Network Management System Installation Guide
Audience
Related Documents
Conventions
Introduction
Resources
Product Release Naming Conventions
System Overview
Pre-Installation
Installation Prerequisites
Introduction
Requirements for Oracle Utilities Network Management System Database
Configuring the Oracle Utilities Network Management System Database
Requirements for Oracle Database Client Installation
Requirements for Spatial Landbase
Requirements for Web Maps Landbase
Software Requirements for Unzipping Files
Security Considerations
Isis Directory and NTP Daemon
Client Authentication
Operating System and Administrative User Setup
Dual-Environment Configuration
Administrative User Configuration
Korn Shell Configuration
Operating System Configuration
Core File Naming Configuration
System Installation
Installation Steps
Upgrading from NMS v2.4 or Earlier
Installing Oracle Utilities Network Management System Software
Starting Isis
Create Database Environment
Validation Model Setup
Web Application Configuration
Configuring NMS Security Roles
WebLogic Server Runtime Configuration
Deploying Oracle Utilities Network Management System in WebLogic Server
Installing Flex Operations
Authenticating Flex Operations Users
Installing Web Clients
Deploying Patch Bundles
Steps to Deploy a Patch Bundle using Failover Patching
Installing Oracle Business Intelligence Publisher
Installing and Configuring Optional Components
Spatial Landbase Map Installation
Spatial Outage Summary Installation
Web Map Server Connection
Oracle Locator Server Connection
Configuring a Web Call Entry-Only Managed Server
Directory Structure
Directory Overview
Installation Directory
Project Configuration Directory
Runtime Directory
Directory Administration
Starting Services
Troubleshooting
Applying Migrations for a New Release
Disabling System Logins
Applying Product Migrations
Manual Product Migrations
Command Line Options
Installing Product Migration Files
The Product Migration Process
Applying Custom Migrations for NMS Integrators
Process Overview
Adding Custom Migrations to the Utility Migrations XML File
Running the Migration Scripts
UTILITY_MIGRATIONS Database Table
Configuring a Translated User Interface
Network Management System Installation Guide, Release 2.6.0.0.2
