Menu Option | Description | Toolbar Icon |
New... | Opens the New Switching Sheet tool that allows you to create a new switching sheet based on the switching type (for example, planned or emergency). | |
Open... | Opens the selected switching sheets. If the window is not pinned or docked, the window will be closed once the sheets are loaded. Note: If the sheet is locked by another user, the Failed to Establish User Lock dialog box will be displayed; see Opening Locked Documents for information. | |
Copy Steps | Copies the selected switching sheet's steps without opening it. The copied steps may then be pasted into another switching sheet. | |
Export Table... | Opens a dialog box to allow you to save the current table view data to a comma separated value (csv) file. | |
Export Sheets... | Export the selected switching sheet as JavaScript Object Notation (JSON) text files to your local file system. These files can then be imported into NMS. This option is restricted to Administration and Trainer user types. See Exporting/Importing Switching Sheets for details. | -- |
Import Sheets... | Import switching sheets into NMS via JavaScript Object Notation (JSON) text files from your local file system. These JSON files were created from the Export Sheets... option or from the switching sheet's Export option. Imports are restricted to switching sheet types Planned, Emergency, Template and Training Scenario. See Exporting/Importing Switching Sheets for details. | -- |
Print List... | Displays the Print Preview dialog box so you can view or print the list. | |
Print Preview Selected Sheets... | Displays the Content Selection dialog box so that you can choose which sections of each highlighted sheet to include in the generated documents. By default, PDF documents will be created for each of the highlighted switching sheets. | |
Print Selected Sheets... | Displays the Content Selection dialog box so that you can choose which sections of each highlighted sheet to include in the generated documents. By default, PDF generated documents will be printed for each of the highlighted switching sheets. The Content Selection dialog box also includes the target print service. Your default printer will be the default option selected in the combo box list. | |
Email Selected Sheets... | Displays the Content Selection dialog box so that you can choose which sections of each highlighted sheet to include in the generated documents. By default, PDF documents will be created for each of the highlighted switching sheets. | |
Toggle Dockable Window | Changes a standalone window to a pane that may be moved or docked in another window or frame. See Understanding Docked Panes and Standalone Window Tools for more information on dockable and standalone windows. | |
Exit | Closes the Switching List window. | -- |
Sort Dialog... | Opens the Sort Dialog, allowing you to create, modify, apply, and save user-defined sorts. See Using the Sort Dialog Box. | -- |
Sheet # | Applies the default sort, which is the sheet # in descending order. | -- |
Refresh | Refresh the switching sheet list with the latest data from the database. | |
Unpin | Unpin the window so that it will close after an open safety document request. Note: The icon shows the current state so the option will be the result of the action and the button will initially show the current state: to unpin, click the Pin button. | |
Pin | Pin the window so that it will not close after an open safety document request. Note: The icon shows the current state so the option will be the result of the action and the button will initially show the current state: to pin, click the unpinned button. | |
View... | Opens Viewer 1 (if not already open), and focuses on the device from the selected sheet row. |
Switching Sheet List Help | Opens the online help system to the Switching Sheet List help content. | -- |
Global Filter | Description |
Active | Displays all the active switching sheets (switching sheets NOT in the Status New, Completed, Deleted, Canceled, or Training-Completed). |
All | Displays all non-complete switching sheets and completed switching sheets from the last 30 days. - No Icon Completed - Displays switching sheets that have been completed in the last 30 days. |
Completed | Displays switching sheets that have been completed in the last 30 days. |
In Progress | Displays all switching sheets in the In Progress state. |
My Sheets | This displays all sheets that were created or are owned by the current user. |
New | Displays all switching sheets in the New state. |
Require Verification | Displays the switching sheets that require verification after model change. |
Today | Display switching sheets that are scheduled or are being worked on Today. |
Tomorrow | Display switching sheets that are scheduled for Tomorrow. |
