Menu Option | Description | Toolbar Icon |
Refresh | Refreshes the Condition Summaries window to display the most recent updates. If you edit a condition using the Edit button, you must refresh the summary to see your changes. | |
Print Preview... | Displays the Print Preview window, from which you can view and print the summary. | |
Delete Row... | Deletes the selected condition from the system. A confirmation dialog box prompts you to confirm before deleting. Once deleted, the condition disappears from both the Summary and the Viewer. | |
Toggle Dockable Window | Changes a standalone window to a pane that may be moved or docked in another window or frame. See Understanding Docked Panes and Standalone Window Tools for more information on dockable and standalone windows. | |
Exit | Closes the Condition Summaries window. | -- |
Sort Dialog... | Displays the Sort Dialog. The Sort Dialog option on the Sort menu performs the same function. See Using the Sort Dialog Box for common sort functions. | |
Condition # | Sorts the Conditions Summaries table by the Condition # column. | -- |
Asset | Sorts the Conditions Summaries table by the Asset column. | -- |
Date Created | Sorts the Conditions Summaries table by the Date Created column. | -- |
Edit... | Opens the Edit balloon dialog box. See Editing Conditions. | |
Enable View Balloon | Enables or disables balloon details. When enabled, a call‑out balloon opens that provides information, such as notes or related asset documents, if applicable, for a selected row. See Using Condition Summaries Balloon Details for more information. | |
View... | Focuses the Viewer on the asset associated with the condition. |
Condition Summaries Help | Opens the online help system to the Condition Summaries help content. | -- |
Filter Name | Description |
All Conditions | Displays all conditions. |
Notes | Displays only rows with Type equal to Note. |
Pending Construction | Displays only rows with Type equal to Pending Construction. |
Pending Decommission | Displays only rows with Type equal to Pending Decommission. |
Quarantine | Displays on rows for the Quarantine (QUAR) work queue. |
Tags | Displays only rows with Type equal to Tag. |
