Launching Modules and Logging In
Launching an Application
Depending on your system installation, Oracle Utilities Network Management System modules are typically accessed by an URL (provided by your Oracle Utilities Network Management System implementation team) or through shortcuts installed on your desktop or in your application menu (such as the Microsoft Windows Start menu or Linux Applications menu).
The following modules are launched individually and are accessible to users having needed permissions based on User Type (see
Understanding User Types for information):
• Configuration Assistant: The Configuration Assistant provides a graphical view of the Oracle Utilities Network Management System configuration options and allows
Administration users to add, edit, and store configuration changes. See
Configuration Assistant for details.
• Model Management: Model Management is a tool for managing changes to your system model. It is available to users with
Model Validation permissions. See
Model Management for details.
• Service Alerts: Service Alert Administration is an application that sends notifications to utility personnel via e-mail or text/SMS message. It may be accessed by
Administration user types. See
Service Alert Administration for details.
• Storm Management: Storm Management enables you to manipulate the event and crew information that the system will use to make its calculations. It provides access for
Full Operations,
View Only, and
Storm Management for details.
• Web Call Entry: Web Call Entry enables you to enter and access customer call and event information. It provides access for the
Web Call Entry user type. See
Web Call Entry for details.
• Web Callbacks: Web Callbacks is used to manage callback requests for customers who called in to report an outage. It provides access for the
Full Operations user type. See
Web Callbacks for details.
• Web Workspace: The Web Workspace provides the tool sets and views that are the foundation of the Oracle Utilities Network Management System user environment. The common features and platform provided by the Web Workspace provide a cohesive user experience for other Oracle Utilities Network Management System modules, such as Web Trouble Management or Web Switching Management. Depending on the NMS modules that are licensed, it provides access to the
Full Operations plus Switching,
Full Operations,
Trouble Maintenance,
Crew Operations,
Switching Request,
View Only,
Administration, and
Trainer user types. See
Web Workspace for details.
Use the installed shortcuts, if applicable, or open the URL in a web browser to launch the module. The Oracle Utilities Network Management System will begin downloading Java components of the module to your computer. The Login window will open.
User type determines how the environment will be displayed when you log in.
• Administration: provides the full complement of tools with additional tools and functions to change operational parameters.
• Crew Operations: provides a limited version of Web Workspace with only the tools necessary for crew administration functions.
• Full Operations: provides operational access to all Web Workspace tools.
• Full Operations plus Switching: provides operational access to all Web Workspace tools plus the Web Switching Management tools.
• Switching Request: provides access to the Web Switching Request environment with only the tools necessary to create switching requests.
• Trainer: provides access to the Web Workspace environment with all licensed modules and extra tools needed by a trainer to conduct training.
• Trouble Maintenance: provides a limited workspace with tools necessary for outage management functions.
• View Only: provides read-only access to the operational environment.
• DERMS User: Access to DERMS Events tool only. Can create and schedule DERMS events. Cannot approve DERMS events.
• DERMS Supervisor: Access to DERMS Events and DERMS Strategies tools. Can create DERMS strategies. Can create, approve, and schedule DERMS events.
• DERMS Administrator: Access to DERMS Events, DERMS Strategies, DERMS Configuration tools. Can create DERMS strategies. Can create, approve, and schedule DERMS events. Can configure DERMS users, parameters, and other options.
• Flex Crew Operations: provides only crew administration functions in the Flex Ops client.
• Flex Full Operations: provides access to all Flex Ops tools except for Switching.
• Flex Full Operations plus Switching: provides operational access to all Flex Ops client tools plus the Flex Switching features.
• Flex Switching Request: provides access to the Flex Ops client’s Switching Request features.
• Flex View Only: provides read-only access to the Flex client environment.
See
Appendix E -
Tool to User Type Matrix for information on modules and tools available by user type.
Logging In
1. To log in, enter the following information in the Login window:
User ID: enter the user name provided to you by your system administrator.
Password: enter the password provided to you by your system administrator.
Validate: click the Validate button to verify your login credentials.
Note: If your user name and password are not entered correctly, the system will display a Login Error message.
Once you have entered your user name and password, the Validate button will become activated.
2. Click Validate (or press Enter while in the password field) to validate your credentials.
3. Select
User Type from the drop-down list to determine what tools and functions will be available to you (some applications only allow one user type). See
Understanding User Types for more information.
5. Once the login criteria have been entered, click the Login button to complete the login process and open the module.
Note: If two-factor authentication is enabled, the Two Factor Authentication dialog box will open. To request an authentication code, select a delivery method from the drop-down list, and then click Request Code. Once you receive the code, enter it in the Code field, and click OK.
6. The Quit button closes the Login window and exits the Oracle Utilities Network Management System.
