Field Name | Nullable | Data Type | Description (JMS Input String Reference) |
ADDR_BUILDING | Y | VARCHAR2(10) | Customer building address. Refer to ADDR_BUILDING for more information. Map to INC.ADDR_BUILDING |
ADDR_CITY | Y | VARCHAR2(45) | Customer City/State. Refer to ADDR_CITY for more information. Maps to INC.ADDR_CITY |
ADDR_CROSS_STREET | Y | VARCHAR2(255) | Intersection cross street name. Maps to INC.ADDR_CROSS_STREET. |
ADDR_STREET | Y | VARCHAR2(255) | Customer address. Refer to ADDR_STREET for more information. Maps to INC.ADDRESS and JOBS.ADDR_STREET |
ALTERNATE_PHONE | Y | VARCHAR2(32) | Alternative contact number. Refer to ALTERNATE_PHONE for more information. Maps to INC.ALTERNATE_PHONE |
APPT_RANGE | Y | NUMBER | Appointment Range. Refer to APPT_RANGE for more information. Maps to INC.APPT_RANGE. |
APPT_TIME | Y | DATE | Time of appointment (in the UTC time zone). Refer to APPT_TIME for more information. Maps to INC.APPT_TIME. |
APPT_TYPE | Y | VARCHAR2(16) | Type of appointment. Refer to APPT_TYPE for more information. Maps to INC.APPT_TYPE. |
CALL_COMMENT | Y | VARCHAR2(255) | Customer Comment. Refer to COMMENT Property Name for more information. Maps to INC.OP_COMMENT. |
CALL_ID | Y | VARCHAR2(16) | Not used. |
CALL_STATUS | Y | VARCHAR2(1) | Status of the trouble call in the TROUBLE_CALLS table. The Generic IVR Adapter uses this internally to identify the status of this trouble call. The possible values are as follows: 'N' - New trouble call 'I' - The Generic IVR Adapter is in the process of submitting this trouble call to Oracle Utilities Network Management System 'C' - Trouble call submission to Oracle Utilities Network Management System is completed. The Generic IVR Adapter uses this field as one of the criteria in purging the TROUBLE_CALLS table for 'old' records. Records with CALL_STATUS field = 'C' will be purged. |
CALL_TIME | N | DATE | Input time of call (in the UTC time zone). Refer to CALL_TIME for more information. Maps to INC.INPUT_TIME The Generic IVR Adapter uses this field as one of the criteria in purging the TROUBLE_CALLS table for 'old' records. The TROUBLE_CALL record is 'aged' based on the system date/time and the CALL_TIME field. Any record older than a predefined number of days will be removed. See keepdbinfo for more information. |
CALL_TYPE | Y | VARCHAR2(8) | Type of call. Refer to CALL_TYPE for more information. Maps to INC.TYPE |
CALLBACK_LATE | Y | VARCHAR2(1) | Callback late indicator. Refer to CALLBACK_LATE for more information. The possible values are as follows: 'Y' - It is OK to call back even when it is already late. 'N' - It is not OK to call back when it is already late. If no value was supplied, this field will default to 'N'. This information is only passed from the external application to Oracle Utilities Network Management System (using the Trouble Calls Data Flow), and back to the external application (using the Callback Requests Data Flow). No other action is taken. |
CALLBACK_EMAIL | Y | VARCHAR2(254) | The callback email address. |
CALLBACK_METHOD | N | number | The callback method requested (1‑phone, 2‑text, 3‑email). |
CALLBACK_TEXT | Y | VARCHAR2(32) | The callback text number. |
CALLBACK_REQUEST | Y | NUMBER | Callback request indicator. Refer to CALLBACK_REQUEST for more information. The possible values are as follows: '0' - callback not requested '1' - restoration callback requested '4' - ERT callback requested '5' - ERT and restoration callbacks requested Maps to INC.CALLBACK_REQUEST |
CALLBACK_TIME | Y | DATE | Callback Before Time (in the UTC time zone). Refer to CALLBACK_TIME for more information. Maps to INC.CALLBACK_TIME |
CHECK_CUTOFF | Y | VARCHAR2(1) | Check cut-off customer indicator. Refer to CHECK_CUTOFF for more information. The possible values are as follows: 'Y' - check if the customer is disconnected 'N' - do not perform checking. |
CLUE | Y | NUMBER | Indicates if call is clue if set to Y. Refer to CLUE on page 1-18 for more information. Maps to INC.CLUE |
COMBINE_PRI | Y | NUMBER | Total priority of call. Refer to COMBINE_PRI for more information. |
CUST_CALL_CANCEL | Y | VARCHAR2(1) | Call cancel indicator. Refer to CUST_CALL_CANCEL for more information. Maps to INC.CALL_CANCEL |
CUST_CRITICAL | Y | VARCHAR2(1) | Critical customer indicator. This is added to the critical C count of the outage. Refer to CUST_CRITICAL for more information. Maps to INC.CRITICAL_CUST |
CUST_DEVICE_ALIAS | Y | VARCHAR2(32) | Customer Device Alias. Refer to CUST_DEVICE_ALIAS for more information. Maps to INC.OBJECT |
CUST_DEVICE_CLS | Y | NUMBER | Corresponding CC.H_CLS field for the given CC.SERV_LOC_ID. This field does not have a corresponding input parameter in the pr_trouble_calls stored procedure. The stored procedure itself populates this field. Refer to CUST_DEVICE_CLS for more information. Maps to INC.H_CLS |
CUST_DEVICE_IDX | Y | NUMBER | Corresponding CC.H_IDX field for the given CC.SERV_LOC_ID. This field does not have a corresponding input parameter in the pr_trouble_calls stored procedure. The stored procedure itself populates this field. Refer to CUST_DEVICE_IDX for more information. Maps to INC.H_IDX |
CUST_DEVICE_NCG | Y | NUMBER | NCG of customer device. Refer to CUST_DEVICE_NCG for more information. Maps to INC.NCG |
CUST_DEVICE_PARTITION | Y | NUMBER | Partition of customer device. Refer to CUST_DEVICE_ PARTITION for more information. Maps to INC.PARTITION |
CUST_FIRST_NAME | Y | VARCHAR2(75) | Customer Name. Refer to CUST_FIRST_NAME for more information. Maps to INC.CUSTOMER_NAME and JOBS.CUSTOMER_NAME |
CUST_ID | Y | VARCHAR2(64) | Unique customer record identifier. Maps to INC.CID. |
CUST_INTERSECT_CLS | Y | NUMBER | Intersecting device class. Refer to CUST_INTERSECT_ CLS for more information. |
CUST_INTERSECT_IDX | Y | NUMBER | Intersecting device index. Refer to CUST_INTERSECT_ IDX for more information. |
CUST_INTERSECT_NCG | Y | NUMBER | Intersecting NCG. Refer to CUST_INTERSECT_ NCG for more information. |
CUST_INTR_X | Y | NUMBER | Intersecting X coordinate. X coordinate used for intersection grouping. |
CUST_INTR_Y | Y | NUMBER | Intersecting Y coordinate.Y coordinate used for intersection grouping. |
CUST_KEY | Y | VARCHAR2(16) | Corresponding CC.ACCOUNT_NUMBER field for the given CC.SERV_LOC_ID. This field does not have a corresponding input parameter in the pr_trouble_calls stored procedure. The stored procedure itself populates this field. Refer to CUST_KEY for more information. Maps to INC.ACCOUNT_NUM |
CUST_LAST_NAME | Y | VARCHAR2(75) | The last name of the customer. Refer to CUST_LAST_NAME for more information. Maps to INC.CUSTOMER_NAME and JOBS.CUSTOMER_NAME |
CUST_LIFE_SUPPORT | Y | VARCHAR2(1) | Life support customer. Refer to CUST_LIFE_SUPPORT for more information. Maps to INC.LIFE_SUPPORT |
CUST_ORDER_NUM | Y | VARCHAR2(16) | Customer order number. Refer to CUST_ORDER_NUM for more information. Maps to INC.ORDER_NUMBER |
CUST_PHONE | Y | VARCHAR2(32) | Customer phone number. Refer to CUST_PHONE for more information. Maps to INC.CUSTOMER_PHONE and JOBS.CUSTOMER_PHONE |
CUST_PHONE_AREA | Y | VARCHAR2(8) | Customer phone area code. Refer to CUST_PHONE_AREA for more information. Maps to INC.CUSTOMER_PHONE and JOBS.CUSTOMER_PHONE |
CUST_PHONE_UPDATE | Y | VARCHAR2(1) | Whether to update customer phone. Refer to CUST_PHONE_ UPDATE for more information. |
CUST_PRIORITY | Y | VARCHAR2(4) | Customer Priority. Refer to CUST_PRIORITY for more information. This is defined by customer and needs to be an integer string. Maps to INC.CUSTOMER_TYPE |
CUST_STATUS | Y | NUMBER | Condition status of call. |
CUST_TROUBLE_CODE | N | VARCHAR2(10) | Trouble code or customer complaint. Refer to CUST_TROUBLE_ CODE for more information. This is the trouble or complaint that the customer reports when making a call. The trouble code determines the priority of the incident. Trouble code mapping set up in Oracle Utilities Network Management System should be synchronized with the trouble code mapping set up on the external application. This is to ensure that the trouble code sent from the external application is interpreted similarly when the trouble code is received by Oracle Utilities Network Management System. Maps to INC.COMPLAINT |
CUST_TROUBLE_QUEUE | Y | VARCHAR2(10) | Customer trouble queue. Refer to CUST_TROUBLE_ QUEUE for more information. This field contains the name of the work group queue that the event has been referred to. Maps to INC.TROUBLE_QUEUE and JOBS.TROUBLE_QUEUE |
DRV_INST | Y | VARCHAR2(180) | Driving instructions. Maps to INC.DRV_INSTR1 |
EST_REST_TIME | Y | Date | The ERT (in the UTC time zone). |
EXTERNAL_ID | N | VARCHAR2(16) | External ID. Refer to EXTERNAL_ID for more information If it is used, its value should be unique. Maps to INC.EXTERNAL_ID and JOBS.EXTERNAL_ID |
FUZZY_NCG_CLS | Y | NUMBER | Fuzzy control zone class. |
FUZZY_NCG_IDX | Y | NUMBER | Fuzzy control zone index. |
GENERAL_AREA | Y | VARCHAR2(32) | General Area. Not Used in the SPL OMS System. Maps to INC.GENERAL_AREA |
GROUP_BY_NAME | Y | VARCHAR2(127) | Fuzzy control zone name. |
GROUPABLE | Y | NUMBER | Indicates if call is groupable if set to 1. Maps to INC.GROUPABLE |
MEET_TIME | Y | DATE | Time of customer meet (in the UTC time zone). Refer to MEET_TIME for more information. Maps to INC.MEET_TIME |
MEET_TYPE | Y | NUMBER | Customer meet type. Refer to MEET_TYPE for more information. Maps to INC.MEET_CODE |
METER_ID | Y | VARCHAR2(32) | Customer meter number. Maps to INC.METER_ID |
RELATED_EVT_APP | Y | NUMBER | Related event application. |
RELATED_EVT_CLS | Y | NUMBER | Related event class. Maps to INC. RELATED_CLS |
RELATED_EVT_IDX | Y | NUMBER | Related event index. Maps to INC. RELATED_IDX |
REPORTED_ERT | Y | DATE | Estimated restoration time reported to caller (in the UTC time zone). Maps to INC. REPORTED_EST_REST_TIME |
SHORT_DESC | Y | VARCHAR2(128) | Trouble short description. Maps to INC.SHORT_DESC |
TROUBLE_LOC | Y | VARCHAR2(255) | Incident's trouble location. Maps to INC.TROUBLE_LOC |
UPDATE_EXISTING_INC | Y | NUMBER | Whether to update an existing incident. Refer to UPDATE_EXISTING_ INC for more information. |
USER_NAME | Y | VARCHAR2(32) | Call-taker user name. Refer to USER_NAME for more information. Maps to INC.USER_NAME |
X_REF | Y | NUMBER | Customer X coordinate. Refer to X_REF for more information. Maps to INC.X_COORD |
Y_REF | Y | NUMBER | Customer Y coordinate. Refer to Y_REF for more information. Maps to INC.Y_COORD |
Column Name | Nullable | Data Type | Description |
ALTERNATE_PHONE | Y | VARCHAR2(38) | Populated by the Callback Requests Data Flow from INC.ALTERNATE_PHONE. |
CALL_TAKER_ID | Y | VARCHAR2(32) | Populated by the Callback Requests Data Flow from INC.USER_NAME. |
CALLBACK_DONE | Y | VARCHAR2(1) | Initially populated by the Callback Requests Data Flow as 'N', signifying that the callback is not yet done. As soon as the external application successfully returns the callback response to the Generic IVR Adapter (using pr_trouble_callback_responses stored procedure), the field is updated to 'Y', signifying that the callback has been done. Below is a list of valid values for this field. 'N' - Callback Has Not Been Done 'Y' - Callback Has Been Done The Generic IVR Adapter uses this field as one of the criteria in purging the TROUBLE_CALLBACKS table for 'old' records. Records with CALLBACK_DONE field = 'Y' will be purged. |
CALLBACK_EMAIL | Y | VARCHAR2(254) | The callback email |
CALLBACK_LATE | Y | VARCHAR2(1) | Populated by the Callback Requests Data Flow from INC.CALLBACK_LATE The possible values are as follows: 'Y' - It is OK to call back even when it is already late. 'N' - It is not OK to call back when it is already late. This information is only passed from the external application to Oracle Utilities Network Management System (using the Trouble Calls Data Flow), and back to the external application (using the Callback Requests Data Flow). No other action is taken. |
CALLBACK_LATE_TIME | Y | DATE | Populated by the Callback Requests Data Flow from INC.CALLBACK_TIME (in the UTC time zone). This information is only passed from the external application to Oracle Utilities Network Management System (using the Trouble Calls Data Flow), and back to the external application (using the Callback Requests Data Flow). No other action is taken. |
CALLBACK_METHOD | N | number | The callback method requested (1‑phone, 2‑text, 3‑email) |
CALLBACK_REASON | Y | VARCHAR2(100) | This is used by the Generic IVR Adapter to indicate the source of the callback request. This will default to 'OMS'. |
CALLBACK_STATUS | Y | VARCHAR2(10) | Initially populated by the Callback Requests Data Flow as NULL; The field is repopulated by the external application (using pr_trouble_callback_responses stored procedure). The valid values are as follows: 'F' - Not Restored Callback 'R' - Restored Callback 'N' - Cancel Callback, unable to get a response The Callback Response Data Flow is responsible for sending the updated value to Oracle Utilities Network Management System. A remapped value is placed in INC.CALLBACK_STATUS. |
CALLBACK_TEXT | Y | VARCHAR2(32) | The Callback text number |
CALLBACK_TIME | Y | DATE | Initially populated by the Callback Requests Data Flow as NULL; The field could be repopulated (with time in the UTC time zone) by the external application (using pr_trouble_callback_responses stored procedure). The stored procedure defaults this field to the system date if no information was supplied by the external application. The Callback Response Data Flow is responsible for sending the updated value to Oracle Utilities Network Management System. The value is placed in INC.CB_CALL_TIME. |
CAUSE_CODE | Y | VARCHAR2(32) | This is used to relay back to customers the cause of an outage when a callback is performed. Populated by the Callback Requests Data Flow from JOBS.CAUSE when the useExternalCause rule is set to 'yes' in the SRS_RULES. |
CB_DETAIL_1 | Y | VARCHAR2(80) | Populated by the Callback Requests Data Flow from a column in the PICKLIST_INFO_UPD_TR database table. Column name is configured in the IVR_ADAPTER_CONFIG database table. |
CB_DETAIL_2 | Y | VARCHAR2(80) | Populated by the Callback Requests Data Flow from a column in the PICKLIST_INFO_UPD_TR database table. Column name is configured in the IVR_ADAPTER_CONFIG database table. |
CB_DETAIL_3 | Y | VARCHAR2(80) | Populated by the Callback Requests Data Flow from a column in the PICKLIST_INFO_UPD_TR database table. Column name is configured in the IVR_ADAPTER_CONFIG database table. |
CB_DETAIL_4 | Y | VARCHAR2(80) | Populated by the Callback Requests Data Flow from a column in the PICKLIST_INFO_UPD_TR database table. Column name is configured in the IVR_ADAPTER_CONFIG database table. |
CUSTOMER_ADDRESS | Y | VARCHAR2(255) | Populated by the Callback Requests Data Flow by concatenating INC.ADDR_BUILDING, INC.ADDRESS and INC.ADDR_CITY |
CUSTOMER_COMMENT | Y | VARCHAR2(255) | Populated by the Callback Requests Data Flow from INC.OP_COMMENT. |
CUSTOMER_COUNT | Y | NUMBER | Populated by the Callback Requests Data Flow from INC.USER_NAME. |
CUSTOMER_NAME | Y | VARCHAR2(75) | Populated by the Callback Requests Data Flow from INC.CUSTOMER_NAME. |
CUSTOMER_PHONE | Y | VARCHAR2(38) | Populated by the Callback Requests Data Flow from INC.CUSTOMER_PHONE. |
EVENT_CLS | Y | NUMBER(38) | Populated by the Callback Requests Data Flow from INC.EVENT_CLS. |
EVENT_IDX | Y | NUMBER(38) | Populated by the Callback Requests Data Flow from INC.EVENT_IDX. |
EXTERNAL_ID | Y | VARCHAR2(16) | Populated by the Callback Requests Data Flow from INC.EXTERNAL_ID. |
INCIDENT_NUMB | N | NUMBER(38) | Populated by the Callback Requests Data Flow from INC.NUMB. |
INCIDENT_TIME | Y | DATE | Populated by the Callback Requests Data Flow from INC.INPUT_TIME (in the UTC time zone). The Generic IVR Adapter uses this field as one of the criteria in purging the TROUBLE_CALLBACKS table for 'old' records. The TROUBLE_CALLBACKS table record is 'aged' based on the system date/time and the INCIDENT_TIME field. Any record older than a predefined number of days will be removed. See keepdbinfo on page 1-13 for more information. |
OUTAGE_DURATION | Y | NUMBER | Outage duration in seconds. Populated by the Callback Requests Data with the difference between JOBS.RESTORE_TIME and JOBS.BEGIN_TIME. |
PREMISE_ID | N | VARCHAR2(64) | Populated by the Callback Requests Data Flow from INC.CID. |
PROCESS_STATUS | Y | VARCHAR2(1) | Initially populated by the Callback Requests Data Flow as 'N', signifying that the record is a new callback Once the record was fetched by the external application (using pr_trouble_callback_requests stored procedure), the field is automatically updated by the stored procedure to 'I' signifying that the external system is currently processing the callback response. As soon as the external application successfully returns the callback response to the Generic IVR Adapter (using pr_trouble_callback_responses stored procedure), the field is updated to 'C', signifying that the external application has completed the processing of the callback response. This field is internally maintained by the Generic IVR Adapter. Below is a list of valid values for this field. 'N' - New Callback 'I' - In Processing Of Callback Response 'C' - Completed The Processing Of Callback Response The Generic IVR Adapter uses this field as one of the criteria in purging the TROUBLE_CALLBACKS table for 'old' records. Records with PROCESS_STATUS field = 'C' will be purged. |
SHORT_DESCRIPTION | Y | VARCHAR2(128) | Populated by the Callback Requests Data Flow from INC.SHORT_DESC This is the clue (e.g., 'Out') of the incident rather than the trouble code (e.g., '10000000'). 'Out' is short for 'All Power Out'. |
TROUBLE_CODE | Y | VARCHAR2(32) | Populated by the Callback Requests Data Flow from INC.COMPLAINT. This is the trouble code (e.g., '10000000') of the incident rather than the clue (e.g., 'Out'). 'Out' is short for 'All Power Out'. |
Parameter Name | Parameter Type | Description |
p_call.call_source_id | VARCHAR2(2) | Id unique to the call capture mechanism (always set to 2 for CCB, 3 for IVR - for example), Value will be prefixed to p_call.external_id field in this stored procedure. Used to allow NMS to maintain unique call ids (incidents.external_id) across multiple call taking systems submitting independent (overlapping) sets of external_ids. Generally an integer (to better support Interactive Voice Response systems) - but can be project specific. |
p_call.service_point_id | VARCHAR2(64) | Service point id. |
p_call.external_id | VARCHAR2(16) | Call external id unique ID from call capture system (CCB). To ensure uniqueness a given NMS implementation needs to agree on a fixed length field (12 characters for example). |
p_call. account_number | VARCHAR2(30) | Customer account number. |
p_call.trouble_code | VARCHAR2(32) | Call trouble code. Integer passed as a string - each character (0-9) indicates a specific selection (or 0 for non-selection) from each of 1 to 32 different trouble call categories. Project configurable. |
p_call.first_name | VARCHAR2(75) | Customer first name or full name (if customer name is passed in a single field). |
p_call.last_name | VARCHAR2(75) | Customer last name. |
p_call.phone | VARCHAR2(32) | Customer phone number. |
p_call.phone_area | VARCHAR2(8) | Customer phone area code. |
p_call.alt_phone | VARCHAR2(32) | Alternative/callback phone number. |
p_call.priority | VARCHAR2(4) | The same value as ces_customers.priority should be passed in. This is used to determine critical customer type. |
p_call.critical_flag | VARCHAR2(1) | Critical customer (Y/N) |
p_call.life_support_flag | VARCHAR2(1) | Life support flag (Y/N). |
p_call.call_id | VARCHAR2(32) | Call identifier (for example, 911 call id) - mapped to general_area. |
p_call.call_time | TIMESTAMP WITH TIME ZONE | Call capture time from external call capture system |
p_call.call_comment | VARCHAR2(255) | Comments |
p_call.call_taker | VARCHAR2(32) | Call taker id. |
p_call.call_type | VARCHAR2(8) | Call type. |
CC&B should leave this field empty. | ||
p_call.addr_building | VARCHAR2(10) | Building/block number. |
p_call.addr_street | VARCHAR2(255) | Street address or name of the first intersection street. |
p_call.addr_cross_street | VARCHAR2(255) | Name of the second intersection (cross) street. |
p_call.addr_city_state | VARCHAR2(45) | City and (optionally) state. |
p_call.drive_instr | VARCHAR2(180) | Driving instructions. |
p_call.meet_time | TIMESTAMP WITH TIME ZONE | Meet time. |
p_call.meet_type | NUMBER | Meet action code. Possible values: • 0 - for non-meet calls • 1 - create new meet • 2 - reschedule existing meet • 3- cancel existing meet |
p_call.group_by_name | VARCHAR2(127) | Optional control zone name for fuzzy calls. |
p_call.device_id | VARCHAR2(32) | Device alias. |
p_call.meter_id | VARCHAR2(32) | Meter number. |
p_call.trouble_queue | VARCHAR2(10) | Trouble queue (Tree Trimming, Underground, etc) |
p_call.trouble_location | VARCHAR2(255) | Trouble location. |
p_call.x_coord | NUMBER | X coordinate in the NMS electrical network model coordinate system (generally NOT lat/long). If not provided JMService will default to the coordinates for the supply_node from the point_coordinates table. |
p_call.y_coord | NUMBER | Y coordinate - match for X coordinate above. |
p_call.appt_type | NUMBER | Appointment type. |
p_call.appt_time | TIMESTAMP WITH TIME ZONE | Appointment time. |
p_call.appt_range | NUMBER | Appointment time window in minutes. |
p_call.callback_flag | NUMBER | Callback request flag. • 0 - callback has not been requested • 1 - restoration callback has been requested. • 4 - ERT callback has been requested • 5 - ERT and restoration callbacks have been requested |
p_call.callback_before_time | TIMESTAMP WITH TIME ZONE | Callback requested before this time. |
p_call.callback_late_flag | VARCHAR2(1) | Callback late ok flag (Y/N) |
p_call.intersection_cls | NUMBER | If p_call.service_point_id is NOT null this field is ignored. If not null and p_call.service_point_d is null interpreted as att_street_intersection.h_cls. Used to help identify an intersection (when paired with p_call.intersection_idx) |
p_call.intersection_idx | NUMBER | If p_call.service_point_id is NOT null this field is ignored. If not null and p_call.service_point_id is null interpreted as att_street_intersection.h_idx - to help identify an intersection (when paired with p_call.intersection_cls). |
p_call.cancel_flag | VARCHAR2(1) | Call cancel flag (Y/N). |
p_call.update_flag | NUMBER | If 0 then this is a new call, otherwise this is an update to an existing call. |
p_call.udf1 | VARCHAR2(255) | User-defined call field 1. |
p_call.udf2 | VARCHAR2(255) | User-defined call field 1. |
p_call.udf3 | VARCHAR2(255) | User-defined call field 1. |
p_call.udf4 | VARCHAR2(255) | User-defined call field 1. |
p_call.udf5 | VARCHAR2(255) | User-defined call field 1. |
p_err_no | NUMBER | Error code. In case of successful execution 0 is returned. |
p_err_msg | VARCHAR2(200) | Internal error message. |
p_cust.serv_point_id | VARCHAR2(64) | Service point id. |
p_cust.premise_id | NUMBER | Service location (premise id). |
p_cust.account_number | VARCHAR2(30) | Customer account number. |
p_loc.city | VARCHAR2(200) | City. |
p_loc.state | VARCHAR2(30) | State. |
p_loc.street1 | VARCHAR2(200) | Street name. This field is used in both street intersection search and street segment search. |
p_loc.street2 | VARCHAR2(200) | Second street name for street intersection search. |
p_loc.block_number | NUMBER | Block number for street segment search. |
p_fuzzy.external_id | VARCHAR2(200) | Call external id. |
p_fuzzy.call_id | VARCHAR2(200) | Call identifier (for example, id for 911 calls). |
p_fuzzy.caller_name | VARCHAR2(200) | Caller name. |
p_fuzzy.caller_phone | VARCHAR2(200) | Caller phone number. |
p_custom.xxx | Implementation-defined search parameters. | |
p_cmp_days | NUMBER | If greater than 0 then switching plans completed within specified number of days in the past will be returned in addition to current and future switching plans. |
p_jobs | nms_cursor | Returned jobs information. |
p_err_msg | VERCHAR2(200) | Internal error message. |
Field Name | Field Type | Description |
serv_point_addr | VARCHAR2(200) | Service point address |
event_idx | NUMBER | Event index. |
begin_time | TIMESTAMP WITH TIME ZONE | Outage begin time. |
est_rest_time | TIMESTAMP WITH TIME ZONE | Estimated restoration time (ERT). |
est_rest_time_source | VARCHAR2(1) | ERT source. Possible values: • N - no ERT. • I - Initial ERT. • C - crew‑entered via mobile interface. • S - ERT calculated by Storm Management. • O - ERT calculated by Storm Management (crew on-site). • P - Non-publisher ERT. • G - ERT override is in effect. • D - ERT delay is in effect. • U - User‑entered via applications or tools (for example, Work Agenda, Event Details, or Crew tools) other than Storm Management. • m - Minimum ERT is not reached. The ERT is below the set threshold for minimum ERT. • M - Maximum ERT exceeded. The Storm Management calculated ERT is beyond a set threshold for maximum ERT. • W - System-wide default ERT. • A - Auto-extended ERT. • E - ERT generated by Storm Management while a crew is en route to the event. |
restore_time | TIMESTAMP WITH TIME ZONE | Outage restoration time. |
cust_out | NUMBER | Number of customers affected by the outage. |
comments | VARCHAR2(255) | Operator's comment. Note some customers increase this to max allowed (4k). |
alarm_state | VARCHAR2(32) | Outage state. |
alarm_state_desc | VARCHAR2(80) | Description of the outage state. |
trouble_location | VARCHAR2(255) | |
status | NUMBER | Job type. Possible values: • 0 - Fuzzy outage. • 1 - Probable/predicted service outage. • 2 - Probable/predicted device outage. • 3 - Real service outage. • 4 - Real device outage. • 7 - Non-outage. • 8 - Critical meet. • 9 - Future meet. • 10 - Confirmed service outage. • 11 - Confirmed secondary outage. • 13 - Probable/predicted momentary outage. • 14 - Real momentary outage. • 15 - Planned outage. • 16 - Non-electric event. • 17 - Master switching job. • 18 - Fault current event. • 19 - Optimization event. • 20 - Active Network Management job. • 21 - Protection Scheme job. |
device_class | VARCHAR2(32) | Outage device class name (e.g., fuse) |
trouble_code | VARCHAR2(128) | Trouble code. |
feeder_name | VARCHAR2(32) | Feeder name. |
cause | VARCHAR2(32) | Outage cause. |
description | VARCHAR2(128) | Job description. |
referral_group | VARCHAR2(32) | Referral group. |
last_update_time | TIMESTAMP WITH TIME ZONE | Timestamp of the latest update to the outage record. |
udf1 | VARCHAR2(255) | Job user-defined field 1. |
udf2 | VARCHAR2(255) | Job user-defined field 2. |
udf3 | VARCHAR2(255) | Job user-defined field 3. |
udf4 | VARCHAR2(255) | Job user-defined field 4. |
udf5 | VARCHAR2(255) | Job user-defined field 5. |
external_id | VARCHAR2(16) | Call external id. |
call_id | VARCHAR2(32) | Call identifier (for example, id for 911 calls). |
call_time | TIMESTAMP WITH TIME ZONE | Call time. |
Address | VARCHAR2(255) | Address for the call. |
short_desc | VARCHAR2(256) | Trouble code. |
Comments | VARCHAR2(255) | Comments. |
cust_name | VARCHAR2(75) | Customer/caller name. |
Status | VARCHAR2(1) | Call status. Possible values (other values can exist in NMS but they would not be returned by this procedure):"Y - active call "N - inactive/restored call "C - canceled call "E - call belongs to canceled job |
udf1 | VARCHAR2(255) | Call user-defined field 1. |
udf2 | VARCHAR2(255) | Call user-defined field 2. |
udf3 | VARCHAR2(255) | Call user-defined field 3. |
udf4 | VARCHAR2(255) | Call user-defined field 4. |
udf5 | VARCHAR2(255) | Call user-defined field 5. |
p_custom | Implementation-defined search parameters. | |
p_sw_plans | nms_cursor | Returned switching plan information. |
p_err_no | NUMBER | Error code In case of successful execution 0 is returned. |
p_err_msg | VARCHAR2(200) | Error message. |
plan_class | VARCHAR2(32) | Switching plan type (planned, emergency, ….). |
plan_number | NUMBER | Switching plan number. |
start_date | TIMESTAMP WITH TIME ZONE | Switching plan start date. |
end_date | TIMESTAMP WITH TIME ZONE | Switching plan end date. |
State | VARCHAR2(32) | Switching plan state. |
work_district | VARCHAR2(500) | |
work_location | VARCHAR2(500) | |
work_description | VARCHAR2(500) | |
p_trouble_codes | nms_cursor | Returned trouble code information. |
p_err_msg | VARCHAR2(200) | Error message |
group_name | VARCHAR2(20) | Trouble code group name |
group_order | NUMBER | Trouble code group order |
code_name | VARCHAR2(40) | Trouble code name |
code_num | NUMBER | Trouble code number within its group |
short_desc | VARCHAR2(25) | Short description of the trouble code |
description | VARCHAR2(70) | Long description of the trouble code |
Parameter | Direction | Data Type | Field Name | Comment |
p_premise_id | In | VARCHAR2 | PREMISE_ID | The value is inserted as is. |
p_trouble_code | In | VARCHAR2 | TROUBLE_CODE | Defaults to '1' followed by a certain number of '0'. If no value was supplied. The total length of the string is the total number of distinct groups in the SRS_TROUBLE_CODES table. |
p_callback_ind | In | VARCHAR2 | CALLBACK_INDICATOR | The possible values are as follows: '0' - callback not requested '1' - callback requested Defaults to '1' if no value is supplied. 'Y' is translated to '1'. 'N' is translated to '0'. |
p_call_time | In | DATE | CALL_TIME | Defaults to the database system date if no value is supplied. When supplied, time should be in the UTC time zone. |
p_call_taker_id | In | VARCHAR2 | CALL_TAKER_ID | The value is inserted as is. |
p_alternate_phone | In | VARCHAR2 | ALTERNATE_PHONE | The value is inserted as is. |
p_customer_comment | In | VARCHAR2 | CUSTOMER_COMMENT | The value is inserted as is. |
p_customer_phone | In | VARCHAR2 | CUSTOMER_PHONE | The value is inserted as is. |
p_customer_name | In | VARCHAR2 | CUSTOMER_NAME | The value is inserted as is. |
p_customer_address | In | VARCHAR2 | CUSTOMER_ADDRESS | The value is inserted as is. |
p_customer_city_state | In | VARCHAR2 | CUSTOMER_CITY_STATE | The value is inserted as is. |
p_customer_priority | In | VARCHAR2 | CUSTOMER_PRIORITY | The value is inserted as is. |
p_external_id | In | VARCHAR2 | EXTERNAL_ID | The value is inserted as is. |
p_device_alias | In | VARCHAR2 | DEVICE_ALIAS | The value is inserted as is. |
p_check_cutoff_ind | In | VARCHAR2 | CHECK_CUTOFF_IND | The possible values are as follows: 'Y' - check if the customer is disconnected 'N' - do not perform checking. Defaults to 'N' if no value is supplied |
p_callback_late_ind | In | VARCHAR2 | CALLBACK_LATE_IND | The possible values are as follows: 'Y' - It is OK to call back even when it is already late. 'N' - It is not OK to call back when it is already late. Defaults to 'N' if no value is supplied |
p_callback_before_time | In | DATE | CALLBACK_BEFORE_TIME | The value is inserted as is. When supplied, time should be in the UTC time zone. |
p_trouble_queue | In | VARCHAR2 | TROUBLE_QUEUE | The value is inserted as is. |
p_meter_id | In | VARCHAR2 | METER_ID | The value is inserted as is. |
p_supply_id | In | NUMBER | SUPPLY_ID | The value is inserted as is. |
p_cust_phone_area | In | VARCHAR2 | CUST_PHONE_AREA | The value is inserted as is. |
p_cust_last_name | In | VARCHAR2 | CUST_LAST_NAME | The value is inserted as is. |
p_general_area | In | VARCHAR2 | GENERAL_AREA | The value is inserted as is. |
p_cust_order_num | In | VARCHAR2 | CUST_ORDER_NUM | The value is inserted as is. |
p_drv_inst | In | VARCHAR2 | DRV_INST | The value is inserted as is. |
p_cust_life_support | In | VARCHAR2 | CUST_LIFE_SUPPORT | The value is inserted as is. |
p_cust_call_cancel | In | VARCHAR2 | CUST_CALL_CANCEL | The value is inserted as is. |
p_short_desc | In | VARCHAR2 | SHORT_DESC | The value is inserted as is. |
p_addr_building | In | VARCHAR2 | ADDR_BUILDING | The value is inserted as is. |
p_meet_time | In | DATE | MEET_TIME | The value is inserted as is. When supplied, time should be in the UTC time zone. |
p_meet_type | In | NUMBER | MEET_TYPE | The value is inserted as is. |
p_groupable | In | NUMBER | GROUPABLE | The value is inserted as is. |
p_clue | In | NUMBER | CLUE | The value is inserted as is. |
p_combine_pri | In | NUMBER | COMBINE_PRI | The value is inserted as is. |
p_cust_status | In | NUMBER | CUST_STATUS | The value is inserted as is. |
p_cust_intr_x | In | NUMBER | CUST_INTR_X | The value is inserted as is. |
p_cust_intr_y | In | NUMBER | CUST_INTR_Y | The value is inserted as is. |
p_cust_intersect_cls | In | NUMBER | CUST_INTERSECT_CLS | The value is inserted as is. |
p_cust_intersect_idx | In | NUMBER | CUST_INTERSECT_IDX | The value is inserted as is. |
p_cust_intersect_ncg | In | NUMBER | CUST_INTERSECT_NCG | The value is inserted as is. |
p_update_existing_inc | In | NUMBER | UPDATE_EXISTING_INC | The value is inserted as is. |
p_fuzzy_ncg_cls | In | NUMBER | FUZZY_NCG_CLS | The value is inserted as is. |
p_fuzzy_ncg_idx | In | NUMBER | FUZZY_NCG_IDX | The value is inserted as is. |
p_group_by_name | In | VARCHAR2 | GROUP_BY_NAME | The value is inserted as is. |
p_cust_critical | In | VARCHAR2 | CUST_CRITICAL | The value is inserted as is. |
p_related_evt_cls | In | NUMBER | RELATED_EVT_CLS | The value is inserted as is. |
p_related_evt_idx | In | NUMBER | RELATED_EVT_IDX | The value is inserted as is. |
p_related_evt_app | In | NUMBER | RELATED_EVT_APP | The value is inserted as is. |
p_x_ref | In | NUMBER | X_REF | The value is inserted as is. |
p_y_ref | In | NUMBER | Y_REF | The value is inserted as is. |
p_call_type | In | VARCHAR2 | CALL_TYPE | The value is inserted as is. |
p_cust_phone_update | In | VARCHAR2 | CUST_PHONE_UPDATE | The value is inserted as is. |
p_trouble_loc | In | VARCHAR2 | TROUBLE_LOC | The value is inserted as is. |
p_appt_type | In | VARCHAR2 | APPT_TYPE | The value is inserted as is. |
p_appt_time | In | DATE | APPT_TIME | The value is inserted as is. When supplied, time should be in the UTC time zone. |
p_appt_range | In | NUMBER | APPT_RANGE | The value is inserted as is. |
p_cust_device_ncg | In | NUMBER | CUST_DEVICE_NCG | The value is inserted as is. |
p_cust_device_partition | In | NUMBER | CUST_DEVICE_PARTITION | The value is inserted as is. |
p_err_premise_id | Out | VARCHAR2 | VARCHAR2(80) | The erroneous premise ID input parameter |
p_err_oracle_error | Out | VARCHAR2 | VARCHAR2(80) | Oracle's error message. |
Parameter | Direction | Cursor |
p_callback_requests | In/Out | CALLBACK_CURSOR |
Field Name from the Cursor | Data Type | Field Name from TROUBLE_CALLBACKS | Comments |
EVENT_CLS | NUMBER(38) | TCB.EVENT_CLS | Event class |
EVENT_IDX | NUMBER(38) | TCB.EVENT_IDX | Event index |
INCIDENT_NUMB | NUMBER(38) | TCB.INCIDENT_NUMB | Incident number |
PREMISE_ID | VARCHAR2(50) | TCB.PREMISE_ID | Premise id |
CUSTOMER_NAME | VARCHAR2(75) | TCB.CUSTOMER_NAME | Customer name |
CUSTOMER_PHONE | VARCHAR2(38) | TCB.CUSTOMER_PHONE | Customer phone |
CUSTOMER_ADDRESS | VARCHAR2(255) | TCB.CUSTOMER_ADDRESS | Customer address |
ALTERNATE_PHONE | VARCHAR2(38) | TCB.ALTERNATE_PHONE | Customer alternate phone number |
TROUBLE_CODE | VARCHAR2(32) | TCB.TROUBLE_CODE | This is the trouble code (e.g., '10000000') of the incident rather than the clue (e.g., 'Out'). 'Out' is short for 'All Power Out'. |
SHORT_DESCRIPTION | VARCHAR2(128) | TCB.SHORT_DESCRIPTION | This is the clue (e.g., 'Out') of the incident rather than the trouble code (e.g., '10000000'). 'Out' is short for 'All Power Out'. |
CUSTOMER_COMMENT | VARCHAR2(255) | TCB.CUSTOMER_COMMENT | Call-taker Comments. Comments provided by the customer or call-taker about the incident. |
INCIDENT_TIME | DATE | TCB.INCIDENT_TIME | Input time of call (in the UTC time zone). The input time of the incident. |
EXTERNAL_ID | VARCHAR2(16) | TCB.EXTERNAL_ID | Unique call identifier. The unique identifier for the incident. |
CALL_TAKER_ID | VARCHAR2(32) | TCB.CALL_TAKER_ID | Call-taker user name. The name of the call-taker or interface that created the call. |
CALLBACK_LATE | VARCHAR2(1) | TCB.CALLBACK_LATE | The possible values are as follows: 'Y' - It is OK to call back even when it is already late. 'N' - It is not OK to call back when it is already late. |
CALLBACK_LATE_TIME | DATE | TCB.CALLBACK_LATE_TIME | When supplied, time should be in the UTC time zone. |
CALLBACK_REASON | VARCHAR2(100) | TCB.CALLBACK_REASON | This will default to 'OMS'. |
CAUSE_CODE | VARCHAR2(32) | TCB.CAUSE_CODE | Cause code of the event related to the callback. |
Parameter | Direction | Data Type | Field Name | Comments |
p_incident_numb | In | NUMBER | INCIDENT_NUMB | Incident Number. Either this or the p_external_id parameter has to be supplied |
p_external_id | In | VARCHAR2 | EXTERNAL_ID | External Id. Either this or the p_incident_numb parameter has to be supplied |
p_premise_id | In | VARCHAR2 | PREMISE_ID | Premise Id. |
p_callback_status | In | VARCHAR2 | CALLBACK_STATUS | The valid values are as follows: 'F' - Not Restored Callback 'R' - Restored Callback 'N' - Cancel Callback, unable to get a response |
p_callback_time | In | DATE | CALLBACK_TIME | Defaulted to the system date if no value was supplied. When supplied, time should be in the UTC time zone. |
p_err_incident_numb | Out | NUMBER | The erroneous incident number input parameter | |
p_err_external_id | Out | VARCHAR2 | The erroneous external ID input parameter | |
p_err_premise_id | Out | VARCHAR2 | The erroneous premise ID input parameter | |
p_err_oracle_error | Out | VARCHAR2 | Oracle's error message |
Parameter | Direction | Data Type | Comments |
p_in_premise_id | In | VARCHAR2 | Premise ID input parameter with a corresponding entry in CES_CUSTOMERS.SERV_LOC_ID. |
p_out_event_class | Out | NUMBER | Event class output parameter. |
p_out_event_index | Out | NUMBER | Event index output parameter. |
p_out_outage_status | Out | VARCHAR2 | This is an abbreviation of the current state of the event, for instance, 'NEW', 'ASN', 'CMP', an so on. |
p_ out_outage_start_time | Out | DATE | The time of the lead call of the job. When supplied, time should be in the UTC time zone. |
p_ out_first_dispatch_time | Out | DATE | The time the first crew was dispatched (in the UTC time zone). |
p_ out_est_restore_time | Out | DATE | The last estimate of restoration time (in the UTC time zone). |
p_ out_est_restore_time_src | Out | VARCHAR2 | The source of the ERT of the event. Possible values are as follows: 'N' - none (no ERT) 'S' - Storm Management 'P' - Storm Management "non-published global ERT" 'O' - Storm Management "onsite ERT" 'G' - Storm Management "published global ERT" D' - Storm Management "published global ERT delay" 'C' - User-entered (assumed to have been provided by the crew) 'I' - Initial default ERT 'M' - Storm Management ERT is further in the future then allowed |
p_ out_crew_arrival_time | Out | DATE | The time when the crew arrived on location (in the UTC time zone). |
p_ out_completion_time | Out | DATE | The time the event has been completed (in the UTC time zone). This implies power restoration, the crew(s) are gone, and the event is completed in the Event Details window. |
p_ out_restoration_time | Out | DATE | The time that power has been restored (in the UTC time zone). |
p_ out_case_note | Out | VARCHAR2 | Comment |
p_ out_status | Out | NUMBER | Condition status |
p_ out_active | Out | VARCHAR2 | Possible values are as follows: 'Y' - Outage Is Active 'N' - Outage Is Not Active |
p_out_alias | Out | VARCHAR2 | The device alias. |
P_out_event_type | Out | VARCHAR2 | Possible values are as follows: OUT NON MEET PLAN SWP |
P_out_feeder_name | Out | VARCHAR2 | The name of the feeder. |
P_out_cause | Out | VARCHAR2 | The cause of the outage if the SRS Rule useExternalCause is on. |
P_out_num_calls | Out | NUMBER | The number of calls. |
P_out_num_cust_out | Out | NUMBER | The number of customers out. |
P_err_premise_id | Out | VARCHAR2 | |
P_err_oracle_error | Out | VARCHAR2 |
Option | Description |
-ami | Submit AMI Last Gasp (Power Down) inputs for the meters specified by the -input parameter. |
-ami_up | Submit AMI Power Up (Restore) inputs for the meters specified by the -input parameter. |
-max number | Maximum number of calls to enter. |
-ivr | Write calls to trouble_calls table for IVR adapter. |
-time | Add input_time with current time. |
-blanksok | Blank lines in call record are acceptable. |
-package number | Number of calls to send to JMS at a time. Default: 10. |
-interval seconds | Seconds to delay between calls.Defaults to 5. Also, it can take floating point values such as 2.5 to sleep 2 and a half seconds between call batches. |
-divide number | Number to divide <WAIT> times by. |
-tilde | Use the tilde in column 0 as a call separator. |
-debug | Enable runtime debugging. |
-input filename | Filename containing trouble call data. Required. |
