Using the Alarm Configuration Tab
The Alarm Configuration tab allows you to define priorities, colors, and sounds for each alarm type. This controls the behavior for future alarms when they appear in the Alarms List tool (see Using the Alarm Displays on page 2-138).
The Alarm Configuration tab is comprised of pages for different alarm configuration options. The pages are provided in sub‑tabs, which are described in the following sections.
Understanding the Behavior Tab
The Behavior tab consists of:
• A table containing the configuration rules (definitions) for all alarms and buttons for working with the alarm definitions.
• Alarm Definition Preview Panes
• The Active Alarms table displays how a selected alarm definition would look in the Web Workspace Alarms list (See Understanding the Alarms List on page 2-138).
• The Alarm History table displays how a selected alarm definition would look in the Web Workspace Alarm History (Understanding the Alarm History List on page 2-146).
