Feeder Load Summary Table Columns
The Feeder Load Management Summary table displays the following columns.
• Substation: The substation name.
• Feeder: The feeder name. This column displays a yellow background for feeders with abnormal data quality or/and data source for any of the phases. See Data Source and Data Quality on page 17-36 and Feeder/Device Condition Names and Colors on page D-7 for more details.
• Feeder Condition: Violation or warning (if any) on a feeder. When multiple violations/warnings occur on a feeder, this column shows the highest-level violation. See Feeder Conditions on page 17-8 for more information.
• Date/Time: Date and time for the displayed feeder condition.
• Phase: The phase with the maximum capacity utilization.
• Util %: Feeder head utilization capacity.
• Amps: Electrical current on the phase with the maximum capacity utilization.
• kW: Active power on the phase with the maximum capacity utilization. Positive values indicate power flowing from substation to load. Negative values indicate power flowing from load (DERs) to substation. Hidden by default.
• kVAr: Reactive power on the phase with the maximum capacity utilization. Positive values indicate power flowing from substation to load. Negative values indicate power flowing from load (DERs) to substation. Hidden by default.
• kVA: Apparent power on the phase with the maximum capacity utilization.
• kV: Voltage on the phase with the maximum capacity utilization.
• Updated: Date and time of the last update for the feeder (only for Earliest Alarms and Worst Case Loads Views).
• Score: EDA score of the feeder at the time of the condition.
• # Alarms: Total number of alarms on the feeder at the time.
• PF Mode: The type of solution used to solve the feeder (kVA or Power Flow).
• FLISR: The mode that FLISR is set to (Disabled, Manual, Automatic).
• FLM: The FLM status for the feeder (Forecasting, Real-Time, Disabled).
• Optimization: The Optimization status (Enabled, Disabled).
• FLA: The mode that FLA is set to (Enabled/Disabled).
• Optimization Objective: The objective for Optimization (Loss Minimization, Conservation Voltage Reduction, Power Factor Correction, or None).
• Protection Schemes: Displays whether dynamic protection schemes are disabled or in manual or automatic mode.
• Protection Schemes Mode: Displays whether protection scheme steps appear before or after the restoration switch step in Suggested Switching and FLISR switching plans.
• Feeder Type: the feeder type.
• PF History: the status of PF History (Enabled/Disabled).
Data Source and Quality Information Balloon
The data source and data quality balloon ()displays feeder head data source and data quality information for the selected row. See Data Source and Data Quality on page 17-36 for more information.
Feeder Conditions
Feeder Load Management displays feeder conditions, including warning and violations, in the Feeder Condition columns of the Feeder Load Summary and the Feeder Load Management Tool. Feeders that present no abnormal conditions at all are reported as Normal.
