Resources
POST /dmg‑rest/event‑update/{event}
Update all active customer damage reports for the passed event, using the passed action.
Parameters
Name
Type
Description
event
required
path[integer]
The event index to update.
action
query[string
the action string (like assessed, failed, and so on)
Error Response
• Code: 401 Unauthorized
User is not authorized to perform the request.
• Code: 500 Internal Server Error
Unspecified error has occurred.
GET /dmg-rest/reports
Retrieves damage reports or given query parameters.
Supported query types:
• Location - returns damage reports within the given radius from the specified location. Parameters lat, long, and rad are required for this query type.
• Patrol - returns damage reports associated with the given patrol event. Parameter patrol is request for this query type.
• Event - returns damage reports associated with the given event. Parameter event is request for this query type.
Note: Parameters from different query types cannot be mixed (for example, it is not possible to request damage reports for a patrol event which are location near specific point).
Parameters
Name
Type
Description
lat
query[floating-point]
Latitude of the location.
long
Longitude of the location.
rad
Radius in meters.
event
query[integer]
Event index.
patrol
query[integer]
Patrol event index.
device
query[string]
Device handle.
Success Response
• Code: 200
Content: Array of JSON objects representing damage reports.
Error Response
POST /dmg-rest/reports
Creates new damage report.
Parameters
Name
Type
Description
unnamed
required
data1
JSON representation of a damage report.
action
query[string]
State transition action when saving damage report (for example, assess).
1 'data' parameters represent the body of a POST or PUT request. Such parameters do not have a name thus 'unnamed' in the list of parameters.
Success Response
• Code: 201 Created
Content: JSON representation of the created damage report.
Error Response
GET /dmg-rest/reports/config/{cfg}
Parameters
Name
Type
Description
cfg
path[string]
Type of configuration items to return.
Available types of configuration items:
• repair-times: damage assessment repair time configuration from the DAMAGE_REPAIR_TIMES_VIEW database view
• asset_statuses: records from the MESSAGE_CODE_LOOKUP where MESSAGE_TOPIC equals 'DA_ASSET_STATUS'
• asset_conditions: records from the MESSAGE_CODE_LOOKUP where MESSAGE_TOPIC equals 'DA_ASSET_CONDITION'
• phases: phase labels from PHASE_BITMAP_LOOKUP table
Success Response
• Code: 200
Array of JSON objects representing requested configuration items.
• Code: 204 No Content.
Nothing found for the requested configuration type.
Error Response
GET /dmg-rest/reports/{id}
Retrieves existing damage report by id.
Parameters
Name
Type
Description
id
required
path[integer]
Damage report identifier.
Success Response
• Code: 200
Content: JSON or XML representation of a damage report.
Error Response
• Code: 204
No Content. Damage report with the given identifier were not found.
POST /dmg-rest/reports/{id}
Updates existing damage report.
Parameters
Name
Type
Description
id
required
path[integer]
action
query[string]
unnamed
required
data
Success Response
• Code: 200
Content: JSON representation of a damage report.
Error Response
GET /dmg-rest/reports/{id}/attachments/{att_id}
Retrieves content of an existing damage report attachment.
Parameters
Name
Type
Description
id
required
path[integer]
att_id
required
path[string]
Attachment name/identifier.
w
query[string]
If image, reduce width to w pixels.
h
query[string]
If image, reduce height to h pixels.
Success Response
• Code: 200
Content: Binary attachment data (e.g., image)
Error Response
• Code: 204
No Content. Requested attachment does not exist.
PUT /dmg-rest/reports/{id}/attachments/{att_id}
Uploads contents of a damage report attachment.
Note: This API only uploads the binary attachment data to the server. The list of attachments is part of the damage report itself.
Parameters
Name
Type
Description
id
required
path[integer]
att_id
required
path[string]
unnamed
required
data
Attachment data.
Success Response
• Code: 201 Created
Error Response
DELETE /dmg-rest/reports/{id}/attachments/{att_id}
Deletes a damage report attachment.
Parameters
Name
Type
Description
id
required
path[integer]
att_id
required
path[string]
Success Response
Error Response
GET /dmg-rest/reports/required-parts
Retrieves list of required parts and materials which are configured in NMS.
Parameters
None.
Success Response
• Code: 200
Content: Array of JSON objects representing all known required parts
Error Response
GET /mobile/application/{name}/{arch}
Returns the latest version of the application for the given Application Name and Architecture in .zip format.
Parameters
Name
Type
Description
name
path[string]
Name of the application (OMA).
arch
path[string]
Architecture of the application. Can be one of these values: ANDROID, IOS, WIN10, BROWSER.
Response
• Code: 200
The return data will be the application in .zip format. If there is no version available matching the app Name and App Architecture, an exception is returned.
GET /mobile/application/{name}/{arch}/{version}
Returns the application for the given Application Name, Application version and Architecture in .zip format.
Parameters
Name
Type
Description
name
path[string]
arch
path[string]
version
path[integer]
Version of the application.
Response
• Code: 200
The return data will be the application in .zip format. If there is no application matching the app Name, app Version and App Architecture, an exception is returned.
GET /mobile/application-version/{name}/{arch}
Returns the latest version number of the application for the given Application Name and Architecture.
Parameters
Name
Type
Description
name
path[string]
arch
path[string]
Response
• Code: 200
The return data will be the latest application version number. If there is no version available matching the app Name and App Architecture, a -1 is returned.
GET /mobile/application-versions/{name}/{arch}
Returns a list of available version numbers of the application for the given Application Name and Architecture.
Parameters
Name
Type
Description
name
path[string]
arch
path[string]
Response
• Code: 200
The return data will be a list of integers for the version numbers of the application that are available. If there is no version available matching the app Name and App Architecture, an empty list is returned.
GET /mobile/attachments/{report-type}/{report-id}/{attachment-id}
Get attachment from the nms_attachments table for the given report.
Parameters
Name
Type
Description
report-type
path[string]
Report type to get attachment for; for example, DA or TE.
report-id
required
path[integer]
Report index to get attachment for
attachment-id
required
path[string]
Attachment ID of requested attachment.
w
optional
query[Integer]
If image, reduce the width to this value, if not provided, no reduction.
h
optional
query[Integer]
If image, reduce the height to this value, if not provided, no reduction.
Success Response
Content: byte[] of the attachment data
• Code: 200
Content: The return value will be the attachment.
Error Response
• Code: 500 Unspecified service error has occurred.
Content: May describe the issue encountered.s
PUT /mobile/attachments/{report-type}/{report-id}/{attachment-id}
Put a new attachment from the nms_attachments table for the given report.
Parameters
Name
Type
Description
report-type
path[string]
report-id
required
path[integer]
attachment-id
required
path[string]
Attachment ID of requested attachment. Must be unique for the given report ID.
uri
optional
query[uri]
URI to use for a link attachment
desc
optional
query[string]
Description to use for the attachment.
data[byte[]]
Data used for the attachment. Not used for link attachments.
Response
• Content: Identifier of the created or updated attachment.
• Code: 201 The attachment was successfully saved
Content may describe the issue encountered.
DELETE /mobile/attachments/{report-type}/{report-id}/{attachment-id}
Delete an attachment from the nms_attachments table for the given report.
Parameters
Name
Type
Description
report-type
path[string]
Report type to delete attachment for; for example, DA or TE.
report-id
required
path[integer]
Report index to delete attachment for
attachment-id
required
path[string]
Attachment ID of attachment to delete.
Success Response
• Code: 204 The request was completed.
Error Response
POST /mobile/condition/{class}
Create a condition with the given class, status, and text for the given device.
Parameters
Name
Type
Description
class
path[string]
Name of the class of conditions
status
query[integer]
Status of the class
dev-class
query[integer]
Handle Class number of the device
dev-index
query[integer]
Handle Index number of the device
text
path[string]
Text to be saved with the condition
phases
optional
query[integer]
Phases of device to apply the condition to. Defaults to 0.
node
optional
query[integer]
Phases of device to apply the condition to. Defaults to "0.0".
external-id
optional
query[string]
External ID to give the condition.
ignore-authority
optional
query[boolean]
Ignore checking for user authority when creating the condition. Defaults to True
as-user
optional
query[string]
User to do the API call as. The calling user must have "Allow as-user Parameter" mobile permission.
Success Response
• Code: 200
Returns the condition index of the new condition created.
GET /mobile/condition/{class}/{id}
Return condition details given the condition class and id.
Parameters
Name
Type
Description
class
required
path[string]
Condition class name
id
required
path[integer]
Condition index
Success Response
• Code: 200
Content: Condition details including handle, affected device handle, node, who created, class name, partition, when created, condition status, phases, ncg, x/y coordinates, application string, text, condition specific data, and external id.
Error Response
DELETE /mobile/condition/{class}/{id}
Deletes the given condition.
Parameters
Name
Type
Description
class
required
path[string]
id
required
path[integer]
Condition index
phases
optional
query[integer]
ignore-authority
optional
query[boolean]
Ignore checking for user authority when creating the condition. Defaults to True.
as-user
optional
query[string]
Success Response
• Code: 200
Content: None.
PUT /mobile/condition/{class}/{id}/{status}
Updates the given condition's status to the given status.
Parameters
Name
Type
Description
class
path[string]
Class Name of the condition
id
path[integer]
Id of the condition
status
path[integer]
The new status of the condition
as-user
optional
query[string]
Response
• Code: 200:
Content: None.
PUT /mobile/condition/{class}/{id}/text/{text}
Updates the text value of a given condition.
Parameters
Name
Type
Description
class
required
path[string]
id
required
path[integer]
Condition index
text
required
path[string]
Text value to update to condition
as-user
optional
query[string]
Success Response
• Code: 200
Content: None.
Error Response
Error Response
GET /mobile/conditions
Retrieves conditions for given geographical area.
Parameters
Name
Type
Description
lat1
required
Latitude of the top left corner of the area
lat2
required
Latitude of the bottom right corner of the area.
long1
required
Longitude of the top left corner of the area
long2
required
Longitude of the bottom right corner of the area
qt
optional
query[string]
Query type.
Valid values:
• da: damage reports
• event: events
• incident: calls and other incidents
• truck: truck dispatch locations
All conditions are returned if this parameter is not provided.
Success Response
• Code: 200
Content: Array of JSON objects representing conditions.
Error Response
GET /mobile/conditions/{class}
Returns a list of conditions for the requesting authentication user name of the given condition class.
Parameters
Name
Type
Description
class
path[string]
Name of the class of conditions.
as-user
optional
query[string]
Query for conditions created by the specified user instead of the authentication user.
Response
• Code: 200
The return data will be a list of conditions
GET /mobile/conditions/device/{handle}
Returns a list of conditions on the specified device handle
Parameters
Name
Type
Description
handle
required
path[hande]
Handle of the device to get conditions for; for example, 148.1001.
Response
• Code: 200
The return data will be a list of conditions.
PUT /mobile/confirm-services
Update service and secondary events for the given list of services.
Parameters
Name
Type
Description
action
required
query[service, secondary, restore, groupable]
Action to perform on the list of customer updates.
crew
optional
query[integer]
Crew key of the crew to be assigned to newly created events.
as-user
optional
query[string]
updates
required
data[updates]
A list of customer service updates.
Example
[{"cust_id":"2001637-2001637-2001637","address":"10586 MOGADORE AVE NW, Lake Twp., OH, 44685","ctype":"","comment":"confirmed outage","device":{"class_number":207,"app":0,"instance_number":2217},"event":{"class_number":800,"app":0,"instance_number":2750},"bitmask":0}]
Success Response
• Code: 200
Content: OK
Error Response
GET /mobile/confirm-services/{handle}
Get a list of customers with secondary and service outage details for the given device or event handle.
Parameters
Name
Type
Description
handle
required
path[Handle string]
Handle of a device or event to get the customers for.
max-supply-nodes
optional
query[integer]
Maximum number of supply nodes to return the customer list from. Defaults to 100.
Response
• Code: 200
The return value will be a object of customer IDs with a list of customer details. The details will include one for the customerId and additional customer details is the customer is involved with an existing service or secondary event.
• Code: 204
No customers for the given device or event handle
• Code: 500
GET /mobile/control-zones
Retrieves list of control zones NMS.
Parameters
None.
Success Response
• Code: 200
Content: Array of JSON objects representing all NMS control zones
Error Response
GET /mobile/create-new-account
Creates new account with the specified username and password. The server checks whether the provided user key is valid and have not exhausted its account creation quota.
Parameters
Name
Type
Description
new-user-key
required
query[string]
User key.
platform
optional
query[string]
The device type used to create the account, will be added to the user log, defaults to blank.
uuid
optional
query[string]
The device uuid used to create the account, will be added to the user log.
Success Response
• Code: 200
Content: User information in JSON format. If account creation is unsuccessful negative value is returned in the userId field.
Error Response
Note: This request does not require Authorization header.
POST /mobile/crew
Update crew information. This is a stub API and not yet implemented.
Parameters
Name
Type
Description
crew
data
Mobile Crew Information
as-user
optional
query[string]
Success Response
• Code: 200
Content: updated Mobile Crew information
Error Response
• Code: 500 Internal Server Errors
GET /mobile/crews
Retrieves list of crews present in NMS. Depending on permissions of the mobile user either all or only MDT crews are returned.
Parameters
None.
Success Response
• Code: 200
Content: Array of JSON objects representing crews.
Error Response
GET /mobile/crews/{id}
Retrieves information for a crew.
Parameters
Name
Type
Description
id
required
path[integer]
Crew key.
Success Response
• Code: 200
Content: Crew information in JSON format.
Error Response
GET /mobile/crews/{id}/assignments
Retrieves list of current assignments for a crew.
Parameters
Name
Type
Description
id
required
path[integer]
Crew key.
include-unsent-assignments
optional
query[boolean]
If value is true, include events assigned to the crew, but not yet sent to the crew.
Success Response
• Code: 200
Content: Array of JSON objects representing crew assignments.
Error Response
POST /mobile/crews/{id}/assignments/{event-id}/assign
Adds assignment of a crew to an event.
Parameters
Name
Type
Description
id
required
path[integer]
Crew key.
event-id
required
path[integer]
Event index.
as-user
optional
query[string]
User to do the API call as. Calling user must have "Allow as-user Parameter" mobile permission.
time
optional
query[long]
Time the assignment change occurred. Zero means current time. The value is the number of milliseconds since 1 January 1970 00:00:00.000.
mark-sent
optional
query[boolean]
Mark the event as sent to the crew. Default is false.
optional
query[boolean]
If value is true, in the return value, include events assigned to the crew, but not yet sent to the crew.
include-related
optional
query[boolean]
If value is true, assign related events for the crew too.
Success Response
• Code: 200
Error Response
POST /mobile/crews/{id}/assignments/{event-id}/dispatch
Places a crew en-route to an event.
Parameters
Name
Type
Description
id
required
path[integer]
Crew key.
event-id
required
path[integer]
Event index.
as-user
optional
query[string]
time
optional
query[long]
optional
query[boolean]
If value is true, in the return value, include events assigned to the crew but not yet sent to the crew.
Success Response
• Code: 200
Error Response
POST /mobile/crews/{id}/assignments/{event-id}/onsite
Places a crew onsite for an event.
Parameters
Name
Type
Description
id
required
path[integer]
Crew key.
event-id
required
path[integer]
Event index.
as-user
optional
query[string]
time
optional
query[long]
optional
query[boolean]
onsite-flag
optional
query[boolean]
If true, mark the crew status as on-site. If false, if the crew was on site, this will transition them to en route. Default is true.
Success Response
• Code: 200
Error Response
POST /mobile/crews/{id}/assignments/{event-id}/unassign
Removes assignment of a crew to an event.
Parameters
Name
Type
Description
id
required
path[integer]
Crew key.
event-id
required
path[integer]
Event index.
as-user
optional
query[string]
time
optional
query[long]
optional
query[boolean]
include-related
optional
query[boolean]
If value is true, undispatch related events for the crew too.
Success Response
• Code: 200
Content: Array of JSON objects representing remaining crew assignments.
Error Response
POST /mobile/crews/{id}/assignments/{event-id}/undispatch
Makes a crew no longer en-route or onsite for an event.
Parameters
Name
Type
Description
id
required
path[integer]
Crew key.
event-id
required
path[integer]
Event index.
as-user
optional
query[string]
time
optional
query[long]
optional
query[boolean]
include-related
optional
query[boolean]
Success Response
• Code: 200
Error Response
POST /mobile/crews/{id}/assignments/{event-id}/undispatch-and-assign
Makes a crew no longer en-route or onsite for an event but keeps the assignment of the crew to the event.
Parameters
Name
Type
Description
id
required
path[integer]
Crew key.
event-id
required
path[string]
A list of comma separated event indices.
as-user
optional
query[string]
time
optional
query[long]
optional
query[boolean]
suspend
optional
query[string]
Whether to suspend the event and crew, when applicable. If no other crews are assigned to the event, it will transition to the SUS state. If the crew is not assigned to other events, the crew will become Suspended.
Success Response
• Code: 200
Error Response
POST /mobile/crews/{id}/assignments/{event-id}/undispatch-and-assign-and-dispatch/{new-event-id}
Places crew en-route to a different event.
Parameters
Name
Type
Description
id
required
path[integer]
Crew key.
event-id
required
path[integer]
Original event index.
new-event-id
required
path[integer]
New event index.
as-user
optional
query[string]
time
optional
query[long]
optional
query[boolean]
Success Response
• Code: 200
Error Response
GET /mobile/crews/{id}/availability
Retrieves the current availability information for a crew.
Parameters
Name
Type
Description
id
required
path[integer]
Crew key.
Success Response
• Code: 200
Content: Crew availability information in JSON format.
Error Response
POST /mobile/crews/{id}/availability
Updates the current availability information for a crew.
Parameters
Name
Type
Description
id
required
path[integer]
Crew key.
unnamed
required
data
as-user
optional
query[string]
Success Response
• Code: 200
Error Response
GET /mobile/crews/{id}/status
Retrieves the current status of a crew.
Parameters
Name
Type
Description
id
required
path[integer]
Crew key.
Success Response
• Code: 200
Content: Crew status information in JSON format. Possible crew statuses: Inactive, OnShift, OffShift.
Error Response
POST /mobile/crews/{id}/status
Updates current status of a crew.
Parameters
Name
Type
Description
id
required
path[integer]
Crew key.
unnamed
required
data
Valid crew statuses:
• OnShift
• OffShift
• Inactive
as-user
optional
query[string]
Success Response
• Code: 200
Error Response
GET /mobile/crews/user
Retrieves crew information for a mobile user.
Parameters
Name
Type
Description
as-user
optional
path[string]
User name, defaults to authenticated user.
Success Response
• Code: 200
Error Response
GET /mobile/crew-types
Retrieves list of crew types configured in NMS.
Parameters
None.
Success Response
• Code: 200
Content: Array of JSON objects representing crew types.
Error Response
GET /mobile/damage-device-details
Retrieves device information for given alias.
Parameters
Name
Type
Description
device-id
required
query[string]
Device alias.
Success Response
• Code: 200
Content: Device information in JSON format.
Error Response
GET /mobile/dataset/{table}
Get records from the given table where the key-field matches the key-value based on the match type. The table must appear in the mobile_datasets whilelist table.
Parameters
Name
Type
Description
table
required
path[string]
Table name to return record for.
key-field
required
query[string]
Field name to use as the selection criteria for the returned records.
key-value
required
query[string]
value matched to the key-field as the selection criteria for the returned records.
match-type
optional
query[string]
The match type to use. Options:
equals, not-equals, like, not-like, or all.
Default value is equals.
max-rows
optional
query[integer]
Limit the number of rows returned to this value. Default value is 100.
lat-long
optional
query[boolean]
Add Lat/Long attributes to the data as possible.
Response
• Code: 200 The return value will a list of record sets.
PUT /mobile/dataset/{table}
Replace records for the given table where the key-field equals the key-value. The table must appear in the mobile_datasets whilelist table.
Parameters
Name
Type
Description
table
required
path[string]
Table name to update record for.
key-field
required
query[string]
key-value
required
query[string]
Value matched to the key-field as the selection criteria for the returned records.
data
required
data
List of records (EBJResultSet) to replace in the database dataset with selection_set, column_names and serialVersionUID set. Column widths and type not required.
Success Response
• Code: 200 OK
Error Response
PUT /mobile/device/assess
Updates the passed conductors to the assessed state.
Parameters
Name
Type
Description
handles
required
data
The conductor handles to update.
Response
• Code: 200 No content returned
POST /mobile/device/{handle}/trace
Request a server trace from the given device handle.
Parameters
Name
Type
Description
handle
path[handle]
Handle of the device to initiate the trace from.
Format: class.index (for example, 147.1234).
type
query[string]
Type of trace to perform. Can be one of the following: source, all, opens, or classes.
phase
query[integer]
Phases to perform trace on. Numbers may include 1 for A phase, 2, for B phase, 3 for AB phases, 4 for C phase, 5 for AC phases, 6 for BC phases and 7 for ABC phases.
direction
query[string]
The direction to trace, can be one of the following: all, up, down.
data
data
List of Stop Class Names.
Response
Java TraceResults in JSON format including list of endpoints, list of traced objects, and list of abnormal open switches
GET /mobile/device/{id}/info
Returns information about a given device given a device handle.
Parameters
Name
Type
Description
id
required
path[string]
The device handle in the format: class.index
Success Response
• Code: 200
Content: Returns information about the device including alias, phases, closed phases, fully open flag, fully closed flag.
Error Response
GET /mobile/device/{handle}/last_known_location
Returns the last known location of the given device handle.
Parameters
Name
Type
Description
handle
path{handle}
Handle of the device to get the last known location of (for example, 147.1234)
Success Response
• Code: 200
Content: Returns information about the device including coordinates, partition and coordinate system.
Error Response
GET /mobile/device/{id}/lookahead/{operation}/{phases}
Returns look ahead data about the requested operation on the given device.
Parameters
Name
Type
Description
id
required
path[string]
operation
required
path[string]
Operation to perform on the device, either open or close
phases
required
path[integer]
Integer representation of the phases to operate. For example, 1=A, 2=B, 3=AB, 4=C, 5=AC, 6=BC, 7=ABC.
Success Response
• Code: 200
Content: Returns Look Ahead Information including device information, alias, phases, customers affected by phase, ato customers affected by phase, condition, abnormal devices, critical customers, and DERs.
Error Response
GET /mobile/device/{id}/operate/{operation}/phases/{phases}/time/{time}
Performs the operation on the given phases for a device.
Parameters
Name
Type
Description
id
required
path[string]
operation
required
path[string]
phases
required
path[integer]
time
required
path[long]
Time the operation was requested. 0 = current time.
as-user
optional
query[string]
crew-id
optional
query[integer]
The crew key, if any resulting newly created Real Outage should be assigned to the crew.
nested
optional
query[string] (Y|N)
Whether to create a nested outage (when applicable)
onsite
optional
query[string]
(Y|N)
Whether the passed crew should also be set to Onsite for the resulting event.
sheet
optional
query[integer]
Switch sheet ID associated with this control operation.
step
optional
query[integer]
Switch step ID associated with this control operation.
Success Response
• Code: 200
Content: Operation successful
Error Response
PUT /mobile/device/unassess
Updates the passed conductors to clear the assessed state.
Parameters
Name
Type
Description
handles
required
data
Response
• 200: No content returned
GET /mobile/devices
Retrieves information for devices matching given device alias search string.
Parameters
Name
Type
Description
device-id
required
query[string]
Device alias search string (can contain SQL wildcard characters).
Success Response
• Code: 200
Content: Array of JSON objects representing device information.
Error Response
GET /mobile/feeders
Retrieves list of feeders with attributes (h_cls, h_idx, feeder_name, substation_name, color, group_num, and abnormal_color).
Parameters
Name
Type
Description
Option
optional
query[string]
If "name", return feeder information structured by feeder name using the server cache. If "handle", return feeder information structured by feeder FID handle using the server cache. Otherwise, return a feeder information from the feeders table as a database dump.
Success Response
• Code: 200
Content: Array of JSON objects representing all NMS feeders
Error Response
GET /mobile/file/:dir_name /:file_name
Returns the requested file from the given OPERATION_MODEL subdirectory in JSON format.
Parameters
Name
Type
Description
dir-name
path[string]
Name of the OPERATIONS_MODEL subdirector
file-name
path[string]
Name of the file to retrieve
Success Response
• Code: 200
Content: JSON file format
Error Response
GET /mobile/full-condition
Retrieves full information for a single condition.
Parameters
Name
Type
Description
qt
required
query[string]
Query type. Valid values:
• da: damage report
• event: event
• incident: call or other incident
• <condition class name>
condition-cls
required
query[integer]
Condition class.
This parameter is not used.
condition-idx
required
query[integer]
Condition index.
Success Response
• Code: 200
Content: JSON object containing condition details.
Content: Condition was not found.
Error Response
Content: User is not authorized to perform the request.
Content: Unspecified error has occurred.
GET /mobile/get-permissions
Retrieves permissions of the mobile user.
Parameters
Name
Type
Description
as-user
optional
query[string]
userType
optional
query[string]
Limit permission based on user type. Default to blank.
Success Response
• Code: 200
Content: List of permissions assigned to the mobile user.
GET /mobile/geographic‑partitions
Retrieves a set of geographic partitions.
Parameters
None.
Success Response
• Code: 200
Content: Set of geographic partitions including map name, handle, and minimum-bounding-rectangle.
POST /mobile/hlm
Sends high-level message (HLM) to NMS.
Parameters
Name
Type
Description
target
required
query[string]
NMS user this HLM should be delivered to
msg
required
data
JSON representation of the HLM
HLM JSON Format
Attribute
Type
Description
from
string
Message sender
to
string
NMS tool this HLM should be delivered to
message
string
The message text
Example
POST https://nms.example.com:7102/nms-ws/mobile/hlm?target=nms2
"from": "nms1",
"message": "test",
"to": "CallEntry"
Required Permissions
Send HLM
Success Response
Content: None
Error Response
• Code: 400 Bad Request
Either 'target' or 'msg' parameter is empty.
GET /mobile/device/{id}/customers
Get a list of customers associated with a device id, including downstream devices. The call will take a device handle and a maximum number of SND's to get customers for.
Parameters
Name
Type
Description
id
path[handle string]
Handle of the device to get customers (for example, 123.1001).
max-supply-nodes
query[integer]
Maximum number of SND's to get customers for.
use-nominal-if-deenergized
optional
query[boolean]
If the device is in a deenergized section of the model, use nominal energization to fine downstream devices.
summarize-if-limit
optional
query[boolean]
If the number of SNDs exceeds the limit, return a summary instead.
summarize-if-limit-with-crit-customers
optional
query[boolean]
If the number of SNDs exceeds the limit and returning a summary, include a list of critical customers if that list of SNDs does not exceed the limit.
Response
• Code: 200
The return value will be the list of customers in JSON double array format, where the first record of the array will be the field names, and the rest of the array will be records of just values. It is up to the client to reformat the return value into true JSON objects.
GET /mobile/{id}/customer-summary
Get a summary of critical customers associated with a device id, including downstream devices. The call will take a device handle to get customers for.
Parameters
Name
Type
Description
id
path[handle string]
optional
path[handle string]
Response
• Code: 200
Content: The return value will be the list of customers in JSON double array format, where the first record of the array will be the field names, and the rest of the array will be records of just values. It is up to the client to reformat the return value into true JSON objects.
GET /mobile/lookup-types/{table}/{keyField}/{valueField}
Get a set of look up values from a table with specified integer key field and string value field. The table must be in the read_only_tables, inserted from the [project]_readonly.sql file. The table must also be in the mobile_lookup_types_tables table, inserted generally from the [project]_mobile_crew.sql file.
Parameters
See description for path parameter details.
HLM JSON Format
Example
GET https://nms.example.com:7102/nms-ws/mobile/lookup-types/crew_mobile_carriers/type_num/carrier
Returns, in JSON format:
{"id":0,"value":" "},
{"id":1,"value":"ATT"},
{"id":2,"value":"Verizon"},
{"id":3,"value":"T-Mobile"},
{"id":4,"value":"Sprint"},
{"id":5,"value":"US Cellular"},
{"id":10,"value":"Other"}
None
Success Response
• Code: 200 Ok
Content: JSON lookup types with "id" and "value" pairs.
Error Response
GET /mobile/maps
Retrieves list of map definition objects.
Parameters
None.
Success Response
• Code: 200
Content: Array of JSON objects representing map definitions.
Error Response
GET /mobile/maps/{mapname}
Returns the requested map in GeoJSON format.
Parameters
Name
Type
Description
mapname
required
path[string]
Name of the map to retrieve.
compression
optional, defaults to 'Y'
query[string]
Indicates if the returned map is to be compressed or not by given value, Y or N.
Success Response
• Code: 200
Content: GeoJSON map.
Error Response
GET /mobile/messages-partition-changes/{sub-id}
Given a subscription ID, get an object from NMS server containing the request status and an array of all partition changes including items like real time switch status, model builds, and condition changes.
Parameters
Name
Type
Description
sub-id
path[string]
A subscription ID from the GET:mobile/subscribe-partition-changes call.
counter
optional
query[integer]
Counter of subscription changes received. Defaults to -1.
Response
Will return an object containing the request status and an array of all partition changes including items like real time switch status, model builds, and condition changes. Will also include a boolean indicator, geojsonIndex, which will be true if the geojson index map has been updated on the server.
POST /mobile/mobile-user-logout
Notifies NMS that mobile user has logged out.
Parameters
None.
Success Response
Content: None
Error Response
GET /mobile/mobile-user-validation
Performs validation of user credentials.
Parameters
Name
Type
Description
platform
optional
query[string]
uuid
optional
query[string]
Success Response
• Code: 200
Content: User information in JSON format. If validation is unsuccessful value -2 is returned in the userId field.
Error Response
POST /mobile/partition/statuses
Given a list of partitions, return the real-time statuses and states of the electrical objects in the partitions by partition.
Parameters
Name
Type
Description
partitions
required
data
A list of partitions (integers).
Success Response
• Code: 200
Content: State and Status information by partition in JSON format.
Error Response
GET /mobile/nms-status
Returns status of the NMS system. Plain text string 'up' is returned if NMS is accessible and all critical services are operational. Otherwise returns plan text string 'down'.
Parameters
None.
Success Response
• Code: 200
Content: None.
Error Response
GET /mobile/set-current-crew/{id}
Sets crew associated with this mobile user.
Parameters
Name
Type
Description
id
required
path[integer]
Crew key.
as-user
optional
query[string]
Success Response
• Code: 200
Error Response
GET /mobile/subscribe-partition-changes
Subscribe to the NMS server for all partition changes including items like real time switch status, model builds, and condition changes.
Parameters
None
Response
Will return a subscription ID string to be used to get the changes and to unsubscribe.
GET /mobile/switch-sheets/assignments/{crew-key}
Returns a list of Mobile Switch Sheets associated to the given crew key
Parameters
Name
Type
Description
crew-key
required
path[integer]
Crew Key
returnStepsInTreeFormat
optional
query[boolean]
If specified, return data in tree format, otherwise will return in flat format. Default is false.
Success Response
• Code: 200
Content: A list of Mobile Switch Sheets, each sheet contains a sheet id, list of attribute/values, a list of steps, and a list of switch sheet associated document names and descriptions.
Error Response
GET /mobile/switch-sheet/{sheet-cls}/{sheet-idx}
Returns a list of Mobile Switch Sheets associated to the given crew key.
Parameters
Name
Type
Description
sheet-cls
required
path[integer]
sheet class number
sheet-idx
required
path[integer]
sheet index number
steps-in-tree-format
optional
query[true/false]
whether to return the steps as a tree or a simple list. Default: false
Success Response
• Code: 200
Content: A Switch Sheet
Error Response
PUT /mobile/switch-sheets/{sheet-cls}/{sheet-idx}/document
Add a document to a switching sheet.
Parameters
Name
Type
Description
sheet-cls
required
path[integer]
Sheet class number
sheet-idx
required
path[integer]
Sheet index number
unnamed
required
data
Document to add
as-user
optional
query[string]
Success Response
• Code: 200
Content: Attachment Document details
Error Response
GET /mobile/switch-sheets/{sheet-cls}/{sheet-idx}/document/{document-id}
Get an attached document from a switching sheet given the document ID.
Parameters
Name
Type
Description
sheet-cls
required
path[integer]
Sheet class number
sheet-idx
required
path[integer]
Sheet index number
document-id
required
path[integer]
Document ID
Success Response
• Code: 200
Content: document requested
Error Response
GET /mobile/switch-sheets/{sheet-cls}/{sheet-idx}/report
Get a formatted report for the given switching sheet.
Parameters
Name
Type
Description
sheet-cls
required
path[integer]
Sheet class number
sheet-idx
required
path[integer]
Sheet index number
format
query[string]
Format of the report:
pdf (default)
html
options
query[string]
Content of the report, use the following content values fallowed by true or false for inclusion in the report, default value is true for all:
SHOW_EC:true;
SHOW_AL:true;
EXTERNAL_DOCUMENTS:true;
SHOW_SAFETY:true;
SHOW_REQUEST:true;
SHOW_IC:true;
SHOW_STEPS:true
Success Response
• Code: 200
Content: content of report
Error Response
POST /mobile/switch-sheets/{sheet-cls}/{sheet-idx}/steps/{step-cls}/{step-idx}
Updates status and fields of a switch sheet step.
Parameters
Name
Type
Description
sheet-cls
required
path[integer]
Sheet class number
sheet-idx
required
path[integer]
Sheet index number
step-cls
required
path[integer]
Step class number
step-idx
required
path[integer]
Step index number
action
optional
query[string]
Step transition action: complete_step, abort_step, fail_step
update-fields
optional
query[string]
Step fields that have changes: comments, switching_desc, step_details, executed_time.
time
query[long]
Time when the switch step update occurred.
as-user
optional
query[string]
Success Response
• Code: 200
Content: None.
Error Response
POST /mobile/switch-sheets/{sheet-cls}/{sheet-idx}/steps/{step-cls}/{step-idx}/details
Updates comments, switching description, step details, mobile status, or mobile status date of a switch sheet step.
Parameters
Name
Type
Description
sheet-cls
required
path[integer]
Sheet class number
sheet-idx
required
path[integer]
Sheet index number
step-cls
required
path[integer]
Step class number
step-idx
required
path[integer]
Step index number
update-fields
optional
query[string]
Step fields that have changes, space separated:
COMMENTS, SWITCHING_DESC, STEP_DETAILS, MOBILE_STATUS, MOBILE_STATUS_TIME.
as-user
optional
query[string]
switch-step
required
data
Switch step object that changes are applied to.
Success Response
• Code: 200
Content: None.
Error Response
POST /mobile/switch-sheets/{sheet-cls}/{sheet-idx}/steps/{step-cls}/{step-idx}/location
Update location (address) of a step of a switching plan.
Parameters
Name
Type
Description
sheet-cls
required
path[integer]
Sheet class number
sheet-idx
required
path[integer]
Sheet index number
step-cls
required
path[integer]
Step class number
step-idx
required
path[integer]
Step index number
unnamed
required
data
New location (Address) of the step.
as-user
optional
query[string]
Success Response
• Code: 200
Content: number indicating a count of the number of step that had this device location updated.
Error Response
POST /mobile/switch-sheets/{sheet-cls}/{sheet-idx}/transition
Transition the given switch sheet using the transition action name provided. Update sheet log with comment, user, and time as provided.
Parameters
Name
Type
Description
sheet-cls
path[integer]
Sheet class number
sheet-idx
path[integer]
Sheet index number
action
query[string]
Transition action to perform
comment
query[string]
Comment to add to the sheet log
time
query[long]
Time when the transition happened
as-user
query[string]
Success Response
• Code: 200
Content: None.
Error Response
GET /mobile/unsubscribe-partition-changes/{sub-id}
Unsubscribe from the NMS server for partition changes.
Parameters
Name
Type
Description
sub-id
path[string]
Response
Will return an object containing the request status.
PUT /mobile/user-profile/{field-name}/{value}
Updates the requesting users profile for the given field-name with the given value.
Parameters
Name
Type
Description
field-name
required
path[string]
Profile field to update.
Names include:
• First name
• Last name
• Email
• Phone
• Company
value
required
path[string]
Value to set field to.
as-user
optional
query[string]
Success Response
• Code: 200
Content: User information including all profile value
Error Response
GET /mobile/version
Get the version of the mobile application.
Parameters
None.
Success Response
• Code: 200
Content: Version information for the NMS Application Server and the NMS Mobile Server including items like build date, build tag, project name, NMS version, and server host name.
Error Response
GET /trbl-rest/config/{cfg}
Retrieves NMS Trouble Management configuration items.
Parameters
Name
Type
Description
cfg
optional
path[string]
Configuration type. One of the following:
• picklist: event completion choices, from the PICKLIST_GUI table.
• trouble-queue: trouble queue options, from the RAPID_REFERRAL table.
• crew-members: crew member type options, from the CREW_MEMBER_CLASSES table.
• te-state-actions: All act_key, act_name from the TE_STATE_ACTIONS configuration table. This can be used to determine which state transitions are valid for a given event.
Success Response
• Code: 200
Content: JSON representation of the requested configuration item.
Error Response
PUT /trbl-rest/event/{id}/confirm-outage
Will confirm open the device associated with a probable outage Event.
Parameters
Name
Type
Description
id
required
path[integer]
Event Idx
as-user
optional
query[string]
Success Response
• Code: 200
Content: None.
Error Response
POST /trbl-rest/event/{id}/confirm-pso
Allows to convert a single-call PSO into CSVO and restore CSVO and CSCO events.
Parameterss
Name
Type
Description
id
required
path[integer]
Event index
restore
optional
query[boolean]
Whether outage should be confirmed or restored.
Success Response
• Content: None.
• Code: 204
Error Response
POST /trbl-rest/event/{id}/log
Add an Event Log entry to the given event.
Parameters
Name
Type
Description
id
required
path[integer]
Event ID
logEntry
required
data[string]
Log message
as-user
optional
query[string]
Success Response
• Code: 200
Content: None
Error Response
POST /trbl-rest/event/{id}/log-once
Add an Event Log entry to the given event; verify it has not already been added before.
Parameters
Name
Type
Description
id
required
path[integer]
Event ID
logEntry
required
data[string]
Log message
as-user
optional
query[string]
Success Response
• Code: 200
Content: None.
Error Response
PUT /trbl-rest/event/{id}/release-all
Release all crews from the event
Parameters
Name
Type
Description
id
required
path[integer]
Event ID
Success Response
• Code: 200
Content: None.
Error Response
POST /trbl-rest/event/{id}/state-transition
Request a state transition for the passed event.
Parameters
Name
Type
Description
id
required
path[integer]
Event ID
action
required
data[string]
The TE state action to be used to transition the event.
alarms
optional
query[string]
Comma separated list of alarm indices.
as-user
optional
query[string]
Success Response
• Code: 200
Content: None.
Error Response
POST /trbl-rest/events/all-events
Retrieves a list of events with the given indexes.
Parameters
Name
Type
Description
unnamed
required
data
List of event ids in JSON format.
max_calls
query[integer]
Maximum number of calls to return about the event. Default: 10.
trace_to_switch
query[char]
Y/N
If value is Y, will also trace to the first upstream switch and store that. Default: N.
Success Response
• Code: 200
Content: JSON representation of NMS events
Error Response
Event with the given indexes were not found.
GET /trbl-rest/events/{id}
Retrieves an event with the given index.
Parameters
Name
Type
Description
id
required
path[integer]
Event index.
max_calls
query[integer]
include_all_related_events
optional
query[boolean]
If value is true, include all related events too.
extended
query[char]
If value is 'Y', will return the NMS TroubleEvent structure in addition to the Event structure.
trace_to_switch
query[char]
Y/N
If value is Y, will also trace to the first upstream switch and store that in the upstreamSwitch Event field.
Success Response
• Code: 200
Content: JSON representation of an NMS event or the NMS Event and TroubleEvent.
Error Response
Event with the given index was not found.
POST /trbl-rest/events/{id}
Updates information for an event. The following event fields can be updated: case notes, ERT, Event Details picklists. Event can also be restored and completed.
Parameters
Name
Type
Description
id
required
path[integer]
Event index.
unnamed
required
data
Event information in JSON format.
as-user
optional
query[string]
Success Response
Error Response
Event index mismatch between resource URL and body.
POST /trbl-rest/events/{id}/associate
Associates fuzzy event to a device.
Parameters
Name
Type
Description
id
required
path[integer]
Event index
unnamed
required
data[json]
Device handle
as-user
optional
query[string]
The user to do the API call as. The calling user must have the 'Allow as‑user Parameter' mobile permission.
Payload Example
"app": 0,
"classNumber": 206,
"instanceNumber": 2149
Success Response
• Code: 204
Content: No Content
Error Response
GET /trbl-rest/events/{id}/customers
Get the customer information for the passed event index. This includes all custom fields from the CES_CUSTOMERS table.
Parameters
Name
Type
Description
id
required
path[integer]
Event ID
Success Response
• Code: 200
Content: double array of customer information.
Error Response
PUT /trbl-rest/events/{id}/trouble-queue
Updates trouble queue(s) for an event.
Parameters
Name
Type
Description
id
required
path[integer]
Event index.
unnamed
required
data
Array of trouble queue codes.
comment
optional
query[string]
Comment
source
optional
query[string]
Update source. Written into the field in the JOBS table specified by the "workQueueSourceField" configuration rule.
as-user
optional
query[string]
User to do the API call as. The calling user must have the 'Allow as-user Parameter' mobile permission.
Payload Example
["SRV", "LNE", "EVL"]
Success Response
Error Response
POST /trbl-rest/user-log
Add an User Log entry to the given event.
Parameters
Name
Type
Description
logEntry
required
data[string]
Log message
Success Response
• Code: 200
Content: None.
Error Response
POST /trbl-rest/user-log-once
Add an User Log entry to the given event; verify it has not already been added before.
Parameters
Name
Type
Description
logEntry
required
data[string]
Log message
Success Response
• Code: 200
Content: None.
Error Response
POST /nms-c2m/job-history
Retrieves jobs from NMS database matching the supplied query conditions by invoking the PK_CCB.JOB_HISTORY stored procedure.
Parameters
Name
Type
Description
unnamed
required
data
JSON representation of query conditions.
The following query conditions are supported:
1. Jobs affecting specific customer. In this case the following query conditions can be used:
• servPointId: Search by unique customer identifier
• premiseId: Search by premise (service location) identifier
• accountNumber: Search by account number
2. Jobs that contain specific calls.
• externalId: Search by call's external id
• callId: Search by call identifier
• callerName: Search by caller name
• callerPhone: Search by caller phone number
3. Jobs at specific location.
The location represents street segment or street intersection. In this case the following query conditions can be used:
• crossStreet1: Street name for street segment search or first street for street intersection search
• crossStreet2: Second street for street intersection search
• blockNumber: Block number for street segment search
• city: City/municipality
• state: State
4. Custom search.
To use custom search the stored procedure needs to be modified by the project. In this case the following query conditions can be used:
• field1: custom search parameter 1
• field2: custom search parameter 2
• field3: custom search parameter 3
• field4: custom search parameter 4
• field5: custom search parameter 5
Active jobs matching query conditions are always returned. Restored and completed jobs are returned if 'numCompletedDays' query condition is provided and job is either not completed or it has been completed no more than the specified number of days in the past.
For more information on the PK_CCB.JOB_HISTORY stored procedure see the Stored Procedure Parameters.
Success Response
• Code: 200
Response contains JSON representation of the found jobs. Definition of the database object type JOB_REQ lists the returned job fields.
No jobs found that match query conditions.
Error Response
Request cannot be processed. Response contains description of the error.
POST /nms-c2m/switching-history
Retrieves current, future and optionally past switching plans that affect specified customer by invoking the PK_CCB.SWITCHING_HISTORY stored procedure.
Parameters
Name
Type
Description
unnamed
required
data
1. Calls for a specific customer.
2. Custom search.
• field1: Custom search parameter 1
• field2: Custom search parameter 2
• field3: Custom search parameter 3
• field4: Custom search parameter 4
• field5: Custom search parameter 5
Completed switching plans matching query conditions are only returned if 'numCompletedDays' query condition is provided and switching plan has been completed no more than the specified number of days in the past.
For more information on the PK_CCB.SWITCHING_HISTORY stored procedure see the Stored Procedure Parameters.
Success Response
• Code: 200
Response contains JSON representation of the found switching plans. Definition of the database object type switching_plan_rec lists the returned call fields.
No switching plans found that match query conditions.
Error Response
• Code: 500: Internal Server Error
POST /nms-c2m/submit-calls
Submit one or more calls to NMS by inserting them into the TROUBLE_CALLS database table using the PK_CCB.SUBMIT_CALL stored procedure.
Parameters
Name
Type
Description
unnamed
required
data
JSON representation of trouble calls.
Definition of the database object type.
INPUT_CALL_REC on page 1-43 lists the available trouble call fields.
For more information on the PK_CCB.SUBMIT_CALLS stored procedure see the Stored Procedure Parameters.
Success Response
All calls submitted successfully.
• Code: 200
At least one of the calls was not submitted successfully. Response contains array of error codes and messages for the failed calls.
Error Response
POST /nms-c2m/update-customers
Adds or updates one or more customer records in the staging customer model database tables (CU_*_CIS) in NMS using the PK_CCB.UPDATE_CUSTOMER stored procedure.
Parameters
Name
Type
Description
unnamed
required
data
JSON array of new/updated customer records. Customer record matches the definition of the CUST_UPDATE_REC database object type.
Success Response
All customer updates performed successfully.
• Code: 200
At least one of the customer updates was not submitted successfully. Response contains array of error codes and messages for the failed updates.
Error Response
GET /nms-c2m/trouble-codes
Retrieves trouble code (clues) configuration from NMS.
Parameters
None
Success Response
• Code: 200
Response contains JSON representation of the trouble codes configured in NMS. Definition of the database object type TROUBLE_CODE_REC on page 1-56 lists the returned call fields.
Error Response
POST /nms-c2m/call-history
Retrieves calls from NMS database matching the supplied query conditions by invoking the PK_CCB.CALL_HISTORY stored procedure.
Parameters
Name
Type
Description
unnamed
required
data
2. Fuzzy call search.
• externalId: Search by calls external id
3. Calls at or near specific location.
• state: State
4. Custom search.
Calls for active jobs matching query conditions are always returned. Calls for restored and completed jobs are returned if 'numCompletedDays' query condition is provided and job is either not completed or it has been completed no more than the specified number of days in the past.
For more information on the PK_CCB.CALL_HISTORY stored procedure see the Stored Procedure Parameters.
Success Response
• Code: 200
Response contains JSON representation of the found calls.
Definition of the database object type CALL_REC on page 1-52 lists the returned call fields.
No calls found that match query conditions.
Error Response
