Menu Option | Description |
Assign Color... | Opens a dialog box that allows you to select a feeder color. |
PF Mode | Allows you to set the PF Mode for the selected feeder: • kVA • Power Flow • Disabled |
PF History | Allows you to maintain the power flow results history in the database for the selected feeder: • Enable • Disable |
FLM Status | Allows you to set the FLM mode for the selected feeder: • Forecasting • Custom Forecasting • Real-Time • Disable |
FLISR Status | Allows you to set the FLISR mode for the selected feeder: • Automatic • Manual • Disable • Restore Only |
FLA Status | Allows you to set the FLA mode for the selected feeder: • Disable • Sustained • Momentary and Sustained Note: See Global FLA Versus Individual Feeder FLA Configuration for more information on FLA status. |
Optimization Status | Allows you to set the Optimization mode for the selected feeder: • Automatic (Slow Cycle) • Automatic (Fast Cycle) • Manual (Slow Cycle) • Manual (Fast Cycle) • Disable • Note: When a feeder is set for Disable mode, the tool will restore the feeder's regulation devices to nominal during the next Optimization cycle. During this scenario, the plan may consist of a blend of optimization steps and return to nominal steps. For example, if a feeder on a bus that contains five feeders was set to Disable, the steps would consist of return to nominal for that feeder and optimization for the remaining four that are enabled. |
Optimization Objective | Allows you to select the Optimization Objective for the feeder. • Conservation Voltage Reduction • Loss Minimization • Power Factor Correction • Relieve Violations • None |
Protection Schemes | Allows you to select the Protection Scheme setting for the feeder. • Disable • Manual • Automatic |
Protection Schemes Mode | Allows you to select the Protection Scheme Mode setting for the feeder. • Before • After |
NCA Objective | Allows you to set the NCA objective for the selected feeder: • Ignore Pre-Existing Conditions • Consider Pre-Existing Conditions • Disable |
Feeder Type | Allows you to select the Feeder Type. • Sub Transmission Transformer • Sub Transmission • Primary Transformer • Primary • Secondary Transformer • Secondary • None Note: The selections are based on the feeder types available in your model. |
