Filter Name | Description |
All | Displays all events of any status. Note: Statuses are displayed in the Work Agenda Status column; see Event Status Codes for a complete list of status codes and descriptions. |
Completed | Displays all completed and canceled trouble events. Statuses: CMP, PCMP, SCMP, WCMP, CNL, SCNL, and WCNL. Note: See Event Status Codes for event status descriptions. |
Default | Applies the filter for the currently selected view. |
In Progress | Displays most trouble events that have crew resources associated with them and any trouble event alarms. Statuses: ASN, SASN, WASN, ENR, SENR, WENR, NFY, ONS, SONS, WONS, RSCH, RST, SRST, SUS, SSUS, WSUS, and VFY. Note: See Event Status Codes for event status descriptions. |
Incomplete | Displays all incomplete trouble events and events that have maintenance work pending. Incomplete events are events that are complete in the field but still require that Event Details be completed. Statuses: INC, PINC, SINC, MNP, and SMNP. Note: See Event Status Codes for event status descriptions. |
Switching | Displays all events that have an associated planned switching sheet in a Scheduled (or later) status. |
To Do | Displays trouble events that require attention and any trouble event alarms. Statuses: CCNL, CRT, NEW, PNEW, SNEW, NFY, RED, RSCH, SNT, PSNT, SSNT, WSNT, UAS, PUAS, SUAS, WUAS, and VFY Note: See Event Status Codes for event status descriptions. |
To Do & In Progress | Displays trouble events that have resources assigned to them or require attention, along with and any trouble event alarms. This view excludes Dist Gen TTL events. Statuses: CRT, CCNL, NEW, FNEW, MNEW, PNEW, SNEW, NFY, RED, RSCH, SNT, MSNT, PSNT, SSNT, WSNT, UAS, FUAS, MUAS, PUAS, SUAS, WUAS, ASN, FASN, SASN, WASN, ENR, FENR, SENR, WENR, NFY, ONS, FONS, SONS, WONS, RSCH, RST, SRST, SUS, SSUS, WSUS, and VFY Note: See Event Status Codes for event status descriptions. |
Menu Option | Description | Toolbar Icon |
Expands to display the following export options. • Default copy action (Ctrl+C): Copies your selection to the clipboard according to the current default copy action. Once the option is selected, the data you selected will be saved to your clipboard so you can then paste the data somewhere. It also opens a panel that allows you to change the default action by clicking the MAKE DEFAULT check-box and then selecting a different copy type. • Cell to Clipboard: Copy the selected cell(s) to the clipboard. • Column to Clipboard: Copy the selected column(s) to the clipboard. • Rows to Clipboard: Copy the selected row(s) to the clipboard. • All Rows to Clipboard: Copies all data rows to the clipboard. • Rows to Clipboard (With Headings): Copies selected data rows and column headings to the clipboard. • All Rows to Clipboard (With Headings): Copies all data rows and column headings to the clipboard. • Export Table...: Opens the Export Table dialog box, which allows you to save the table data to a comma separated value (csv) file. | -- | |
Print... | Displays the Print Preview dialog box so you can view or print the list. | |
Print Reading Pane... | Displays the Print Preview dialog box so you can view or print the Reading Pane. | |
Print Preview Calls... | Opens the Report dialog box that allows you to choose a preview type (for example, PDF, HTML, and so on); click Preview.... to display the calls report for the highlighted rows. | |
Print Calls... | Opens the Report dialog box that allows you to choose a report type (for example, PDF, HTML, and so on) and printer for the highlighted rows; click Print to send the report to the selected printer. | |
Email Calls... | Opens the Report dialog box that allows you to choose the type of report (for example, PDF, HTML, and so on) to be generated for each highlighted row; click Email... to attach the calls to a new email message (using your default email application) that may then be sent to your chosen recipients. | |
Toggle Dockable Window | Changes a standalone window to a pane that may be moved or docked in another window or frame. See Understanding Docked Panes and Standalone Window Tools for more information on dockable and standalone windows. | |
Exit | Closes the Work Agenda window. | -- |
View... | Opens Viewer 1 if not already open, and then focuses Viewer 1 on the asset from the selected Work Agenda row. | |
Trouble Info... | Opens the Trouble Info tab with information about the selected event. | |
Event Details... | Opens the Event Details window with information about the selected event. | |
Event Log... | Opens the Event Details Event Log tab for the selected event. | -- |
Switching... | Opens the Open or Create New Switching Sheet dialog box, which allows you to create a new switching sheet or open a switching sheet associated with the selected event. See Open or Create New Switching Sheet for more information. | -- |
Damage Assessment… | Opens the Damage Assessments tool, which displays a list of damage assessments associated with the selected event and allows you to add additional damage assessments. See Using the Damage Assessments Tab. | -- |
Show AMI Request… | Displays a list of active and completed AMI requests for the selected event. | -- |
Sort Dialog... | Opens the Sort Dialog, allowing you to create, modify, apply, and save user-defined sorts. See Using the Sort Dialog Box. | -- |
Default | Applies the default sort. | -- |
Outages | Displays all outage events. | -- |
Non Outages | Displays all non-outage events. | -- |
Both | Displays both outage and non-outage events. | -- |
Menu Option | Description | Toolbar Icon | Right-Click Y/N |
Acknowledge | Acknowledges the selected event. | Y | |
Work Queues... | Opens the Work Queues dialog box, allowing you to select work groups to refer the event to and enter any necessary notes. | Y | |
Send to Mobile | Changes the event status to a Sent status that is appropriate for the selected event (for example, SNT, S-SNT, P-SNT, W-SNT). Also, if the Sent to Mobile column value happens to be N at the time the Send to Mobile button is pressed, it will update to a value of Y. | -- | N |
Update ERTs... | Opens the Update ERT dialog box so you can enter a new ERT (Estimated Restoration Time) for all selected events. | -- | N |
System-Wide Default ERT... | Opens the System-Wide Default ERT dialog box, which allows you to view and modify the system-wide default restoration time value. (Use the Configuration Assistant to set restoration times for specific control zone‑asset class combinations.) | -- | N |
Associate Event... | Allows you to associate the selected fuzzy event to an asset. | -- | N |
Group Events... | Opens the Group Events dialog box, which allows you to manually merge, relate, and un-relate events. | -- | N |
Undo Grouping and Repredict | Ungroups and repredicts all calls from an event. It may be used to undo the results of manual grouping or repredict upstream/downstream. This action is not allowed for events with crews. See Ungrouping Events. | -- | N |
Update Events... | Opens the Update Events dialog box, which allows you to update multiple Event Details fields for the selected events. See Using the Update Events Window. | -- | Y |
Update All Related Events... | Opens the Update Events dialog box, which allows you to update multiple Event Details fields for all events related to the selected event. See Using the Update Events Window. | -- | Y |
Confirm/Restore Outage | Provides a submenu with options to confirm outages or convert an active outage event to a non‑outage. | ||
Confirm Outages... Opens the Confirm Outages dialog box, which allows you to confirm secondary or service outages for customers associated with event assets. | -- | Y | |
Convert to Non-Outage Converts the active PSO or PDO event to a Non‑Outage event. | -- | Y | |
Assign All Related | Assigns the selected crew to the selected event and all related events. • If the twoStepCrewAssignment rule is set to yes (non-product configuration), then the selected event should also be dispatched/sent and the other related events should just be assigned. • If the twoStepCrewAssignment rule is not set (product configuration), all of the events should be dispatched/sent. | Y | |
Release Crews... | Opens the Release Crews dialog box, which allows you to release assigned en route or onsite crews from an event. See Releasing Crews from an Event Selected in the Work Agenda for more information. | -- | Y |
Release from All Related... | Opens the Release Crews dialog box, which allows you to release assigned, en route, or onsite crews from an event and all related events. | -- | Y |
Cancel Event... | Cancels the selected event. A dialog box opens prompting you for a reason for the cancellation. | Y | |
Incomplete | Changes the status of the event to an Incomplete status that is appropriate for the selected event (for example, INC, S-INC, P-INC). | -- | N |
Make Predicted Stable | Makes currently selected predicted outage stable. Visible only when currently selected predicted outage can be made stable. See Working with Stable Predictions for more details. | Y | |
Remove Predicted Stable | Removes stable flag from the currently selected predicted stable outage. Visible only when predicted stable outage is selected. See Working with Stable Predictions for more details. | N | |
Reading Pane | Splits the Work Agenda table to display a pane with the selected row's details. | N | |
Abort DMS Processing | Aborts FLISR or Optimization processing. | ||
Show Event Note... | Enables a balloon dialog box that displays event notes, if they exist. | Y | |
Toggle Auto Filter | Allows you to quickly filter the table by the selected cell value. | -- | Y |
Find Selection | Scrolls the currently selected event back into view should it scroll off of the list. | -- | N |
Load Completed Events | By default, completed events are not loaded into the Work Agenda on startup for performance reasons. This action will open the Load Completed Events dialog box. | -- | N |
Load Completed Events - Range... | Opens the Load Completed Events - Range dialog box, which allows you to filter completed events by a start and end date. Note: the total number of events returned is bounded by the RULE_VALUE_INTEGER_1 field of the completedRetainPeriod SRS rule. See the Using the Event Management Rules Tab for more details. | -- | N |
Load Completed Event… | Opens the Load Completed Event Dialog, which allows you to load a specific completed event by specifying its Event number (index). | -- | N |
Generate Restoration Callbacks | Generate restoration callbacks for the selected row. | -- | |
Cancel Callbacks | Cancels callback requests for selected event. | N | |
Create Follow‑Up Event... | Displays the Create Event dialog to create a new related event. |
Work Agenda Help | Opens the online help system to the Work Agenda tool help content. | -- |
Sort... | Displays the Sort Dialog so you can modify the default sort. See Using the Sort Dialog Box. |
Select Columns... | Opens a dialog box that displays a list of columns that can be displayed in the Work Agenda table. A checkmark appears next to columns that are currently displayed. To remove a column from the table, deselect the box. To add a column that is not currently displayed, check the box. Click OK to exit. Note: These settings are applied immediately and affect only the current user session. To save these settings as the default view for the Work Agenda (for the currently logged-in user), select Save Preferences from the Web Workspace Preferences menu. |
Unlock Columns | When the Work Agenda is first launched, the first four columns are locked in place so they stay in view as you scroll the table to the right. • You may unlock the columns by choosing Unlock Columns from the context menu. • With the columns unlocked, you may lock columns by right-clicking the column you wish to be the right-most frozen column. |
