Menu Option | Description | Toolbar Icon |
Print... | Opens the Print Preview dialog box, which allows you to print the contents of the Model Management window. |
Refresh | Refreshes both the Pending Maps and Patches lists. | |
Halt Model Build | Stops all model build activity. See “Enabling and Disabling Model Building” for more information. | |
Enable Model Build | Enables model building activity that was previously halted. | |
Run Full Model Build | Rebuilds the entire system model, not just individual maps. | -- |
Run Post Process | Runs the post-processing script. Post processing takes place after maps are built. The default post-processing script performs a recompute and recache of the control zones in DDService, but this can be modified to perform various tasks, such as generating control zones or computing EE details from the model. | |
Enable Model Build Reporting | Enables or disables model build reporting. The Model Build Report lists all objects that were modified when a particular patch was applied. If enabled, a checkmark appears next to the menu option. | -- |
Build Map | Prompts you to enter one or more map names and then rebuilds the specified maps. If you are entering multiple map names, separate names with spaces, as shown below: Landbase_49132336 Primary_49132336 |
Smaller Font | Decreases the font size in text and icons. Repeat to further decrease the font size. |
Bigger Font | Increases the font size in text and icons. Repeat to further increase the font size. |
Reset Font | The application will reset the text and icons to use their default font size. |
Change Color Scheme... | Opens the Change Color Scheme dialog box, which allows you to select from different user interface coloring schemes. The options are a Light scheme, a Dark scheme, and the default High Definition scheme. Unlike other user preferences, these apply to all environments for the user on the machine. |
Model Management Help | Launches the online help system and loads the Model Management content. |
Email Log Files... | Gathers the environment's log files and attaches them to a new email message using your default email client. The log files can then be sent to your support team or contact for further analysis. |
Set Debug... | Launches the Set Debug dialog box allowing you to set debug on or off within your current environment. This is used for debugging and analysis purposes. See “Setting Debug” for more information. |
About Model Management | Opens a window with environment and software information. |
