Installation and Deployment Overview
This document assumes you are using the Oracle Network Management System (NMS) and the Oracle Integration Cloud (OIC), with integration to the Oracle Data Access Cloud Service (DACS), Oracle Utilities Analytics Insights (OUAI), and Oracle Live Energy Connect (LEC). If you are using Oracle Network Management System Grid Edge DERMS without any of these products, you will need to contact Oracle Consulting Service (OCS) to integrate to your products.
The Oracle Network Management System Grid Edge DERMS is delivered as two components:
1. The server side Grid Edge DERMS Gateway. This gateway must be installed on an application server available to the clients. If the clients are coming in from the public internet, this DERMS Gateway must be available on the public internet. This DERMS Gateway will then interface to the Oracle Network Management System and the Oracle Integration Cloud (OIC) application servers based on firewall/network configurations setup by your IT staff.
2. The Oracle Network Management System Grid Edge DERMS Software Development Kit (DERMS/SDK), which contains the source code of the mobile application. The Grid Edge DERMS/SDK must be compiled to the target platform and installed on the platforms in order to run.
