique combination of p_external_id and p_premise_id on the TROUBLE_CALLBACKS table, whichever among p_incident_numb or p_external_id was supplied.
• The TROUBLE_CALLBACKS table is updated for the p_incident_numb and p_premise_id combination OR the p_external_id and p_premise_id combination. The following fields are updated:
• The callback's CALLBACK_DONE field to 'Y' signifying that the callback was already done.
• The callback's CALLBACK_TIME field with provided p_callback_time stored procedure parameter. CALLBACK_TIME field defaults to the system date if no value was provided.
• The callback's CALLBACK_STATUS field with the appropriate callback response code.
• Should any of these steps fail, the stored procedure exits and returns the appropriate error.
Note: Refer to the Data Flow Steps of the Callback Response Data Flow on how the TROUBLE_CALLBACKS table is populated.
Parameters
Parameter
Direction
Data Type
Field Name
Comments
p_incident_numb
In
NUMBER
INCIDENT_NUMB
Incident Number. Either this or the p_external_id parameter has to be supplied
p_external_id
In
VARCHAR2
EXTERNAL_ID
External Id. Either this or the p_incident_numb parameter has to be supplied
p_premise_id
In
VARCHAR2
PREMISE_ID
Premise Id.
p_callback_status
In
VARCHAR2
CALLBACK_STATUS
p_callback_time
In
DATE
CALLBACK_TIME
Defaulted to the system date if no value was supplied. When supplied, time should be in the UTC time zone.
p_err_incident_numb
Out
NUMBER
The erroneous incident number input parameter
p_err_external_id
Out
VARCHAR2
The erroneous external ID input parameter
p_err_premise_id
Out
VARCHAR2
p_err_oracle_error
Out
VARCHAR2
pr_customer_event_details
The Generic IVR Gateway provides the pr_customer_event_details stored procedure that gives the event details of an outage given the customer premise. Refer to the data flow detail for “Callback Requests”.
Below is a high level description of what is done inside the stored procedure.
• The stored procedure tries to get the latest event for the given premise ID (p_in_premise_id input parameter).
Parameters
Below are details about each parameter of the pr_customer_event_details stored procedure.
Parameter
Direction
Data Type
Comments
p_in_premise_id
In
VARCHAR2
Premise ID input parameter with a corresponding entry in CES_CUSTOMERS.SERV_LOC_ID.
p_out_event_class
Out
NUMBER
Event class output parameter.
p_out_event_index
Out
NUMBER
Event index output parameter.
p_out_outage_status
Out
VARCHAR2
This is an abbreviation of the current state of the event, for instance, 'NEW', 'ASN', 'CMP', an so on.
p_ out_outage_start_time
Out
DATE
The time of the lead call of the job. When supplied, time should be in the UTC time zone.
p_ out_first_dispatch_time
Out
DATE
The time the first crew was dispatched (in the UTC time zone).
p_ out_est_restore_time
Out
DATE
The last estimate of restoration time (in the UTC time zone).
p_ out_est_restore_time_src
Out
VARCHAR2
The source of the ERT of the event.
Possible values are as follows:
'N' - none (no ERT)
'S' - Storm Management
'P' - Storm Management "non-published global ERT"
'O' - Storm Management "onsite ERT"
'G' - Storm Management "published global ERT"
D' - Storm Management "published global ERT delay"
'C' - User-entered (assumed to have been provided by the crew)
'I' - Initial default ERT
'M' - Storm Management ERT is further in the future then allowed
p_ out_crew_arrival_time
Out
DATE
The time when the crew arrived on location (in the UTC time zone).
p_ out_completion_time
Out
DATE
The time the event has been completed (in the UTC time zone). This implies power restoration, the crew(s) are gone, and the event is completed in the Event Details window.
p_ out_restoration_time
Out
DATE
The time that power has been restored (in the UTC time zone).
p_ out_case_note
Out
VARCHAR2
Comment
p_ out_status
Out
NUMBER
Condition status
p_ out_active
Out
VARCHAR2
'Y' - Outage Is Active
'N' - Outage Is Not Active
p_out_alias
Out
VARCHAR2
The device alias.
P_out_event_type
Out
VARCHAR2
OUT
NON
MEET
PLAN
SWP
P_out_feeder_name
Out
VARCHAR2
The name of the feeder.
P_out_cause
Out
VARCHAR2
The cause of the outage if the SRS Rule useExternalCause is on.
P_out_num_calls
Out
NUMBER
The number of calls.
P_out_num_cust_out
Out
NUMBER
The number of customers out.
P_err_premise_id
Out
VARCHAR2
P_err_oracle_error
Out
VARCHAR2
SRSInput Testing Utility Command Line Options
SRSInput adds raw file incidents into JMService.
Usage
SRSinput [-ami][-ami_up] [-max number] [-ivr] [-time] [-blanksok] [-package number]
[-interval seconds] [-divide number] [-tilde] [-debug]
-input filename
Options/Arguments:
Option
Description
-ami
Submit AMI Last Gasp (Power Down) inputs for the meters specified by the -input parameter.
-ami_up
Submit AMI Power Up (Restore) inputs for the meters specified by the -input parameter.
-max number
Maximum number of calls to enter.
-ivr
Write calls to trouble_calls table for IVR adapter.
-time
Add input_time with current time.
-blanksok
Blank lines in call record are acceptable.
-package number
Number of calls to send to JMS at a time. Default: 10.
-interval seconds
Seconds to delay between calls.Defaults to 5. Also, it can take floating point values such as 2.5 to sleep 2 and a half seconds between call batches.
-divide number
Number to divide <WAIT> times by.
-tilde
Use the tilde in column 0 as a call separator.
-debug
Enable runtime debugging.
-input filename
Filename containing trouble call data. Required.
Note: If the -ivr option is not used, SRSinput sends calls to JMService via the C++ API.
